Could not select device driver "" with capabilities: [[gpu]]
• SO Ubuntu 22.04
• Hardware Platform (Jetson / GPU) RTX A4000
• DeepStream Version 6.2
• nvidia-smi
| NVIDIA-SMI 535.54.03 Driver Version: 535.54.03 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX A4000 Off | 00000000:01:00.0 On | Off |
| 41% 40C P8 11W / 140W | 177MiB / 16376MiB | 8% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1257 G /usr/lib/xorg/Xorg 90MiB |
| 0 N/A N/A 1543 G /usr/bin/gnome-shell 79MiB |
I successfully made a docker pull from nvcr.io/nvidia/deepstream:6.2-devel and I am trying to run a simple hello world from GitHub - NVIDIA-AI-IOT/deepstream_python_apps: DeepStream SDK Python bindings and sample applications.
I have done it several times im a Jetson, but this is the first time on a ordinary host with GPU board and docker. How do I override the following error?
user@user-Default-string:~/test$ sudo docker run -it --gpus all -v /home/user/test:/test nvcr.io/nvidia/deepstream:6.2-devel python3 deepstream_test_1.py /home/user/test/sample/sample_1080p_h264.mp4
docker: Error response from daemon: could not select device driver "" with capabilities: [[gpu]].
ERRO[0000] error waiting for container: context canceled
It looks like docker is missing some components
Can you try the following command?
sudo apt-get update
sudo apt-get install -y nvidia-container-toolkit
sudo systemctl restart docker
Here is same error as yours
Don’t know why, but I had to add an nvidia-ctk to your tip, and then worked fine.
sudo apt-get update
sudo nvidia-ctk runtime configure --runtime=docker
