Converting engine file into tensorRT
Software Version
DRIVE OS 6.0.10.0
[1]DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[1]Linux
QNX
other
Hardware Platform
[1]DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
[1]other
Host Machine Version
other
Issue Description
Hi team, If I have a yolo.engine file, Can I convert this file into tensorRT using tensorRT optimization tool? Can I use this file for running inference?
Dear @akshay.tupkar ,
You need ONNX model to get DW compatible TRT model using tensorRT_optimization tool
That is already a tensorrt serialized file. You must have used the trtexec binary. You need to use onnx file with the tool.
