Using pgf95 6.0-5 64-bit target on x86-64 Linux, I get a coredump in my program. The debugger only spits out:
Loaded: /home/t/fleur-bin/fleur_r_debug.x core.31420
Signalled SIGSEGV at 0x2A9633CDD6, function __hpf_dealloc
2A9633CDD6: 48 39 6F 8 cmpq %rbp,8(%rdi)
Any idea how to debug? (Compiled with -g -r8 -Mbounds.)
The problem is that the program crashes after about 90 minutes of number crunching, which makes debugging not really easier.
Tobias
PS: Side question: In how far is the pgi 6.0 compatible with pgi 6.1?
Reason is: I’d like to use the AMD Math Core Library 3.1 (compiled with 6.1 and available next week) and our admins have only 6.0 installed. (If it only works with 6.1, I need to push them to upgrade ;-)
Googling a bit around, I found something similar in forum post
That was with 6.0-4 (I have 6.0-5) and had the tracking number TPR #3551.
I tried that program with 6.0-5 and it still crashes. What is the current status about that issue?
I tried to run my program “fleur_r_debug.x” in pgdbg, but “where” does not give any further information after the crash.
However, “gdb” spits out more information (with “where”/“bt”):
#0 0x0000002a9633cdd6 in hpf_dealloc () from /opt/testing/pgi-6/linux86-64/6.0/libso/libpgf90.so #1 0x0000002a9633cf5c in pgf90_dealloc () from /opt/testing/pgi-6/linux86-64/6.0/libso/libpgf90.so #2 0x000000000068cc23 in m_tlmplm_tlmplm () at tlmplm.F:324 #3 0x00000000008a2c25 in m_eigen_eigen () at eigen.F:434 #4 0x0000000000926360 in fleur () at fleur.F:842 #5 0x00000000004031aa in main ()
The line 324 is “END SUBROUTINE tlmplm” and the file only contains only arrays passed as INTENT(IN)/INTENT(OUT) and local arrays with a size depending on the passed arguments. No explicit ALLOCATE/DEALLOCATE is present.
Something must have gone wrong with the automatic deallocation for the local arrays, I presume. But I have not idea how to (a) workaround this problem or (b) to investigate this problem.
How come that gdb supports the nice “where” whereas “pgdbg” does not?
TPR#3551 was fixed as of the 6.1-1 release. The problem was how the compiler was generating temporary arrays having a negative stride, which may or may not be the same as your error. Please either install the demo version of 6.1 (found here) or send a report to trs@pgroup.com.
pgdbg has a problem with the stacktrace from within code not compiled with “-g”. Our tools group is aware of the issue and should have it fixed later this year.
While not every major release has compatability issues, compatability problems are generally confined to pgf90 compiled code since optimizations may change how modules are constructed. We did also change the C++ STL between 5.2 and 6.0, but these types of major changes rarely occur. While I’m not 100% sure, I believe that ACML is built with pgf77 so should not have compatiability problems.
