Hi all,
I’m having real problems copying a 2d array of ints or float complex from host to device.
I’m allocating the host memory using malloc, could this cause a problem when copying?
Has anybody got an example they could post???
Thanks,
Wes.
Hi all,
Thanks,
Wes.
Sure!
I use something like this:
// Device buffers allocation
CUDA_SAFE_CALL ( cudaMalloc ((void **) &dfpInRe, (samples * sizeof(float))) );
if (dfpInRe == NULL)
return 2;
CUDA_SAFE_CALL ( cudaMalloc ((void **) &dfpInIm, (samples * sizeof(float))) );
if (dfpInIm == NULL)
return 2;
// Data transfers
CUDA_SAFE_CALL (cudaMemcpy (dfpInRe, in_re, samples * sizeof(float), cudaMemcpyHostToDevice));
CUDA_SAFE_CALL (cudaMemcpy (dfpInIm, in_im, samples * sizeof(float), cudaMemcpyHostToDevice));
Fernando
By 2D array, you need to have an int with length x*y and index into that based on offsets/length. An int is actually an array of pointers to arrays of ints, so you won’t be able to copy that directly to the device.
Thanks for both replies. I did try to convert the int[i][j] into a int[k] and index it using somthings along the lines of k= (max_i)*i + j but when I tried to use it on the device I got a error telling me I couldn’t use (max_i)*i + j as an argument to my array.
I have a feeling that this was because the array was an argument to another array…
expv[ishf[(max_i)*i + j]]
I there a way around this???
Thansk again for the help,
Wes.
Hi, I’m not sure I’m following you…
Anyway, the code I posted works perfectly, and the arrays you see (in_re, in_im, dfpInRe and dfpInIm) are the Real and Imaginary parts of 2D complex arrays (of floats, but works just as fine with ints).
dfpInRe and dfpInIm are device arrays, in_re and in_im are host arrays.
I index the arrays with:
#define IDX(row, col, width) ((col) + ((row)*(width)))
so from C that I can easily access any (Col,Row) member with say
in_re[IDX(Row, Col, NCols)]
Fernando
That would be max_i*j + i
As to “now being able to use it as an argument”, post more code.
Thanks for the help, For future readers I indexed the 2D array as per this thread then allocated memory statically using device outside of main(); and copied my data to the devices global memory using copyToSymbol();
Thanks,
Wes.
