I’ve finished training a Mask RCNN model from TAO Toolkit Getting Started | NVIDIA NGC (skipped steps 6 and 7 of pruning and retraining) using a custom dataset on AWS EC2 and was then trying to run inference on my own Jetson Orin AGX.
I’m currently with a .tlt model that, running the !tao maskrcnn export function, exports it to a .uff file (despite the notebook saying it would generate a .onnx file… anyways)
The notebook then generates a TensorRT engine through the !tao deploy mask_rcnn gen_trt_engine function, that I’m not able to run on the Jetson since I guess it’s created based on the GPU architecture for the AWS machine that’s not the one on the Orin. So I also tried to run the !tao deploy mask_rcnn gen_trt_engine function straight on the Orin without any success.
Could you please guide me through these final steps… what should I do and then finally how to implement (using deepstream maybe?)
Thank you very much for any kind of help,
Best regards
I’m running the notebook from the link above, version 5.0.0 in notebooks/tao_launcher_starter_kit/mask_rcnn, the model is downloaded from !ngc registry model download-version nvidia/tao/pretrained_instance_segmentation:resnet50 (for what I saw in one of the links that’s also the architecture used on PeopleSegNet, right?)
I tried using tao-converter, but its documentation says I need an .etlt file - when running !tao maskrcnn export I get only a .uff as mentioned above. Any comments?
I was able to export the model using:
trtexec
–uff=/export/model.epoch-149.uff
–maxBatch=16
–uffInput=Input,3,1024,1024
–output=generate_detections,mask_fcn_logits/BiasAdd
–saveEngine=/export/model.engine
