I can consistently capture power consumption during prefill, but instant speed is trickier since the /monitor API from vLLM is not responding me with real-time decoding speed. But I can definitely try to record more data (and I will) with more prefill heavy scenarios.
The scenario I showed in my graph is very VERY similar to my real-world use, so very relevant to me.
If you want to try it in real time, the easiest way is to use Sparkview — GPU monitor tool with GB10-aware unified memory handling as it will show you clocks, power draw, temperature and everything. You can try both clocks configuration and watch the real time results.
