Converting from TensorFlow 1 to TensorRT
Is there a simple way of converting a frozen graph model from TensorFlow 1 to a .UFF file for use with TensorRT? I have done some research into this but haven’t found anything that’s easy to do - is there an easy tutorial out there? Or is there a python script which I can just use so that I can convert from TF1 to TRT.
Thanks in advance!
You can find an example below:
In general, you need to run a similar command as below to convert a .pb file into .uff.
$ convert-to-uff -p config.py -O dense_class/Softmax -O dense_regress/BiasAdd -O proposal faster_rcnn.pb
I tried to do this but just got a bunch of errors when I tried to convert.
