So a few times Iowered the clocks of my GB10 during long tasks to reduce the temps and I honestly never felt a lot (if any) performance lost, so today, I decided to actually measure:
I ran the same benchmark twice (codeneedle) in this case with Qwen3.6-35b-a3b-NVFP4. First run, normal clocks (hovered between 2400 and 2470mhz) and the 2nd run by limiting the clocks to 2000Mhz.
Run 1 - Stock speed:
- GPU Power = 43w
- Speed (avg) = ~113tk/s
you can see from the graph the orange line oscillating between 100 and 130 t/k.
Run 3 - 2000 mhz:
- GPU Power = 25w
- Speed (avg) = ~113t/s
Again, you can clearly see that the Generation throughput moves between the same range even at ~18w less.
There are many other benchmarks I can run and document (pre-fill speed, lama-benchy at different pressures, etc,etc) and also other models (I eyeballed a lot 122b-a10b as well) but the result is always the same. Less power draw, lower temps, about the same speed. I was able to bench lower speeds once in a repetitive way, but it was ~2% less at 30% less power, so still a win.
Try it out for yourselves! grab your results and your use case and report back, I’m curious if it’s the same for everyone or if there’s a use case that its really hurt by the reduced speeds.
sudo nvidia-smi -lgc 0,2000 - Reduced speeds
sudo nvidia-smi -lgc 0,3000 - Stock settings.
