Hi
Thank you for replying, however I am still stuck! I am not trying to convert to YV12, I am just trying to give jetson-inference any format its happy with and YV12 just happens to be one of the potential input formats I have access to. Maybe if I describe the problem a little more that will help:
I am using a program which turns the topic from kinect2_bridge into a dev/video1 v4l2 stream. It can produce BGR3, RGB3, GREY, YV12, YUYV pixel formats depending what I choose. If I run it with YUYV and HD resolution options, and then do
v4l2-ctl -d /dev/video1 -V
I get:
$ v4l2-ctl -d /dev/video1 -V
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'YUYV'
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default
YCbCr Encoding : Default
Quantization : Default
Flags :
If I run
gst-launch-1.0 v4l2src device=/dev/video1 ! xvimagesink
I can view the stream. I have experimented with all the formats except grey, and a range of resolutions (1280 x 720, 1920 x 1080, 640 x 480).
When I run jetson-inference, it initially says that it has opened the camera stream but then fails. Here is the terminal output:
$ ./imagenet-camera imagenet-camera
args (1): 0 [./imagenet-camera]
[gstreamer] initialized gstreamer, version 1.8.3.0
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVCAMERA
[gstreamer] gstCamera pipeline string:
v4l2src device=/dev/video1 ! video/x-raw, width=(int)1280, height=(int)720, format=RGB ! videoconvert ! video/x-raw, format=RGB ! videoconvert !appsink name=mysink
[gstreamer] gstCamera successfully initialized with GST_SOURCE_V4L2
imagenet-camera: successfully initialized video device
width: 1280
height: 720
depth: 24 (bpp)
imageNet -- loading classification network model from:
-- prototxt networks/googlenet.prototxt
-- model networks/bvlc_googlenet.caffemodel
-- class_labels networks/ilsvrc12_synset_words.txt
-- input_blob 'data'
-- output_blob 'prob'
-- batch_size 2
[TRT] TensorRT version 4.0.2
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file networks/bvlc_googlenet.caffemodel.2.1.GPU.FP16.engine
[TRT] loading network profile from engine cache... networks/bvlc_googlenet.caffemodel.2.1.GPU.FP16.engine
[TRT] device GPU, networks/bvlc_googlenet.caffemodel loaded
[TRT] device GPU, CUDA engine context initialized with 2 bindings
[TRT] networks/bvlc_googlenet.caffemodel input binding index: 0
[TRT] networks/bvlc_googlenet.caffemodel input dims (b=2 c=3 h=224 w=224) size=1204224
[cuda] cudaAllocMapped 1204224 bytes, CPU 0x101540000 GPU 0x101540000
[TRT] networks/bvlc_googlenet.caffemodel output 0 prob binding index: 1
[TRT] networks/bvlc_googlenet.caffemodel output 0 prob dims (b=2 c=1000 h=1 w=1) size=8000
[cuda] cudaAllocMapped 8000 bytes, CPU 0x101740000 GPU 0x101740000
device GPU, networks/bvlc_googlenet.caffemodel initialized.
[TRT] networks/bvlc_googlenet.caffemodel loaded
imageNet -- loaded 1000 class info entries
default X screen 0: 1920 x 1080
[OpenGL] glDisplay display window initialized
[OpenGL] creating 1280x720 texture
loaded image fontmapA.png (256 x 512) 2097152 bytes
[cuda] cudaAllocMapped 2097152 bytes, CPU 0x101940000 GPU 0x101940000
[cuda] cudaAllocMapped 8192 bytes, CPU 0x101742000 GPU 0x101742000
[gstreamer] gstreamer transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstCamera onEOS
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert1
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer msg stream-start ==> pipeline0
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer v4l2src0 ERROR Internal data flow error.
[gstreamer] gstreamer Debugging info: gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason not-negotiated (-4)
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
imagenet-camera: camera open for streaming
imagenet-camera: failed to capture frame
imagenet-camera: failed to convert from NV12 to RGBA
[TRT] imageNet::Classify( 0x(nil), 1280, 720 ) -> invalid parameters
[cuda] cudaNormalizeRGBA((float4*)imgRGBA, make_float2(0.0f, 255.0f), (float4*)imgRGBA, make_float2(0.0f, 1.0f), camera->GetWidth(), camera->GetHeight())
[cuda] invalid device pointer (error 17) (hex 0x11)
[cuda] /home/nvidia/jetson-inference/imagenet-camera/imagenet-camera.cpp:198
[cuda] registered 14745600 byte openGL texture for interop access (1280x720)
So it looks like it is trying to convert from NV12 anyway, despite opening an RGB / RGB stream under gstreamer. I have set the v4l2 index from -1 to 0 or 1, and recompiled, neither helps.
I am also not sure how to use the commands you mentioned above. In the terminal I can run say
gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw, width=1920, height=1080, format=RGB ! videoconvert ! video/x-raw, format=RGB ! videoconvert ! xvimagesink
or even
gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw, width=1920, height=1080, format=RGB ! videoconvert ! video/x-raw, format=NV12 ! videoconvert ! xvimagesink
And I can view the stream. Then I try with jetson-inference bit same errors.
I also tried
! videoconvert ! appsink name=mysink
as appsink name=mysink is the sink named in the error message. That did not work either. Should running these in the terminal have any effect on running imagenet-camera?
Additionally I have looked into substituting a function from
cudaYUV.h
for
convertRGBA()
in imagenet-camera.cpp, but again am running into the limit of my coding ability here. I changed
if( !camera->ConvertRGBA(imgCUDA, &imgRGBA) )
printf("imagenet-camera: failed to convert from NV12 to RGBA\n");
to
if( !cudaYUYVToRGBA(imgCUDA, &imgRGBA, camera->GetWidth(), camera->GetHeight())
printf("imagenet-camera: failed to convert from YUYV to RGBA\n");
but of course the types of the arguments are different, with convertRGBA requiring
ConvertRGBA( void* input, void** output, bool zeroCopy )
and cudaYUV.h’s function requiring:
cudaError_t cudaYUYVToRGBA( uchar2* input, uchar4* output, size_t width, size_t height )
So I get errors relating to type conversions. I know enough to realise that cudaYUYVToRGBA is not a member function of the camera object but I am not sure if that is the correct way to handle it or not, just #include ing the header file and calling the function?
Sorry I know this is a big post and a lot to ask, I am drowning a bit and could really use some detailed help! :)
Thank you
