It is possible to convert PIXEL_FMT_YCbCr_420_888 to RGB ?
I could not convert “mapBuffer” to rgb data.
Perhaps have someone any example, how can I do it correctly or any Ids what is wrong ?
Write to JPEG works.
EGLStream::Image *image = iFrame->getImage();
if (!image)
setMsg(“Failed to get Image from interface”);
return ;
if (isRec) // Recording Image
EGLStream::IImageJPEG *iImageJPEG = Argus::interface_castEGLStream::IImageJPEG(image);
if (!iImageJPEG)
setMsg(“Failed to get ImageJPEG Interface”);
return ;
status = iImageJPEG->writeJPEG(“test.jpg”);
if (status != Argus::STATUS_OK)
SET_MSG(DEB_LVL_LOW, "Failed write jpeg);
// Prepare Preview Image
EGLStream::IImage *iImageData = Argus::interface_castEGLStream::IImage(image);
if (!iImageData)
setMsg(“Failed to get IImage Interface”);
return ;
size = iImageData->getBufferSize();
int width = 640;
int height = 480;
int nSize = width * height * 3;
char *rgb = new char[nSize];
memset(rgb, 255, nSize);
yuv_to_rgb((char*)iImageData->mapBuffer(), rgb, width, height); // ! Conversion not work !
I have try at less with 11 Versions, but still something doesn’t work and my Preview Images look like bad.
A few decode samples:
// PIXEL_FMT_YCbCr_420_888
// VER 1
int yuv2rgb(int Y, int Cb, int Cr, int* r, int* g, int* b)
unsigned int r_tmp, g_tmp, b_tmp;
unsigned char r_t, g_t, b_t;
// ORG
// r_tmp = (Y + 1.402 * (Cr - 128));
// g_tmp = (Y - 0.34414 * (Cb - 128) - 0.71414 * (Cr - 128));
// b_tmp = (Y + 1.772 * (Cb - 128));
// T2
r_tmp = (Y + 1.402 * (Cr));
g_tmp = (Y - 0.34414 * (Cr) - 0.71414 * (Cb));
b_tmp = (Y + 1.772 * (Cb));
// T3
// r_tmp = (Y + 1.402 * (Cr));
// g_tmp = (Y - 0.34414 * (Cr) - 0.71414 * (Cb));
// b_tmp = (Y + 1.772 * (Cb));
// T1
// r_tmp = (Y + 1.370705 * (Cr));
// g_tmp = (Y - 0.698001 * (Cr) - 0.337633 * (Cb));
// b_tmp = (Y + 1.732446 * (Cb));
r_t = MAX (0, MIN (255, r_tmp));
g_t = MAX (0, MIN (255, g_tmp));
b_t = MAX (0, MIN (255, b_tmp));
// r_t = (unsigned char)(Y + 1.403Cr);
// g_t = (unsigned char)(Y - 0.344Cb - 0.714Cr);
// b_t = (unsigned char)(Y + 1.770Cb);
*r = r_t;
*g = g_t;
*b = b_t;
return 0;
void yuv_to_rgb(char* yuv, char* rgb, int width, int height)
int y, cb, cr;
int r, g, b;
int i = 0;
char* p_y;
char* p_u;
char* p_v;
char* p_rgb;
int chroma_v = 2;
int chroma_h = 4;
int cbcr_width;
int cbcr_height;
int cbcr_size;
cbcr_width = width * (chroma_h / 4.0);
cbcr_height = height * (chroma_v / 4.0);
cbcr_size = cbcr_width * cbcr_height;
p_y = yuv;
p_u = p_y + width * height;
p_v = p_u + cbcr_size;
p_rgb = rgb;
for (i = 0; i < cbcr_size; i++)
y = p_y[0];
cb = p_u[0];
cr = p_v[0];
yuv2rgb(y, cb, cr, &r, &g, &b);
p_rgb[0] = r;
p_rgb[1] = g;
p_rgb[2] = b;
y = p_y[1];
cb = p_u[0];
cr = p_v[0];
p_rgb[3] = r;
p_rgb[4] = g;
p_rgb[5] = b;
p_y += 2;
p_u += 1;
p_v += 1;
p_rgb += 6;
// VER 2
void yuv420_to_rgb24_3(char yuv420, char rgb24, int width, int height)
char p_y;
char p_u;
char* p_v;
int R,G,B,Y,U,V;
int x,y;
int nWidth = width>>1;
p_y = yuv420;
p_v = p_u + width * height / 4;
for (y=0;y<height;y++)
for (x=0;x<width;x++)
Y = *(p_y + y*width + x);
U = *(p_u + ((y>>1)*nWidth) + (x>>1));
V = *(p_v + ((y>>1)*nWidth) + (x>>1));
R = Y + 1.402*(V-128);
G = Y - 0.34414*(U-128) - 0.71414*(V-128);
B = Y + 1.772*(U-128);
yuv2rgb(Y, U, V, &R, &G, &B);
if (R>255)R=255;
if (R<0)R=0;
if (G>255)G=255;
if (G<0)G=0;
if (B>255)B=255;
if (B<0)B=0;
*(rgb24 + (y*width + x)*3) = R;
*(rgb24 + (y*width + x)*3 + 1) = G;
*(rgb24 + (y*width + x)*3 + 2) = B;
// VER 3
void yuv_to_rgb_ver6(char* yuv, char* rgb, int width, int height)
uint8_t size = width * height;
for (int h = 0; h < height; h++)
for (int w = 0; w < width; w++)
// VER 1
// uint8_t y = yuv[h * width + w];
// uint8_t u = yuv[(uint)((h * 0.5) * (width * 0.5) + (w * 0.5) + size)];
// uint8_t v = yuv[(uint)((h * 0.5) * (width * 0.5) + (w * 0.5) + size + (size / 4))];
// uint8_t r = 0;
// uint8_t g = 0;
// uint8_t b = 0;
// yuv2rgb_ver6(y, u, v, &r, &g, &b);
// rgb[0] = r;
// rgb[1] = g;
// rgb[2] = b;
// rgb += 3;
// END VER 1
// VER2
int Y = yuv[h * width + w] & 0xFF;
int U = yuv[(h / 2) * (width / 2) + (w / 2) + size] & 0xFF;
int V = yuv[(h / 2) * (width / 2) + (w / 2) + (size / 4)] & 0xFF;
U = U - 128;
V = V - 128;
int R,G,B;
R = (int)(Y + 1.402 * V);
G = (int)(Y - 0.34414 * U - 0.71414 * V);
B = (int)(Y + 1.772 * U);
R = MAX (0, MIN (255, R));
G = MAX (0, MIN (255, G));
B = MAX (0, MIN (255, B));
rgb[h*4*width+w*4 ] = (char) R;
rgb[h*4*width+w*4+1] = (char) G;
rgb[h*4*width+w*4+2] = (char) B;
rgb[h*4*width+w*4+3] = 255;
etc …
Thx for any help.
