Hello, I am trying to convert my trained model (EfficientDet D0) from Tensorflow Object Detection API to TensorRT. A mentor from NVIDIA provided my a useful resource from TensorRT Github EfficientDet. I followed the README.md step by step, however, in the Create ONNX Graph (from the instructions). I have an error when executing the following command line:
python create_onnx.py --input_shape '1,512,512,3' --saved_model ./saved_model --onnx ./model.onnx
The error looks as follows:
INFO:tf2onnx.tf_utils:Computed 2 values for constant folding
INFO:tf2onnx.tfonnx:folding node using tf type=Select, name=StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/PadOrClipBoxList/Select_1
INFO:tf2onnx.tfonnx:folding node using tf type=Select, name=StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/PadOrClipBoxList/Select_8
INFO:tf2onnx.optimizer:Optimizing ONNX model
INFO:tf2onnx.optimizer:After optimization: BatchNormalization -45 (108->63), Cast -88 (197->109), Const -756 (1411->655), GlobalAveragePool +16 (0->16), Identity -109 (109->0), Less -1 (10->9), Mul -2 (170->168), Placeholder -2 (6->4), ReduceMean -16 (16->0), ReduceSum -4 (5->1), Reshape -89 (147->58), Shape -5 (29->24), Slice -9 (58->49), Split -1 (15->14), Squeeze +5 (95->100), Sub -4 (36->32), Transpose -681 (767->86), Unsqueeze -51 (188->137)
INFO:EfficientDetGraphSurgeon:TF2ONNX graph created successfully
[W] colored module is not installed, will not use colors when logging. To enable colors, please install the colored module: python3 -m pip install colored
[W] 'Shape tensor cast elision' routine failed with: None
INFO:EfficientDetGraphSurgeon:Graph was detected as TFOD
INFO:EfficientDetGraphSurgeon:ONNX graph input shape: [1, 512, 512, 3] [NHWC format detected]
File "create_onnx.py", line 451, in <module>
main(args)
File "create_onnx.py", line 425, in main
effdet_gs.update_preprocessor(args.input_shape)
File "create_onnx.py", line 155, in update_preprocessor
mean_val = -1 * np.expand_dims(np.asarray([0.485, 0.456, 0.406], dtype=np.float32), axis=(0, 2, 3))
File "<__array_function__ internals>", line 6, in expand_dims
File "/usr/local/lib/python3.6/dist-packages/numpy/lib/shape_base.py", line 577, in expand_dims
if axis > a.ndim or axis < -a.ndim - 1:
TypeError: '>' not supported between instances of 'tuple' and 'int'
I tried to modifty the create_onnx.py in the line 155, however, i had no success. Then, I tried to use the pretrained model from efficientdet d0 pretrained model and same error occurs. Finally, I tried to change the order of the command line from ‘1,512,512,3’ to ‘1,3,512,512’, and I have no success.
I would appreciate any help with this problem. Thank you in advanced for all the support.
