Running tegrastats causes cpufreq fluctuations
I run jetson_clocks, so I expect CPUs to run at constant, max frequencies:
root@orin:~# jetson_clocks --show
SOC family:tegra234  Machine:Jetson AGX Orin
Online CPUs: 0-11
cpu0: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu1: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu10: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu11: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu2: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu3: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu4: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu5: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu6: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu7: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu8: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu9: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
GPU MinFreq=1300500000 MaxFreq=1300500000 CurrentFreq=1300500000
EMC MinFreq=204000000 MaxFreq=3199000000 CurrentFreq=3199000000 FreqOverride=1
DLA0_CORE:   Online=1 MinFreq=0 MaxFreq=1600000000 CurrentFreq=1600000000
DLA0_FALCON: Online=1 MinFreq=0 MaxFreq=844800000 CurrentFreq=844800000
DLA1_CORE:   Online=1 MinFreq=0 MaxFreq=1600000000 CurrentFreq=1600000000
DLA1_FALCON: Online=1 MinFreq=0 MaxFreq=844800000 CurrentFreq=844800000
PVA0_VPS0: Online=1 MinFreq=0 MaxFreq=1152000000 CurrentFreq=1152000000
PVA0_AXI:  Online=1 MinFreq=0 MaxFreq=832000000 CurrentFreq=832000000
FAN Dynamic Speed control=active hwmon2_pwm1=55
NV Power Mode: MAXN
root@orin:~#
However when I start tegrastats CPU frequencies start to fluctuate:
[ 5479.946808] cpufreq: cpu8,cur:2048000,set:2201600,set ndiv:172
[ 5480.967462] cpufreq: cpu0,cur:2002000,set:2201600,set ndiv:172
[ 5480.968117] cpufreq: cpu0,cur:2331000,set:2201600,set ndiv:172
[ 5481.996510] cpufreq: cpu8,cur:2485000,set:2201600,set ndiv:172
[ 5488.136842] cpufreq: cpu4,cur:2369000,set:2201600,set ndiv:172
[ 5490.182221] cpufreq: cpu0,cur:2390000,set:2201600,set ndiv:172
[ 5490.182872] cpufreq: cpu0,cur:2079000,set:2201600,set ndiv:172
[ 5490.186153] cpufreq: cpu8,cur:2380000,set:2201600,set ndiv:172
[ 5891.527045] cpufreq: cpu4,cur:2056000,set:2201600,set ndiv:172
[ 5893.570458] cpufreq: cpu0,cur:2059000,set:2201600,set ndiv:172
[ 5893.575829] cpufreq: cpu8,cur:2317000,set:2201600,set ndiv:172
[ 5895.618455] cpufreq: cpu0,cur:2348000,set:2201600,set ndiv:172
[ 5896.645144] cpufreq: cpu4,cur:2358000,set:2201600,set ndiv:172
[ 5902.791372] cpufreq: cpu8,cur:2329000,set:2201600,set ndiv:172
[ 5905.858457] cpufreq: cpu0,cur:2398000,set:2201600,set ndiv:172
[ 5905.861206] cpufreq: cpu4,cur:2048000,set:2201600,set ndiv:172
[ 6304.826290] cpufreq: cpu4,cur:2317000,set:2201600,set ndiv:172
It stops when I kill tegrastats.
We will check this. For information, do you observe it on Jetpack 5.1.1?
All Jetpack 5 versions, including 5.1.1
I can trigger these “cpufreq” kernel messages just by doing, for example:
watch -n 0.1 "cat /sys/devices/system/cpu/cpufreq/policy8/cpuinfo_cur_freq"
Is there any update here? What’s interesting is in some of the output such as:
cpufreq: cpu8,cur:2390000,set:2201600,set ndiv:172
the cur:2390000 is actually greater than /sys/devices/system/cpu/cpufreq/policy8/cpuinfo_max_freq, which is 2201600
