Couldn't communicate with the NVIDIA driver
I started using azure nvidia-gpu-optimized-vmi-a10 vm
But there are no nvidia drivers in that VM and I am unable to install them also
Here are some commands and there outputs which can help in debugging the problem
Command : nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Command : sudo apt install nvidia-driver-495
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package nvidia-driver-495 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
**E:** Package 'nvidia-driver-495' has no installation candidate
Command : sudo apt install nvidia-495
E: Unable to locate package nvidia-495
and for lspci command I am not getting any output
Some of the commands I tried
sudo add-apt-repository ppa:graphics-drivers/pp
sudo apt update
output for uname -a
Linux sanath 5.15.0-1020-azure #25~20.04.1-Ubuntu SMP Thu Sep 1 19:20:56 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
It’s a vGPU VM, meaning you can’t use the normal graphics driver but have to use the GRID driver instead. to install, use
https://learn.microsoft.com/en-us/azure/virtual-machines/extensions/hpccompute-gpu-linux
or download and install manually
https://learn.microsoft.com/en-us/azure/virtual-machines/linux/n-series-driver-setup
https://github.com/Azure/azhpc-extensions/blob/master/NvidiaGPU/resources.json
I have added extension as there in the below link and I rebooted VM also still nothing changed @generix
Did you uninstall the repo driver beforehand?
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
you mean ppa:graphic-drivers/ppa repo ?
between attaching the file
nvidia-bug-report.log.gz (32.3 KB)
That looks like a very basic vm without any gpu.
This is the image I have choosed for this vm
Then something went awry on creating it, it’s a simple vm with two xeon cores, 4GB RAM, 8GB SSD and no supplemental devices. Please check sudo lspci to see.
Just delete it try to properly recreate it.
no output for sudo lspci command
I recreated VM
still I think nothing changed
here is the report
nvidia-bug-report.log.gz (32.2 KB)
More info : (This is message I get after opening vm terminal through ssh)
Welcome to the NVIDIA GPU Cloud image. This image provides an optimized
environment for running the deep learning and HPC containers from the
NVIDIA GPU Cloud Container Registry. Many NGC containers are freely
available. However, some NGC containers require that you log in with
a valid NGC API key in order to access them. This is indicated by a
“pull access denied for xyz …” or “Get xyz: unauthorized: …” error
message from the daemon.
Documentation on using this image and accessing the NVIDIA GPU Cloud
Container Registry can be found at
NGC Documentation
Last login: Sun Oct 2 17:05:18 2022 from 49.37.156.151
Warning: Unsupported instance type for NVIDIA GPU Cloud Machine Image.
Please use an ND, NCv2, or NCv3 instance for optimal performance and reliability.
please give suggestion @generix ?
You only reapplied the OS image, but didn’t change the azure instance as it seems. You need to create the correct VM instance first
https://learn.microsoft.com/en-us/azure/virtual-machines/sizes-gpu
I had the exact same problem, turns out it’s the wrong VM.
I used the Nvidia-GPU-Optimized-VM, and I also installed the Nvidia-GPU-Driver extension on the Azure portal, BUT I still got the same error.
Then I used ‘sudo lspci -v | less’ to check the GPU, turns out it’s still a fu*king AMD driver because I was using [NVv4-series] sizes.
You need to use [NCv3-series] and [NC T4_v3-series] to be able to use Nvidia GPU. Reference: (https://learn.microsoft.com/en-us/azure/virtual-machines/sizes-gpu?toc=%2Fazure%2Fvirtual-machines%2Flinux%2Ftoc.json)
Probably I am wrong because I am a new user of Azure, but Azure is so fu*king confusing.
