I am new to DS.
I want to use the same pipeline in deepstream-test4 but I want to replace gst-nvinfer with my own lib (input is single frame to cv::mat and output is bbox-ed frame). I use ONNX model and Tensort as inference engine but it was all processed in our lib.
What is the best way to replace only gst-nvinfer and keep the same pipeline including metadata of stream ?
Many thanks,
• Hardware Platform (Jetson / GPU): Xavier NX
• DeepStream Version: 5.1
• TensorRT Version: 7.2.2.3
Why can’t you deploy your network with gst-nvinfer?
I had a pre-processing and post-processing step between model inferencing which lead me to spend effort to integrate with gst-nvinfer. So I would think a way to bypass nvinfer but keep stream metadata.
How many models do you have? What kind of “pre-processing and post-processing” steps “between” model inferencing?
Hi Fiona,
I have with one model only. It’s kind of smooth filtering process which applied a set of opencv mathlib.
Also, would you show me the input/output gstbuffer of gst-nvinfer src code ? AFAIK, it do the same as my own lib does: catch every frame and output bboxed-frame ?
The gst-nvinfer is open source. The code is under /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvinfer
There is a simple introduction of the gst-nvinfer: DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
Hi Fiona,
I am a bit confused about gstbuffer in/out flow between element/plugin. Could you show me where in source code to manage this flow ?
I want to insert my own lib as bellow sequence:
gstbuffer input → convert to frame RGB → my own lib → convert to frame RGB → gstbuffer ouput
e.g: I don’t see bellow API to be invoked by any others… So I don’t know the flow/sequence-order to insert my modified code…
/* Implementation of the GObject/GstBaseTransform interfaces. */
static void gst_nvinfer_finalize (GObject * object);
static void gst_nvinfer_set_property (GObject * object, guint prop_id,
const GValue * value, GParamSpec * pspec);
static void gst_nvinfer_get_property (GObject * object, guint prop_id,
static gboolean gst_nvinfer_start (GstBaseTransform * btrans);
static gboolean gst_nvinfer_stop (GstBaseTransform * btrans);
static gboolean gst_nvinfer_sink_event (GstBaseTransform * trans,
GstEvent * event);
static GstFlowReturn gst_nvinfer_submit_input_buffer (GstBaseTransform *
btrans, gboolean discont, GstBuffer * inbuf);
static GstFlowReturn gst_nvinfer_generate_output (GstBaseTransform *
btrans, GstBuffer ** outbuf);
Deepstream is based on gstreamer. Please refer to gstreamer. GStreamer: open source multimedia framework
Please make sure you know basic knowledge and coding skills of gstreamer before you start with deepstream.
