CPU attestation failure in AMD SEV SNP CVM + H100
Hello, I was trying to perform CPU and GPU attestation in a CVM on an AMD host with H100 GPU.
I’m unable to perform a CPU attestation in the CVM using the attest binary. The error I get is as follows , I’m not sure what device is not working here:
user@hccvm:~$ sudo ./attest
[sudo] password for user:
Failed to open firmware device and get an attestation report; are you running in a CVM?
Error was FirmwareError(IoError(Os { code: 2, kind: NotFound, message: "No such file or directory" }))
user@hccvm:~$ nvidia-smi
Wed Jan 17 13:36:03 2024
| NVIDIA-SMI 535.104.05             Driver Version: 535.104.05   CUDA Version: 12.2     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  NVIDIA H100 PCIe               On  | 00000000:01:00.0 Off |                    0 |
| N/A   29C    P0              47W / 350W |      0MiB / 81559MiB |      0%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|  No running processes found                                                           |
user@hccvm:~$
user@hccvm:~$ sudo nvidia-smi conf-compute -f
CC status: ON
user@hccvm:~$
user@hccvm:~$ sudo dmesg | grep SEV | head
[    1.061846] Memory Encryption Features active: AMD SEV SEV-ES SEV-SNP
[    1.246441] SEV: Using SNP CPUID table, 31 entries present.
[    6.636358] SEV: SNP guest platform device initialized.
user@hccvm:~$ grep -w sev /proc/cpuinfo
user@hccvm:~$
I was however able to successfully attest the GPU:
(nvAttest) user@hccvm:~/nvtrust/guest_tools/attestation_sdk$ python3
Python 3.10.12 (main, Nov 20 2023, 15:14:05) [GCC 11.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> from nv_attestation_sdk import attestation
>>> client = attestation.Attestation("test_node")
>>> client.add_verifier(attestation.Devices.GPU, attestation.Environment.LOCAL, "",   "")
>>> attestation_results_policy = '{"version":"1.0","authorization-rules":{"x-nv-gpu-available":true,' \
... '"x-nv-gpu-attestation-report-available":true,"x-nv-gpu-info-fetched":true,' \
... '"x-nv-gpu-arch-check":true,"x-nv-gpu-root-cert-available":true,' \
... '"x-nv-gpu-cert-chain-verified":true,"x-nv-gpu-ocsp-cert-chain-verified":true,' \
... '"x-nv-gpu-ocsp-signature-verified":true,"x-nv-gpu-cert-ocsp-nonce-match":true,' \
... '"x-nv-gpu-cert-check-complete":true,"x-nv-gpu-measurement-available":true,' \
... '"x-nv-gpu-attestation-report-parsed":true,"x-nv-gpu-nonce-match":true,' \
... '"x-nv-gpu-attestation-report-driver-version-match":true,' \
... '"x-nv-gpu-attestation-report-vbios-version-match":true,' \
... '"x-nv-gpu-attestation-report-verified":true,"x-nv-gpu-driver-rim-schema-fetched":true,' \
... '"x-nv-gpu-driver-rim-schema-validated":true,"x-nv-gpu-driver-rim-cert-extracted":true,' \
... '"x-nv-gpu-driver-rim-signature-verified":true,' \
... '"x-nv-gpu-driver-rim-driver-measurements-available":true,' \
... '"x-nv-gpu-driver-vbios-rim-fetched":true,"x-nv-gpu-vbios-rim-schema-validated":true,' \
... '"x-nv-gpu-vbios-rim-cert-extracted":true,"x-nv-gpu-vbios-rim-signature-verified":true,' \
... '"x-nv-gpu-vbios-rim-driver-measurements-available":true,' \
... '"x-nv-gpu-vbios-index-conflict":true,"x-nv-gpu-measurements-match":true}}'
>>> client.attest()
Number of GPUs available : 1
Fetching GPU 0 information from GPU driver.
Using the Nonce specified by user
VERIFYING GPU : 0
        Driver version fetched : 535.104.05
        VBIOS version fetched : 96.00.74.00.1a
        Validating GPU certificate chains.
                GPU attestation report certificate chain validation successful.
                        The certificate chain revocation status verification successful.
        Authenticating attestation report
                The nonce in the SPDM GET MEASUREMENT request message is matching with the generated nonce.
                Driver version fetched from the attestation report : 535.104.05
                VBIOS version fetched from the attestation report : 96.00.74.00.1a
                Attestation report signature verification successful.
                Attestation report verification successful.
        Authenticating the RIMs.
                Authenticating Driver RIM
                        Fetching the driver RIM from the RIM service.
                        RIM Schema validation passed.
                        driver RIM certificate chain verification successful.
                        driver RIM signature verification successful.
                        Driver RIM verification successful
                Authenticating VBIOS RIM.
                        Fetching the VBIOS RIM from the RIM service.
                        vbios RIM certificate chain verification successful.
                        vbios RIM signature verification successful.
                        VBIOS RIM verification successful
        Comparing measurements (runtime vs golden)
                        The runtime measurements are matching with the golden measurements.
                GPU is in expected state.
        GPU 0 verified successfully.
        GPU Attested Successfully
True
>>> client.validate_token(attestation_results_policy)
        [ERROR] Invalid token. Authorized claims does not match the appraisal policy:  x-nv-gpu-vbios-index-conflict
False
Any idea what is going wrong here?
Can you utilize the RemoteGPUTest.py
rather than the code you used? It appears this code is leveraging the local verifier (normally utilized in airgapped scenarios). These instructions will be updated.
By airgapped scenarios, you mean without an ssh connection?
I ran the RemoteGPUTest.py, and I got a successful result.
Any idea why is the CPU attestation failing in the CVM?
Correct.
We don’t directly support CPU attestation. The application you’re using was provided by one of our engineers as a courtesy. I’ll reach to him to see what we can do to get it reenabled in your CVM
The issue wasn’t with the cpu attestation binary provided to us. It was that the /dev/snp-guest device was not found:
user@hccvm:~$
I was able to resolve this by manually inserting the kernel module needed before performing any kind of cpu attestation:
nvidia@hccvm:~$ sudo modprobe sev-guest
[sudo] password for nvidia:
nvidia@hccvm:~$ echo $?
0
nvidia@hccvm:~$
nvidia@hccvm:~$ sudo ./attest
Report data matches supplied data
Report signature verification succeeded
nvidia@hccvm:~$
