EDIT: It’s actually the 387.34 driver, but the previous driver had the same problem.
$ inxi -bxx
System: Host: ronin Kernel: 4.14.0-12.1-liquorix-amd64 x86_64 bits: 64 gcc: 7.2.0
Desktop: Xfce 4.12.4 (Gtk 2.24.31) dm: lightdm Distro: Debian GNU/Linux buster/sid
Machine: Device: desktop Mobo: ASUSTeK model: ROG STRIX B350-F GAMING v: Rev X.0x serial: N/A
UEFI [Legacy]: American Megatrends v: 3401 date: 12/04/2017
CPU: Quad core AMD Ryzen 5 1500X (-HT-MCP-) arch: Zen rev.1 speed/max: 1550/3500 MHz
Graphics: Card: NVIDIA GK208 [GeForce GT 730] bus-ID: 08:00.0 chip-ID: 10de:1287
Display Server: x11 (X.Org 1.19.5 ) driver: nouveau Resolution: 1280x1024@60.02hz
OpenGL: renderer: NV106 version: 4.3 Mesa 17.3.1 (compat-v: 3.0) Direct Render: Yes
Network: Card: Intel I211 Gigabit Network Connection
driver: igb v: 5.4.0-k port: e000 bus-ID: 03:00.0 chip-ID: 8086:1539
Drives: HDD Total Size: 370.1GB (53.9% used)
Info: Processes: 284 Uptime: 9:38 Memory: 4289.6/7976.9MB Init: systemd v: 236 runlevel: 5 Gcc sys: 7.2.0
Client: Shell (bash 4.4.121 running in xfce4-terminal) inxi: 2.3.45
This problem made my computer unbootable. Because DKMS installs the driver to all kernels, none of my installed kernels would boot properly. I reinstalled Debian. Then started using sgfxi instead to install the drivers without DKMS, so I can boot another kernel to remove the drivers.
Oddly enough, Debian doesn’t come with persistent logs turned on, but I managed to enable them, and this is the report I get:
Jan 08 22:47:03 ronin kernel: divide error: 0000 [#1] PREEMPT SMP
Jan 08 22:47:03 ronin kernel: Modules linked in: btrfs zstd_compress zstd_decompress xxhash xor raid6_pq edac_mce_amd kvm_amd kvm eeepc_wmi asus_wmi sparse_keymap irqbypass rfkill
Jan 08 22:47:03 ronin kernel: crc32c_intel i2c_piix4 libata i2c_algo_bit dca ptp xhci_pci pps_core scsi_mod xhci_hcd rtc_cmos gpio_amdpt gpio_generic i2c_designware_platform i2c_d
Jan 08 22:47:03 ronin kernel: CPU: 2 PID: 347 Comm: systemd-udevd Not tainted 4.14.0-11.1-liquorix-amd64 #1 liquorix 4.14-14
Jan 08 22:47:03 ronin kernel: Hardware name: System manufacturer System Product Name/ROG STRIX B350-F GAMING, BIOS 3401 12/04/2017
Jan 08 22:47:03 ronin kernel: task: ffff88020eb73500 task.stack: ffffc900014c8000
Jan 08 22:47:03 ronin kernel: RIP: 0010:nvGetClocks+0x176/0x260 [nvidiafb]
Jan 08 22:47:03 ronin kernel: RSP: 0018:ffffc900014cb7f8 EFLAGS: 00010246
Jan 08 22:47:03 ronin kernel: RAX: 0000000000000000 RBX: ffff8802152e2420 RCX: 0000000000000000
Jan 08 22:47:03 ronin kernel: RDX: 0000000000000000 RSI: ffffc900014cb834 RDI: ffff8802152e2420
Jan 08 22:47:03 ronin kernel: RBP: ffff8802152e2518 R08: ffffc900014cb838 R09: 0000000000000000
Jan 08 22:47:03 ronin kernel: R10: 0000000000000068 R11: 00000000002e18c8 R12: 0000000000062570
Jan 08 22:47:03 ronin kernel: R13: 000000000000000e R14: 0000000000000010 R15: 0000000000000008
Jan 08 22:47:03 ronin kernel: FS: 00007fe8ed56b400(0000) GS:ffff88021ec80000(0000) knlGS:0000000000000000
Jan 08 22:47:03 ronin kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jan 08 22:47:03 ronin kernel: CR2: 00007f546a15c870 CR3: 000000020df0a000 CR4: 00000000003406e0
Jan 08 22:47:03 ronin kernel: Call Trace:
Jan 08 22:47:03 ronin kernel: NVCalcStateExt+0x189/0x8e0 [nvidiafb]
Jan 08 22:47:03 ronin kernel: nvidiafb_set_par+0x47c/0x9f0 [nvidiafb]
Jan 08 22:47:03 ronin kernel: fbcon_init+0x59e/0x780
Jan 08 22:47:03 ronin kernel: visual_init+0xca/0x120
Jan 08 22:47:03 ronin kernel: do_bind_con_driver+0x2ab/0x640
Jan 08 22:47:03 ronin kernel: do_take_over_console+0x22d/0x470
Jan 08 22:47:03 ronin kernel: fbcon_event_notify+0x90d/0xa20
Jan 08 22:47:03 ronin kernel: blocking_notifier_call_chain+0x5d/0x80
Jan 08 22:47:03 ronin kernel: register_framebuffer+0x1d5/0x2f0
Jan 08 22:47:03 ronin kernel: nvidiafb_probe+0x6b2/0xa80 [nvidiafb]
Jan 08 22:47:03 ronin kernel: pci_device_probe+0x1e4/0x340
Jan 08 22:47:03 ronin kernel: driver_probe_device+0x3d4/0x4a0
Jan 08 22:47:03 ronin kernel: __driver_attach+0xd1/0xe0
Jan 08 22:47:03 ronin kernel: ? driver_probe_device+0x4a0/0x4a0
Jan 08 22:47:03 ronin kernel: bus_for_each_dev+0x57/0x80
Jan 08 22:47:03 ronin kernel: bus_add_driver+0x191/0x210
Jan 08 22:47:03 ronin kernel: driver_register+0x78/0xf0
Jan 08 22:47:03 ronin kernel: ? nvidiafb_setcolreg+0x2a0/0x2a0 [nvidiafb]
Jan 08 22:47:03 ronin kernel: do_one_initcall+0x46/0x190
Jan 08 22:47:03 ronin kernel: do_init_module+0x58/0x2f9
Jan 08 22:47:03 ronin kernel: load_module+0x1dfd/0x2760
Jan 08 22:47:03 ronin kernel: ? SyS_finit_module+0x91/0xb0
Jan 08 22:47:03 ronin kernel: SyS_finit_module+0x91/0xb0
Jan 08 22:47:03 ronin kernel: do_syscall_64+0x64/0x190
Jan 08 22:47:03 ronin kernel: entry_SYSCALL64_slow_path+0x25/0x25
Jan 08 22:47:03 ronin kernel: RIP: 0033:0x7fe8ece94da9
Jan 08 22:47:03 ronin kernel: RSP: 002b:00007ffe2837a368 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
Jan 08 22:47:03 ronin kernel: RAX: ffffffffffffffda RBX: 000055d1362632f0 RCX: 00007fe8ece94da9
Jan 08 22:47:03 ronin kernel: RDX: 0000000000000000 RSI: 00007fe8ecb9f2d5 RDI: 0000000000000010
Jan 08 22:47:03 ronin kernel: RBP: 00007fe8ecb9f2d5 R08: 0000000000000000 R09: 0000000000000000
Jan 08 22:47:03 ronin kernel: R10: 0000000000000010 R11: 0000000000000246 R12: 0000000000000000
Jan 08 22:47:03 ronin kernel: R13: 000055d1362591a0 R14: 0000000000020000 R15: 000055d136249140
Jan 08 22:47:03 ronin kernel: Code: f0 0f 00 00 3d 00 03 00 00 74 73 3d 30 03 00 00 74 6c 41 8b 89 04 05 00 00 0f b6 c5 44 0f b6 c9 c1 e9 10 0f af c2 31 d2 83 e1 0f <41> f7 f1 d3 e
Jan 08 22:47:03 ronin kernel: RIP: nvGetClocks+0x176/0x260 [nvidiafb] RSP: ffffc900014cb7f8
