I am trying to convert the EfficientDet D1 640x640 of the new Tensorflow 2 Object Detection API to a TensorRT Model to run on my Jetson AGX Board.
I am running the following Code:
import tensorflow as tf
import numpy as np
from tensorflow.python.compiler.tensorrt import trt_convert as trt
input_saved_model_dir = './efficientdet_d1_coco17_tpu-32/saved_model/'
output_saved_model_dir = './models/tensorRT/'
num_runs = 2
conversion_params = trt.DEFAULT_TRT_CONVERSION_PARAMS
conversion_params = conversion_params._replace(max_workspace_size_bytes=(1<<32))
conversion_params = conversion_params._replace(precision_mode="FP16")
# conversion_params = conversion_params._replace(maximum_cached_engiens=100)
converter = trt.TrtGraphConverterV2(input_saved_model_dir=input_saved_model_dir,conversion_params=conversion_params)
converter.convert()
def my_input_fn():
for _ in range(num_runs):
inp1 = np.random.normal(size=(1, 640, 640, 3)).astype(np.uint8)
yield inp1
converter.build(input_fn=my_input_fn)
converter.save(output_saved_model_dir)
I am getting the following Error:
InvalidArgumentError Traceback (most recent call last)
<ipython-input-5-d7c3941a6051> in <module>
7 yield inp1
8
----> 9 converter.build(input_fn=my_input_fn)
10 converter.save(output_saved_model_dir)
/projects/sebschaefer/venv/tf22gpu_copy/lib/python3.6/site-packages/tensorflow/python/compiler/tensorrt/trt_convert.py in build(self, input_fn)
1172 if not first_input:
1173 first_input = inp
-> 1174 func(*map(ops.convert_to_tensor, inp))
1175
1176 if self._need_trt_profiles:
/projects/sebschaefer/venv/tf22gpu_copy/lib/python3.6/site-packages/tensorflow/python/eager/function.py in __call__(self, *args, **kwargs)
1603 TypeError: For invalid positional/keyword argument combinations.
1604 """
-> 1605 return self._call_impl(args, kwargs)
1606
1607 def _call_impl(self, args, kwargs, cancellation_manager=None):
/projects/sebschaefer/venv/tf22gpu_copy/lib/python3.6/site-packages/tensorflow/python/eager/function.py in _call_impl(self, args, kwargs, cancellation_manager)
1643 raise TypeError("Keyword arguments {} unknown. Expected {}.".format(
1644 list(kwargs.keys()), list(self._arg_keywords)))
-> 1645 return self._call_flat(args, self.captured_inputs, cancellation_manager)
1646
1647 def _filtered_call(self, args, kwargs):
/projects/sebschaefer/venv/tf22gpu_copy/lib/python3.6/site-packages/tensorflow/python/eager/function.py in _call_flat(self, args, captured_inputs, cancellation_manager)
1744 # No tape is watching; skip to running the function.
1745 return self._build_call_outputs(self._inference_function.call(
-> 1746 ctx, args, cancellation_manager=cancellation_manager))
1747 forward_backward = self._select_forward_and_backward_functions(
1748 args,
/projects/sebschaefer/venv/tf22gpu_copy/lib/python3.6/site-packages/tensorflow/python/eager/function.py in call(self, ctx, args, cancellation_manager)
596 inputs=args,
597 attrs=attrs,
--> 598 ctx=ctx)
599 else:
600 outputs = execute.execute_with_cancellation(
/projects/sebschaefer/venv/tf22gpu_copy/lib/python3.6/site-packages/tensorflow/python/eager/execute.py in quick_execute(op_name, num_outputs, inputs, attrs, ctx, name)
58 ctx.ensure_initialized()
59 tensors = pywrap_tfe.TFE_Py_Execute(ctx._handle, device_name, op_name,
---> 60 inputs, attrs, num_outputs)
61 except core._NotOkStatusException as e:
62 if name is not None:
InvalidArgumentError: 2 root error(s) found.
(0) Invalid argument: Input shapes do not match input partial shapes stored in graph, for TRTEngineOp_5: [[640,640,3]] != [[1,?,?,3]]
[[node TRTEngineOp_5 (defined at <ipython-input-5-d7c3941a6051>:2) ]]
[[StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/TRTEngineOp_43/_240]]
(1) Invalid argument: Input shapes do not match input partial shapes stored in graph, for TRTEngineOp_5: [[640,640,3]] != [[1,?,?,3]]
0 successful operations.
0 derived errors ignored. [Op:__inference_pruned_177388]
Function call stack:
pruned -> pruned
The error message says that it expects an input shape of [1,?,?,3], but get’s [640,640,3]. But I am passing the array of size (1,640,640,3), which should be correct. But fore some reason it doesn’t seem to work.
The Model I am using is the pretrained model from the Tensorflow 2.0 Object Detection Api (models/tf2_detection_zoo.md at master · tensorflow/models · GitHub)
Thanks in advance for your help!
