create_ibv_flow() Create of QP flow ID failed
Dear Mellanox Support,
I’ve problems with OFED 2.2. Neither raw_ethernet_bw / raw_ethernet_lat nor libvma can create a QP flow / call verbs.
At some point on that machine it used to run fine but then we added more network interfaces and it seems to break it somehow.
I got all the latest MLNX software & firmware. Flow steering is disabled and there is nothing useful in dmesg. Could you please help me to figure out what’s wrong? See basic info below.
[root@aurarb01 log]# uname -a
Linux aurarb01 2.6.32-431.17.1.el6.x86_64 #1 SMP Fri Apr 11 17:27:00 EDT 2014 x86_64 x86_64 x86_64 GNU/Linux
[root@aurarb01 log]# ofed_info
MLNX_OFED_LINUX-2.2-1.0.1 (OFED-2.2-1.0.0):
[root@aurarb01 log]# raw_ethernet_bw --server
Max msg size in RawEth is MTU 1518
Changing msg size to this MTU
Send BW Test
Dual-port : OFF Device : mlx4_1
Number of qps : 1 Transport type : IB
Connection type : RawEth Using SRQ : OFF
RX depth : 512
CQ Moderation : 100
Mtu : 1518[B]
Link type : Ethernet
Gid index : 0
Max inline data : 0[B]
rdma_cm QPs : OFF
Data ex. method : Ethernet
MAC attached : 24:BE:05:81:95:90
error: Function not implemented
Couldn’t attach QP
[root@aurarb01 log]# LD_PRELOAD=libvma.so sockperf sr
VMA INFO : ---------------------------------------------------------------------------
VMA INFO : VMA_VERSION: 6.6.4-0 Release built on 2014-04-23-16:54:38
VMA INFO : Cmd Line: sockperf sr
VMA INFO : OFED Version: MLNX_OFED_LINUX-2.2-1.0.1:
VMA INFO : Log Level 3 [VMA_TRACELEVEL]
sockperf: == version #2.5.233 ==
VMA ERROR : rfs[0x23888f0]:188:create_ibv_flow() Create of QP flow ID failed with flow dst:172.17.38.37:11111, src:0.0.0.0:0, protocol:UDP
VMA ERROR : rfs[0x241aa70]:188:create_ibv_flow() Create of QP flow ID failed with flow dst:172.17.38.38:11111, src:0.0.0.0:0, protocol:UDP
VMA ERROR : rfs[0x243e240]:188:create_ibv_flow() Create of QP flow ID failed with flow dst:172.17.38.36:11111, src:0.0.0.0:0, protocol:UDP
sockperf: [SERVER] listen on:
[ 0] IP = 0.0.0.0 PORT = 11111 # UDP
sockperf: Warmup stage (sending a few dummy messages)…
Basically high_rate_steer=1 parameters breaks OFED, that was the reason
