In a complex java application that mix opencl 1.1 and opengl 4 running on RHEL 6u5 - 64 bits,
I’ve experiment a crash in the driver version 384.98 and 375.20 with a GTX 970 or GTX 750 cards
I’ve no problem with 352.55
(with driver 384.98)
The problem is in libGLX_nvidia.so.0 at address 0xbe726
with objdump -S
be71e: 00
be71f: 0f 95 c2 setne %dl
be722: 84 d2 test %dl,%dl
be724: 75 ea jne be710 <vk_icdGetInstanceProcAddr+0x13930>
be726: 49 8b 84 24 68 09 00 mov 0x968(%r12),%rax
be72d: 00
The gdb stack trace is :
#0 0x0000003aed432925 in raise () from /lib64/libc.so.6
#1 0x0000003aed434105 in abort () from /lib64/libc.so.6
#2 0x00007fb63f44f605 in os::abort(bool) () from /mw/MW_jre_1.8.0_92/lib/amd64/server/libjvm.so
#3 0x00007fb63f5eea63 in VMError::report_and_die() () from /mw/MW_jre_1.8.0_92/lib/amd64/server/libjvm.so
#4 0x00007fb63f454e2f in JVM_handle_linux_signal () from /mw/MW_jre_1.8.0_92/lib/amd64/server/libjvm.so
#5 0x00007fb63f44b5c3 in signalHandler(int, siginfo*, void*) () from /mw/MW_jre_1.8.0_92/lib/amd64/server/libjvm.so
#6
#7 0x00007fb6118d0726 in ?? () from /usr/lib64/libGLX_nvidia.so.0
#8 0x00007fb611869249 in ?? () from /usr/lib64/libGLX_nvidia.so.0
#9 0x00007fb60b23a4cf in ?? () from /usr/lib64/libnvidia-glcore.so.384.98
#10 0x00007fb60b23a8e0 in ?? () from /usr/lib64/libnvidia-glcore.so.384.98
#11 0x00007fb60b27d860 in ?? () from /usr/lib64/libnvidia-glcore.so.384.98
#12 0x00007fb60b238389 in ?? () from /usr/lib64/libnvidia-glcore.so.384.98
#13 0x00007fb6009b125e in ?? () from /usr/lib64/libnvidia-opencl.so.1
#14 0x00007fb6008bf291 in ?? () from /usr/lib64/libnvidia-opencl.so.1
#15 0x00007fb6008a3905 in ?? () from /usr/lib64/libnvidia-opencl.so.1
#16 0x00007fb6008a3ce7 in ?? () from /usr/lib64/libnvidia-opencl.so.1
#17 0x00007fb6008c517d in ?? () from /usr/lib64/libnvidia-opencl.so.1
#18 0x00007fb6008c628e in ?? () from /usr/lib64/libnvidia-opencl.so.1
#19 0x00007fb6008c6df0 in ?? () from /usr/lib64/libnvidia-opencl.so.1
#20 0x00007fb6009dfe18 in ?? () from /usr/lib64/libnvidia-opencl.so.1
#21 0x0000003aed8079d1 in start_thread () from /lib64/libpthread.so.0
#22 0x0000003aed4e8b6d in clone () from /lib64/libc.so.6
Thanks for whatever support you are able to provide.
