Hi
Currently I am working on an embedded project using Orin NX 16G, Jetpack5.1.2.
I have fixed cpu frequency in /etc/rc.local like this
echo 1 > /sys/devices/system/cpu/cpu0/online
echo 1 > /sys/devices/system/cpu/cpu1/online
echo 1 > /sys/devices/system/cpu/cpu2/online
echo 1 > /sys/devices/system/cpu/cpu3/online
echo 1 > /sys/devices/system/cpu/cpu4/online
echo 1 > /sys/devices/system/cpu/cpu5/online
echo 1 > /sys/devices/system/cpu/cpu6/online
echo 1 > /sys/devices/system/cpu/cpu7/online
sleep 2
echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu5/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu6/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu7/cpufreq/scaling_governor
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
sleep 1
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
During Kernel startup I am seeing some error messages related to CPU clock frequencies like,
Mar 15 23:04:18 Linux kernel: [ 7.614531] OF: /i2c@3180000/max96712@4b: could not get #gpio-cells for /iommu@12000000
Mar 15 23:04:18 Linux kernel: [ 7.634645] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
**Mar 15 23:04:18 Linux kernel: [ 7.657233] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2006000 KHz, changing to: 1984000 KHz**
**Mar 15 23:04:18 Linux kernel: [ 7.670155] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2034000 KHz, changing to: 1984000 KHz**
Mar 15 23:04:18 Linux kernel: [ 7.681968] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
Mar 15 23:04:18 Linux kernel: [ 7.689017] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
Mar 15 23:04:18 Linux kernel: [ 7.696367] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
Mar 15 23:04:18 Linux kernel: [ 7.703542] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
Mar 15 23:04:18 Linux kernel: [ 7.712227] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
Mar 15 23:04:18 Linux kernel: [ 7.720908] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
After startup, some times I also see lot of messges like
Mar 15 23:04:24 Linux kernel: [ 19.548164] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:42 PDT 2023
Mar 15 23:04:24 Linux kernel: [ 20.430941] NVRM nvAssertFailedNoLog: Assertion failed: minRequiredIsoBandwidthKBPS <= clientBwValues[DISPLAY_ICC_BW_CLIENT_EXT].minRequiredIsoBandwidthKBPS @ kern_disp_0402.c:111
Mar 15 23:04:24 Linux kernel: [ 20.430952] CPU: 6 PID: 735 Comm: kworker/u16:4 Tainted: G OE 5.10.120-tegra #2
Mar 15 23:04:24 Linux kernel: [ 20.430954] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 4.1-33958178 08/01/2023
Mar 15 23:04:24 Linux kernel: [ 20.430965] Workqueue: dce-async-ipc-wq dce_client_async_event_work
Mar 15 23:04:24 Linux kernel: [ 20.430969] Call trace:
Mar 15 23:04:24 Linux kernel: [ 20.430975] dump_backtrace+0x0/0x1d0
Mar 15 23:04:24 Linux kernel: [ 20.430978] show_stack+0x30/0x40
Mar 15 23:04:24 Linux kernel: [ 20.430983] dump_stack+0xd8/0x138
Mar 15 23:04:24 Linux kernel: [ 20.431031] os_dump_stack+0x18/0x20 [nvidia]
Mar 15 23:04:24 Linux kernel: [ 20.431072] tlsEntryGet+0x130/0x138 [nvidia]
Mar 15 23:04:24 Linux kernel: [ 20.431110] kdispArbAndAllocDisplayBandwidth_v04_02+0x274/0x288 [nvidia]
Mar 15 23:04:24 Linux kernel: [ 20.431148] kdispInvokeDisplayModesetCallback_KERNEL+0xa8/0xf0 [nvidia]
Mar 15 23:04:24 Linux kernel: [ 20.431186] dceclientHandleAsyncRpcCallback+0x17c/0x2f0 [nvidia]
Mar 15 23:04:24 Linux kernel: [ 20.431223] initVGXSpecificRegistry+0x1dc/0x300 [nvidia]
Mar 15 23:04:24 Linux kernel: [ 20.431226] dce_client_async_event_work+0x8c/0x190
Mar 15 23:04:24 Linux kernel: [ 20.431230] process_one_work+0x1c4/0x4a0
Mar 15 23:04:24 Linux kernel: [ 20.431231] worker_thread+0x54/0x430
Mar 15 23:04:24 Linux kernel: [ 20.431233] kthread+0x148/0x170
Mar 15 23:04:24 Linux kernel: [ 20.431235] ret_from_fork+0x10/0x24
Mar 15 23:04:25 Linux kernel: [ 21.227614] cpufreq: cpu4,cur:2100000,set:1984000,set ndiv:155
Mar 15 23:04:35 Linux kernel: [ 31.330780] cpufreq: cpu4,cur:2108000,set:1984000,set ndiv:155
Mar 15 23:04:36 Linux kernel: [ 32.341998] cpufreq: cpu4,cur:1863000,set:1984000,set ndiv:155
Mar 15 23:04:40 Linux kernel: [ 36.363943] cpufreq: cpu4,cur:2168000,set:1984000,set ndiv:155
Mar 15 23:04:43 Linux kernel: [ 39.395505] cpufreq: cpu4,cur:1852000,set:1984000,set ndiv:155
Mar 15 23:04:57 Linux kernel: [ 52.535213] cpufreq: cpu4,cur:2150000,set:1984000,set ndiv:155
Mar 15 23:04:58 Linux kernel: [ 53.546040] cpufreq: cpu4,cur:2139000,set:1984000,set ndiv:155
Mar 15 23:05:00 Linux kernel: [ 55.566251] cpufreq: cpu4,cur:2128000,set:1984000,set ndiv:155
Mar 15 23:05:02 Linux kernel: [ 57.577291] cpufreq: cpu4,cur:2117000,set:1984000,set ndiv:155
Mar 15 23:05:10 Linux kernel: [ 65.665224] cpufreq: cpu4,cur:1861000,set:1984000,set ndiv:155
Mar 15 23:05:15 Linux kernel: [ 70.715422] cpufreq: cpu4,cur:2211000,set:1984000,set ndiv:155
Mar 15 23:05:17 Linux kernel: [ 72.739699] cpufreq: cpu4,cur:1762000,set:1984000,set ndiv:155
Mar 15 23:05:18 Linux kernel: [ 73.750529] cpufreq: cpu4,cur:1861000,set:1984000,set ndiv:155
Mar 15 23:05:19 Linux kernel: [ 74.765947] cpufreq: cpu4,cur:2102000,set:1984000,set ndiv:155
Mar 15 23:05:24 Linux kernel: [ 79.827418] cpufreq: cpu4,cur:1861000,set:1984000,set ndiv:155
Mar 15 23:05:26 Linux kernel: [ 81.854053] cpufreq: cpu4,cur:2108000,set:1984000,set ndiv:155
Mar 15 23:05:29 Linux kernel: [ 84.890205] cpufreq: cpu4,cur:1836000,set:1984000,set ndiv:155
Mar 15 23:05:30 Linux kernel: [ 85.903129] cpufreq: cpu4,cur:2108000,set:1984000,set ndiv:155
Mar 15 23:05:30 Linux kernel: [ 85.903651] cpufreq: cpu4,cur:2127000,set:1984000,set ndiv:155
Mar 15 23:05:32 Linux kernel: [ 87.929634] cpufreq: cpu4,cur:2103000,set:1984000,set ndiv:155
Mar 15 23:05:32 Linux kernel: [ 87.930156] cpufreq: cpu4,cur:2172000,set:1984000,set ndiv:155
Mar 15 23:05:32 Linux kernel: [ 87.931206] cpufreq: cpu4,cur:2156000,set:1984000,set ndiv:155
Mar 15 23:05:33 Linux kernel: [ 88.943606] cpufreq: cpu4,cur:2101000,set:1984000,set ndiv:155
Mar 15 23:05:34 Linux kernel: [ 89.953780] cpufreq: cpu4,cur:1854000,set:1984000,set ndiv:155
Mar 15 23:05:34 Linux kernel: [ 89.954300] cpufreq: cpu4,cur:2148000,set:1984000,set ndiv:155
Mar 15 23:05:36 Linux kernel: [ 91.979365] cpufreq: cpu0,cur:2173000,set:1984000,set ndiv:155
Mar 15 23:05:37 Linux kernel: [ 92.994909] cpufreq: cpu4,cur:2219000,set:1984000,set ndiv:155
Mar 15 23:05:38 Linux kernel: [ 94.001415] cpufreq: cpu0,cur:2170000,set:1984000,set ndiv:155
Mar 15 23:05:38 Linux kernel: [ 94.001939] cpufreq: cpu0,cur:1803000,set:1984000,set ndiv:155
On seeing this I have a feeling that the cpu clock frequency might not right - as lot of application problem rising.
Any suggestions on how to fix this problem. Please note that only one board have this problem, others running OK.
