can confirm what @mcardillo55 said. Same version, same configuration, and the same problem.
without NVreg_PreserveVideoMemoryAllocations the system hibernates successfully but after boot, the artifacts are so bad that you can’t even log in (2/3 of the text is missing, anything that moves is now all over the pace and jittering/flickering, )
Hi
my machine does not resume after suspend. It is happening since a couple of updates, some time ago.
My present setting is:
$ uname -a >>> Linux localhost.localdomain 5.18.5-100.fc35.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Jun 16 14:44:38 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
$ glxinfo | grep NVIDIA >>>
server glx vendor string: NVIDIA Corporation
client glx vendor string: NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce GTX 950/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 515.48.07
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL version string: 4.6.0 NVIDIA 515.48.07
OpenGL shading language version string: 4.60 NVIDIA
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 515.48.07
$ loginctl show-session 2 -p Type >>> Type=x11
$ lspci | grep -e VGA >>>
01:00.0 VGA compatible controller: NVIDIA Corporation GM206 [GeForce GTX 950] (rev a1)
$ cat /sys/power/resume >>> 0:0 (NOTE: briefly I had 253:1, I am not able to repeat)
$ sudo lsinitrd -m | grep -E '^resume$' >>> resume
$ systemctl status nvidia-suspend.service
○ nvidia-suspend.service - NVIDIA system suspend actions
Loaded: loaded (/usr/lib/systemd/system/nvidia-suspend.service; enabled; vendor preset: disabled)
Active: inactive (dead)
$ systemctl status nvidia-hibernate.service
○ nvidia-hibernate.service - NVIDIA system hibernate actions
Loaded: loaded (/usr/lib/systemd/system/nvidia-hibernate.service; enabled; vendor preset: disabled)
moreover: Gnome 41.6 (according to Settings), GNOME Shell 41.7 (according to Gnome Tweaks), GTK 3.24.34 (according to Gnome Tweaks)
Also, I do not know how to check/set NVreg_PreserveVideoMemoryAllocations=1 and TemporaryFilePath=/run, how do I do?
Also, I tried with nouveau drivers, but it was not better, so the issue is not a strictly NVIDIA issue.
Thanks so much for your help. Cheers
mario
I think I’m having the same issue but I’m getting slightly different errors in journalctl.
uname -a
Linux archlinux 5.18.5-zen1-1-zen #1 ZEN SMP PREEMPT_DYNAMIC Thu, 16 Jun 2022 20:40:47 +0000 x86_64 GNU/Linux
prime-run glxinfo | grep NVIDIA
OpenGL renderer string: NVIDIA GeForce RTX 3070 Laptop GPU/PCIe/SSE2
lspci -vvv -s 01:00.0
01:00.0 VGA compatible controller: NVIDIA Corporation GA104M [GeForce RTX 3070 Mobile / Max-Q] (rev a1) (prog-if 00 [VGA controller])
Subsystem: CLEVO/KAPOK Computer Device 65f1
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 147
IOMMU group: 16
Region 0: Memory at 81000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at 1200000000 (64-bit, prefetchable) [size=8G]
Region 3: Memory at 1400000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at 4000 [size=128]
Expansion ROM at 82000000 [virtual] [disabled] [size=512K]
Capabilities: <access denied>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
lspci -vvv -s 00:02.0
00:02.0 VGA compatible controller: Intel Corporation TigerLake-H GT1 [UHD Graphics] (rev 01) (prog-if 00 [VGA controller])
DeviceName: VGA compatible controller
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 183
IOMMU group: 2
Region 0: Memory at 83000000 (64-bit, non-prefetchable) [size=16M]
Region 2: Memory at 90000000 (64-bit, prefetchable) [size=256M]
Region 4: I/O ports at 1000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
* nvidia-suspend.service - NVIDIA system suspend actions
* nvidia-hibernate.service - NVIDIA system hibernate actions
Loaded: loaded (/usr/lib/systemd/system/nvidia-hibernate.service; disabled; vendor preset: disabled)
journalctl -b -1 -x --grep=nvidia
Jun 21 20:08:29 archlinux audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvidia-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 20:08:29 archlinux audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvidia-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 20:08:29 archlinux kernel: audit: type=1130 audit(1655860109.853:197): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvidia-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? te>
Jun 21 20:08:29 archlinux kernel: audit: type=1131 audit(1655860109.853:198): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvidia-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? te>
Jun 21 20:52:39 archlinux kernel: WARNING: CPU: 3 PID: 40329 at /var/lib/dkms/nvidia/515.48.07/build/kernel-open/nvidia/nv.c:3946 nv_restore_user_channels+0xc6/0xe0 [nvidia]
Jun 21 20:52:39 archlinux kernel: pmt_telemetry snd_hwdep 8250_dw mei_hdcp mei_pxp ee1004 mtd iTCO_vendor_support intel_rapl_msr pmt_class bluetooth kvm irqbypass cfg80211 snd_pcm r8169 videodev ttm snd_timer ec>
Jun 21 20:52:39 archlinux kernel: libps2 serio_raw vivaldi_fmap nvme nvme_core i2c_hid_acpi i8042 i2c_hid serio xhci_pci usbhid nvidia(OE) xhci_pci_renesas
Jun 21 20:52:39 archlinux kernel: CPU: 3 PID: 40329 Comm: nvidia-sleep.sh Tainted: G OE 5.18.5-zen1-1-zen #1 1b0f14670b06387fbfac0d7e749656f6285dc8ca
Jun 21 20:52:39 archlinux kernel: RIP: 0010:nv_restore_user_channels+0xc6/0xe0 [nvidia]
Jun 21 20:52:39 archlinux kernel: nv_set_system_power_state+0xec/0x500 [nvidia b3a44ffd1fc14e58c80e58536fb243556ffce5f9]
Jun 21 20:52:39 archlinux kernel: nv_procfs_write_suspend+0x1a9/0x280 [nvidia b3a44ffd1fc14e58c80e58536fb243556ffce5f9]
Jun 21 20:52:39 archlinux kernel: WARNING: CPU: 3 PID: 40329 at /var/lib/dkms/nvidia/515.48.07/build/kernel-open/nvidia/nv.c:4176 nv_set_system_power_state+0x363/0x500 [nvidia]
Jun 21 20:52:39 archlinux kernel: CPU: 3 PID: 40329 Comm: nvidia-sleep.sh Tainted: G W OE 5.18.5-zen1-1-zen #1 1b0f14670b06387fbfac0d7e749656f6285dc8ca
Jun 21 20:52:39 archlinux kernel: RIP: 0010:nv_set_system_power_state+0x363/0x500 [nvidia]
Jun 21 20:52:47 archlinux kernel: nvidia-modeset: ERROR: GPU:0: Failed to determine display capabilities
Jun 21 20:52:51 archlinux kernel: nvidia-modeset: ERROR: GPU:0: Failed to tear down Disp
Jun 21 20:52:59 archlinux kernel: nvidia-modeset: ERROR: GPU:0: Failed to determine display capabilities
Jun 21 20:53:03 archlinux kernel: nvidia-modeset: ERROR: GPU:0: Failed to tear down Disp
Jun 21 20:53:25 archlinux systemd[1]: Stopping NVIDIA Persistence Daemon...
-- Subject: A stop job for unit nvidia-persistenced.service has begun execution
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- A stop job for unit nvidia-persistenced.service has begun execution.
-- The job identifier is 2170.
Jun 21 20:54:29 archlinux kernel: nvidia-modeset: ERROR: GPU:0: Failed to determine display capabilities
Jun 21 20:54:43 archlinux kernel: nvidia-modeset: ERROR: GPU:0: Failed to tear down Disp
Jun 21 20:54:55 archlinux kernel: nvidia-modeset: ERROR: GPU:0: Failed to determine display capabilities
Jun 21 20:54:55 archlinux systemd[1]: nvidia-persistenced.service: Deactivated successfully.
-- Subject: Unit succeeded
-- The unit nvidia-persistenced.service has successfully entered the 'dead' state.
Jun 21 20:54:55 archlinux systemd[1]: Stopped NVIDIA Persistence Daemon.
-- Subject: A stop job for unit nvidia-persistenced.service has finished
-- A stop job for unit nvidia-persistenced.service has finished.
-- The job identifier is 2170 and the job result is done.
Jun 21 20:54:55 archlinux systemd[1]: nvidia-persistenced.service: Consumed 12.003s CPU time.
-- Subject: Resources consumed by unit runtime
-- The unit nvidia-persistenced.service completed and consumed the indicated resources.
Jun 21 20:54:55 archlinux audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvidia-persistenced comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 20:54:55 archlinux kernel: audit: type=1131 audit(1655862895.260:235): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvidia-persistenced comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr>
Jun 21 20:54:59 archlinux kernel: nvidia-modeset: ERROR: GPU:0: Failed to tear down Disp
