We encountered some issues for crosscompiling to jetson orin r35.1 (as well as r35.2),
The cross-aarch64 nvidia repository doesn’t seem to contains any package providing :
libnvinfer.so.8,
Installing the libnvinfer8 on the jetson host repository package is nether possible as it is conflicting with cross-compile ones -
/usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1
nvidia-l4t-cuda cannot be installed on non host target (preinst script check /proc/device-tree/compatible)
We do succed to crosscompile by :
- repackaging the libnvinfer8:arm64 package to libnvinfer8-cross-aarch64:amd64 with the following changes :
diff -u <(dpkg -I libnvinfer8_8.4.1-1+cuda11.4_arm64.deb) <(dpkg -I libnvinfer8-cross-aarch64_8.4.1-1+cuda11.4_amd64.deb)
--- /dev/fd/63 2023-03-28 15:23:20.061243686 +0200
+++ /dev/fd/62 2023-03-28 15:23:20.061243686 +0200
@@ -1,16 +1,16 @@
new Debian package, version 2.0.
- size 145034940 bytes: control archive=816 bytes.
- 474 bytes, 12 lines control
+ size 145040548 bytes: control archive=820 bytes.
+ 412 bytes, 12 lines control
400 bytes, 5 lines md5sums
67 bytes, 2 lines shlibs
73 bytes, 2 lines triggers
- Package: libnvinfer8
+ Package: libnvinfer8-cross-aarch64
Source: tensorrt
Version: 8.4.1-1+cuda11.4
- Architecture: arm64
+ Architecture: amd64
Maintainer: cudatools <cudatools@nvidia.com>
Installed-Size: 490082
- Depends: libcudnn8, libcublas.so.11 | libcublas-11-1 | libcublas-11-0, libnvrtc.so.11.2 | libnvrtc.so.11.3 | libnvrtc.so.11.4 | cuda-nvrtc-11-1 | cuda-nvrtc-11-0
+ Depends: libcudnn8:arm64, libcublas-cross-aarch64-11-4, cuda-nvrtc-cross-aarch64-11-4
Replaces: libnvinfer-doc (<< 8.4.1-1+cuda11.4)
Section: multiverse/libs
Priority: optional
- by repackaging nvidia-l4t-cuda:arm64, nvidia-l4t-core:arm64 and nvidia-l4t-3d-core:arm64 to **-cross-aarch64:amd64 with the following changes :
diff -u <(dpkg -I nvidia-l4t-cuda_35.1.0-20220825113828_arm64.deb) <(dpkg -I nvidia-l4t-cuda-cross-aarch64_35.1.0-20220825113828_amd64.deb)
--- /dev/fd/63 2023-03-28 17:35:56.441142466 +0200
+++ /dev/fd/62 2023-03-28 17:35:56.441142466 +0200
@@ -1,15 +1,15 @@
- size 4141402 bytes: control archive=10240 bytes.
- 371 bytes, 11 lines control
+ size 2326888 bytes: control archive=1620 bytes.
+ 433 bytes, 11 lines control LD}"
322 bytes, 4 lines md5sums tform, quit."
1787 bytes, 39 lines * postrm #!/bin/bash
- Package: nvidia-l4t-cuda
+ Package: nvidia-l4t-cuda-cross-aarch64 41,14 52%
Version: 35.1.0-20220825113828
Maintainer: NVIDIA Corporation
Installed-Size: 22790
- Pre-Depends: nvidia-l4t-core (>> 35.1-0), nvidia-l4t-core (<< 35.2-0)
- Depends: libc6, nvidia-l4t-3d-core (= 35.1.0-20220825113828)
+ Pre-Depends: nvidia-l4t-core-cross-aarch64 (>> 35.1-0), nvidia-l4t-core-cross-aarch64 (<< 35.2-0)
+ Depends: libc6:arm64
Section: libs
Priority: standard
Homepage: http://developer.nvidia.com/jetson
diff -u nvidia-l4t-core_35.1.0-20220825113828_arm64/DEBIAN/preinst nvidia-l4t-core-cross-aarch64_35.1.0-20220825113828_amd64/DEBIAN/preinst
--- nvidia-l4t-core_35.1.0-20220825113828_arm64/DEBIAN/preinst 2022-08-25 20:38:28.000000000 +0200
+++ nvidia-l4t-core-cross-aarch64_35.1.0-20220825113828_amd64/DEBIAN/preinst 2023-03-28 16:46:28.993180217 +0200
@@ -38,7 +38,7 @@
# Check platform compatibility
compatible="yes"
-CHIP="$(tr '\0' ' ' < /proc/device-tree/compatible)"
+CHIP="tegra194"
if [[ ${CHIP} =~ "tegra194" ]]; then
if [ "${BUILD}" != "t186ref" ]; then
compatible="no"
diff -u <(dpkg -I nvidia-l4t-core_35.1.0-20220825113828_arm64.deb) <(dpkg -I nvidia-l4t-core-cross-aarch64_35.1.0-20220825113828_amd64.deb)
--- /dev/fd/63 2023-03-28 15:33:58.629235562 +0200
+++ /dev/fd/62 2023-03-28 15:33:58.633235562 +0200
@@ -1,18 +1,18 @@
- size 3812510 bytes: control archive=20480 bytes.
+ size 2573940 bytes: control archive=3720 bytes.
92 bytes, 3 lines conffiles
- 363 bytes, 12 lines control
+ 419 bytes, 12 lines control
4391 bytes, 53 lines md5sums
2791 bytes, 78 lines * preinst #!/bin/bash
- Package: nvidia-l4t-core
+ Package: nvidia-l4t-core-cross-aarch64
Installed-Size: 10422
- Depends: libc6, libegl1, libexpat1, libgcc1, libstdc++6
- Conflicts: nvidia-l4t-ccp-t186ref
- Replaces: nvidia-l4t-ccp-t186ref
+ Depends: libc6:arm64, libegl1:arm64, libexpat1:arm64, libgcc1:arm64, libstdc++6:arm64
+ Conflicts: nvidia-l4t-ccp-t186ref:arm64
+ Replaces: nvidia-l4t-ccp-t186ref:arm64
Section: libs
Priority: standard
diff -u <(dpkg -I nvidia-l4t-3d-core_35.1.0-20220825113828_arm64.deb) <(dpkg -I nvidia-l4t-3d-core-cross-aarch64_35.1.0-20220825113828_amd64.deb)
--- /dev/fd/63 2023-03-28 16:18:27.149201614 +0200
+++ /dev/fd/62 2023-03-28 16:18:27.149201614 +0200
@@ -1,16 +1,16 @@
- size 65501106 bytes: control archive=20480 bytes.
- 611 bytes, 11 lines control
+ size 45204980 bytes: control archive=2528 bytes.
+ 719 bytes, 11 lines control
2063 bytes, 23 lines md5sums
1820 bytes, 35 lines * postinst #!/bin/bash
- Package: nvidia-l4t-3d-core
+ Package: nvidia-l4t-3d-core-cross-aarch64
Installed-Size: 160854
- Depends: libc6, libegl1, libgcc1, libstdc++6, libx11-6, libxext6, nvidia-l4t-firmware (= 35.1.0-20220825113828), nvidia-l4t-init (= 35.1.0-20220825113828), nvidia-l4t-libvulkan (= 35.1.0-20220825113828), nvidia-l4t-wayland (= 35.1.0-20220825113828), nvidia-l4t-x11 (= 35.1.0-20220825113828)
+ Depends: libc6:arm64, libegl1:arm64, libgcc1:arm64, libstdc++6:arm64, libx11-6:arm64, libxext6:arm64, nvidia-l4t-firmware:arm64 (= 35.1.0-20220825113828), nvidia-l4t-init:arm64 (= 35.1.0-20220825113828), nvidia-l4t-libvulkan:arm64 (= 35.1.0-20220825113828), nvidia-l4t-wayland:arm64 (= 35.1.0-20220825113828), nvidia-l4t-x11:arm64 (= 35.1.0-20220825113828)
Section: graphics
Priority: standard
Moreover, both cuda-cudart-11-4 and cuda-cudart-cross-aarch64-11-4 are present on the repository without any Breaks,Conflicts, Replace clause (They do conflict on each other)
Finally, their is no symlink /usr/local/cuda-11.4/targets/aarch64-linux/lib/stubs/libcudla.so{,.1} on package
Are we missing something ?
Thank you !
