Hi Nvidia Team,
I have converted the Slow Fast model(trained on our Custom dataset) from Pt to ONNX. I need to further convert the ONNX model to TRT. But the main challenge is that the model has two Inputs(As shown in the image below). I usually convert the ONNX model to TRT using the standard code below:
import tensorrt as trt
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
trt_runtime = trt.Runtime(TRT_LOGGER)
def build_engine(onnx_path, shape = [1,3,112,112]):
with trt.Builder(TRT_LOGGER) as builder, builder.create_network(1) as network, trt.OnnxParser(network, TRT_LOGGER) as parser:
builder.fp16_mode = True
builder.max_workspace_size = (256 << 20)
with open(onnx_path, 'rb') as model:
parser.parse(model.read())
network.get_input(0).shape = shape
engine = builder.build_cuda_engine(network)
return engine
def save_engine(engine, file_name):
buf = engine.serialize()
with open(file_name, 'wb') as f:
f.write(buf)
def load_engine(trt_runtime, plan_path):
with open(engine_path, 'rb') as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
from onnx import ModelProto
engine_name = "model.trt"
onnx_path = "model.onnx"
model = ModelProto()
with open(onnx_path, "rb") as f:
model.ParseFromString(f.read())
batch_size = 1
d0 = model.graph.input[0].type.tensor_type.shape.dim[1].dim_value
d1 = model.graph.input[0].type.tensor_type.shape.dim[2].dim_value
d2 = model.graph.input[0].type.tensor_type.shape.dim[3].dim_value
shape = [batch_size , d0, d1 ,d2]
engine = build_engine(onnx_path)
save_engine(engine, engine_name)
But, as I mentioned above that the Slowfast model has two inputs, I am facing difficulty in converting the ONNX Model(with two inputs) to TRT.
I Kindly request you assist me in changing the above Code for two Inputs for Conversion.
Thanks in advance,
Darshan
