Converting TAO-trained MaskRCNN models to ONNX for CPU inference
• Hardware (RTX 3090)
• Network Type (Mask_rcnn)
Hi, I want to perform CPU inference using TAO-trained MaskRCNN models. I previously was able to do so using TAO-trained DetectNet_v2 models by converting them into ONNX, and I was hoping to do the same for TAO-trained MaskRCNN models.
I’m trying to do this as I want to use the ONNX weights with a CPU-only instance of Triton Inference Server. It currently works with the TAO-trained DetectNet_v2-converted ONNX models, and I’m trying to figure out how to do so for the TAO-trained MaskRCNN models as well.
I understand that back in 2022, there was no support for direct TAO-trained MaskRCNN → ONNX conversion. Does this still hold true as of today?
If yes, are there other, perhaps indirect ways to perform this conversion? (E.g. converting/exporting into an intermediary file format that can then be converted into ONNX?)
Since TAO 5.0, you can generate the .onnx file instead of .etlt file.
You can refer to 5.0 or latest 5.5(link) notebook.
Using TAO 5.3.0, upon running the relevant command (10. Deploy!):
!tao model mask_rcnn export -m $USER_EXPERIMENT_DIR/experiment_dir_retrain/model.epoch-$NUM_EPOCH.tlt \
                      -e $SPECS_DIR/maskrcnn_retrain_resnet50.txt \
                      -k tlt_encode \
                      --gen_ds_config
I get an UFF file instead of an ONNX file. Specifically, the logs show:
2024-10-02 04:12:25,307 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.mask_rcnn.export.exporter 300: Converted model was saved into /usr/src/app/mask_rcnn/experiment_dir_unpruned/model.epoch-199.uff
Is this expected?
After checking, currently, Mask_rcnn does not support export to ONNX file yet. Suggest you to use trtexec to generate tensorrt engine for running inference on GPU.
I see. For my use case:
does that mean that there is no way at all for me to get TAO-trained MaskRCNN models running for CPU-only instances?
If no, is export to ONNX on the roadmap for the next update/release?
Will sync internally for this feature request.
Suggest to shift to Mask2Former as alternative. Please refer to latest TAO 5.5 user guide or notebook.
Thank you for the update, I will keep it in mind.
Might I suggest you feedback internally to update the provided notebook accordingly too? Like both of us, I suspect there will be others who might also be misled by the in-line ONNX comments in here: tao_tutorials/notebooks/tao_launcher_starter_kit/mask_rcnn/maskrcnn.ipynb at main · NVIDIA/tao_tutorials · GitHub
Got it. We will improve the notebook. Thanks for the catching!
