• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.0
• TensorRT Version
I have an application based on Deepstream 5.0 which is based on gstreamer to process RTSP streams, it ran into a core dump like below.
# gdb python3 core.6693
Core was generated by `python3 xxx.py'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007fc68453d70e in ?? () from /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
[Current thread is 1 (Thread 0x7fc4185b6700 (LWP 21274))]
(gdb) bt
#0 0x00007fc68453d70e in () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#1 0x00007fc68453f5ad in gst_buffer_pool_acquire_buffer () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#2 0x00007fc67e6c1f04 in gst_nvstreammux_chain ()
at /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so
#3 0x00007fc68457288b in () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#4 0x00007fc68457abb3 in gst_pad_push () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#5 0x00007fc684560aab in gst_proxy_pad_chain_default () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#6 0x00007fc68457288b in () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#7 0x00007fc68457abb3 in gst_pad_push () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#8 0x00007fc684560aab in gst_proxy_pad_chain_default () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#9 0x00007fc68457288b in () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#10 0x00007fc68457abb3 in gst_pad_push () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#11 0x00007fc684560aab in gst_proxy_pad_chain_default () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#12 0x00007fc68457288b in () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#13 0x00007fc68457abb3 in gst_pad_push () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#14 0x00007fc67c6ecf1a in () at /usr/lib/x86_64-linux-gnu/libgstvideo-1.0.so.0
#15 0x00007fc67c6f409b in gst_video_decoder_finish_frame () at /usr/lib/x86_64-linux-gnu/libgstvideo-1.0.so.0
#16 0x00007fc64396ecb6 in gst_v4l2_video_dec_loop ()
at /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so
#17 0x00007fc6845a7269 in () at /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#18 0x00007fc6863ffb40 in () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#19 0x00007fc6863ff175 in () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#20 0x00007fc687ab36db in start_thread () at /lib/x86_64-linux-gnu/libpthread.so.0
#21 0x00007fc687dec88f in clone () at /lib/x86_64-linux-gnu/libc.so.6
(gdb)
The code related to the nvstreammux object is shown below.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
streammux.set_property('live-source', 1)
streammux.set_property('width', 1280)
streammux.set_property('height', 720)
streammux.set_property('batch-size', number_sources) # the number of RTSP streams
streammux.set_property('batched-push-timeout', 40000) # 40ms
streammux.set_property("nvbuf-memory-type", int(pyds.NVBUF_MEM_CUDA_UNIFIED))
Can anyone please shed some light on this issue? What does this error indicate and how to avoid the core dump?
