I’m wondering if there is a simple way to convert a cubin file to an object file?
I need this because I want to run the edited cubin file on GPU. I know one way to do it is to use driver API functions. But it seems too complicated for my purpose.
I know I can do “nvcc -cubin myfile.cu” to compile myfile.cu to myfile.cubin, then I edit the cubin file (delete instructions, add instructions, etc, BTW, I know what the instructions mean by using decuda), I just need something further to convert the edited cubin file to an object file.
Hi, I figured this out. This actually can be done pretty easily. I put it here for the people who might be interested this.
There are 3 steps,
(1) do “nvcc myfile.cu”, this will generete a temporaty cubin file in folder /tmp
(2) modify this cubin file according to your needs.
(3) do “nvcc -dryrun myfile.cu” to list all nvcc compiliation commands, run all commands after fatbin (including fatbin) to generate the object file of the modified cubin file. (you can copy these compiliation commands to a script to make it more convenient )
