Run docker (
I have an error when I run this…
$ sudo docker run --gpus all -it --rm  -p9002:8888  -v /home/username/:/projects -w /projects determinedai/environments:cuda-10.2-pytorch-1.7-tf-1.15-gpu-0.17.0 bash
docker: Error response from daemon: could not select device driver "" with capabilities: [[gpu]].
Here is what I have…
$ lspci | grep -i nvidia
03:00.0 3D controller: NVIDIA Corporation Device 1fb7 (rev a1)
$ nvidia-smi
Tue Feb 28 14:56:17 2023
| NVIDIA-SMI 525.78.01    Driver Version: 525.78.01    CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA T550 Lap...  Off  | 00000000:03:00.0 Off |                  N/A |
| N/A   41C    P8     3W /  30W |      6MiB /  4096MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      2260      G   /usr/lib/xorg/Xorg                  4MiB |
|    0   N/A  N/A      2483      G   ...ome-remote-desktop-daemon        1MiB |
