We suggest break down the pipeline to check which part triggers the segment fault. Please check if you can run this and see camera preview:
OpenCV Video Capture with GStreamer doesn't work on ROS-melodic - #3 by DaneLLL
DaneLLL
4
Related topics
| "argus_thread" received signal SIGSEGV, Segmentation fault | 18 | 3188 | September 5, 2023 | |
| Stereo camera opencv segmentation fault during exit | 17 | 4213 | August 7, 2021 | |
| Segementation fault when running the default board's camera gstreamer pipeline through opencv 4.1.1 python | 1 | 1287 | September 12, 2019 | |
| Segmentation fault when re-creating the Gstreamer pipeline with nvarguscamerasrc | 9 | 1624 | September 27, 2019 | |
| BUG: nvarguscamerasrc Segmentation fault | 14 | 3574 | April 14, 2021 | |
| Argus segmentaion fault in GStreamer module | 1 | 97 | December 3, 2024 | |
| Opencv nvarguscamerasrc: hard LOCKUP on cpu 0 | 7 | 2217 | March 17, 2021 | |
| Segfault In stop start playing gstreamer included nvarguscamerasrc | 4 | 1283 | December 7, 2020 | |
| GStreamer-CRITICAL gst_mini_object_set_qdata: assertion 'object != NULL' failed | 7 | 8352 | June 23, 2021 | |
| Hardware Accelerated Encoding with Gstreamer in CPP Fails with Segmentation Fault | 3 | 964 | September 8, 2023 |
