I just found that one can read the counters per port per interface at the following locations:
/sys/class/infiniband/mlx4_X/ports//counters/
/sys/class/infiniband/mlx4_X/ports//counters_ext/
Is there any way to get counters for specific virtual functions when using SRIOV
Vangelis
Hi Ophir,
Is there a solution for this? Im also getting the same error with respect to IB VFs within a VM.
Adit
eranbe
3
Hi Adit,
A fix for this issue was intoroduced in mlnx ofed 3.1-1.0.0 and it is also available in upstream kernel since 4.3.
Eran.
ophirm
4
Let me check that for you.
Ophir.
ophirm
5
Hi Vangelis,
You can view the VF counters via the ethtool when connected to the VM.
Refer to this post as well.
Counters Troubleshooting for Linux Driver https://community.mellanox.com/s/article/counters-troubleshooting-for-linux-driver
Thanks,
Ophir.
Is it possible to view the VF counters for IB? Looks like it is not possible to get this information currently.
In the following example mlx4_0 is the PF and mlx4_1 and mlx4_2 are two probed VFs.
cat /sys/class/infiniband/mlx4_0/ports/1/counters/port_xmit_data
16199496
cat /sys/class/infiniband/mlx4_1/ports/1/counters/port_xmit_data
cat: /sys/class/infiniband/mlx4_1/ports/1/counters/port_xmit_data: Invalid argument
cat /sys/class/infiniband/mlx4_2/ports/1/counters/port_xmit_data
cat: /sys/class/infiniband/mlx4_2/ports/1/counters/port_xmit_data: Invalid argument
