Does MCX-312b (ConnectX-3 Pro) NOT support ibv_flow_spec_ipv4 rule?
For this NIC, ethtool reports it supports mlx4_flow_steering_ipv4 as below
ethtool --show-priv-flags ens2
Private flags for ens2:
blueflame : on
mlx4_flow_steering_ethernet_l2: on
mlx4_flow_steering_ipv4 : on
mlx4_flow_steering_tcp : on
mlx4_flow_steering_udp : on
qcn_disable_32_14_4_e : off
rx-copy : off
phv-bit : off
rx-fcs : off
rx-all : off
mlx4_rss_xor_hash_function : off
But with ibv_query_device, it’s reported NOT to support 'IBV_DEVICE_MANAGED_FLOW_STEERING.
So, does this NIC actually support flow_steering_ipv4 in programming? or just support MAC–> QP flow steering rule?
BTW, if ConnectX-3 Pro just support MAC–> QP flow steering rule, is it actually NOT able to support mcast receive acceleration
( kernel bypass) with libvma?
EXP_MANAGED_FLOW_STEERING flag is shown
Does this show it can support verbs programming APIs in ibv_exp_, such as ibv_exp_create_flow, and ALL those ibv_exp_ flow steering rules, such as ibv_exp_flow_spec_eth, ibv_exp_flow_spec_ipv4, ibv_exp_flow_spec_tcp_udp ?
I wrote a test program, the flow steering can work with only MAC->QP rule. If adding ipv4,tcp/udp → QP rules, the flow can NOT be
steered into the QP.
Besides, because recently I found libvma can actually support kernel pass acceleration for multicast, this show the ConnectX-3 pro support somewhat flow steering also.
So the question become - Is the ConnectX-3 Pro just support MAC->QP rule, or all ipv4,tcp/udp → QP rules?
Can a programmer for libvma give an definite answer?
@alkx, thank you very much!
I’v already been reading the code of libvma.
BTW, EXP_MANAGED_FLOW_STEERING flag means the support to ibv_exp_create_flow (and its series) APIs while MANAGED_FLOW_STEERING means the support to ibv_create_flow (and its series) APIs, right?
If yes, as the output from ‘ibv_devinfo -v’ before, there is EXP_MANAGED_FLOW_STEERING flag but NO MANAGED_FLOW_STEERING flag, then the card ConnectX-3 Pro only support ibv_exp_create_flow series APIs, right?
RAW QP (the one that used by VMA) does support 5tuple. As VMA is an OpenSource GitHub - Mellanox/libvma: Linux user space library for network socket acceleration based on RDMA compatible network adap… GitHub - Mellanox/libvma: Linux user space library for network socket acceleration based on RDMA compatible network adaptors
you can check the implementation there
As a startup point, take a look at these functions
prepare_flow_spec
ibv_create_flow
ring_simple::attach_flow
rfs::attach_flow
In the case if you have more specific questions regarding VMA, there is a discussion forum on Google Groups Redirecting to Google Groups
What is the output of?
#cat /etc/release
#uname -a
#ofed_info -s
#ibv_devinfo -v
  1. OS: CentOS Linux release 7.1.1503
  2. ‘uname -a’ output: Linux testlab5 3.10.0-229.el7.x86_64 #1 SMP Fri Mar 6 11:36:42 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
  3. ofed_info -s
MLNX_OFED_LINUX-3.4-1.0.0.0:
  1. ibv_devinfo -v
sudo ibv_devinfo -v
hca_id: mlx4_0
transport: InfiniBand (0)
fw_ver: 2.36.5150
node_guid: e41d:2d03:002b:dba0
sys_image_guid: e41d:2d03:002b:dba0
vendor_id: 0x02c9
vendor_part_id: 4103
hw_ver: 0x0
board_id: MT_1200111023
phys_port_cnt: 2
max_mr_size: 0xffffffffffffffff
page_size_cap: 0xfffffe00
max_qp: 392632
max_qp_wr: 16351
device_cap_flags: 0x005c9c66
BAD_PKEY_CNTR
BAD_QKEY_CNTR
CHANGE_PHY_PORT
UD_AV_PORT_ENFORCE
PORT_ACTIVE_EVENT
SYS_IMAGE_GUID
RC_RNR_NAK_GEN
XRC
Unknown flags: 0x004c8000
device_cap_exp_flags: 0x71221C1600000000
EXP_DEVICE_QPG
EXP_UD_RSS
EXP_MEM_WINDOW
EXP_MEM_MGT_EXTENSIONS
EXP_MW_TYPE_2B
EXP_CROSS_CHANNEL
EXP_MR_ALLOCATE
EXT_ATOMICS
EXP_VXLAN_SUPPORT
EXP_RX_CSUM_TCP_UDP_PKT
EXP_RX_CSUM_IP_PKT
max_sge: 32
max_sge_rd: 30
max_cq: 65408
max_cqe: 4194303
max_mr: 524032
max_pd: 32764
max_qp_rd_atom: 16
max_ee_rd_atom: 0
max_res_rd_atom: 6282112
max_qp_init_rd_atom: 128
max_ee_init_rd_atom: 0
atomic_cap: ATOMIC_HCA (1)
log atomic arg sizes (mask) 0x8
masked_log_atomic_arg_sizes (mask) 0x8
masked_log_atomic_arg_sizes_network_endianness (mask) 0x0
max fetch and add bit boundary 64
log max atomic inline 3
max_ee: 0
max_rdd: 0
max_mw: 0
max_raw_ipv6_qp: 0
max_raw_ethy_qp: 0
max_mcast_grp: 131072
max_mcast_qp_attach: 244
max_total_mcast_qp_attach: 31981568
max_ah: 2147483647
max_fmr: 0
max_srq: 65472
max_srq_wr: 16383
max_srq_sge: 31
max_pkeys: 128
local_ca_ack_delay: 15
hca_core_clock: 318
max_klm_list_size: 0
max_send_wqe_inline_klms: 0
max_umr_recursion_depth: 0
max_umr_stride_dimension: 0
general_odp_caps:
rc_odp_caps:
NO SUPPORT
uc_odp_caps:
NO SUPPORT
ud_odp_caps:
NO SUPPORT
dc_odp_caps:
NO SUPPORT
xrc_odp_caps:
NO SUPPORT
raw_eth_odp_caps:
NO SUPPORT
max_dct: 0
max_device_ctx: 1016
Multi-Packet RQ is not supported
rx_pad_end_addr_align: 0
tso_caps:
max_tso: 0
packet_pacing_caps:
qp_rate_limit_min: 0kbps
qp_rate_limit_max: 0kbps
Device ports:
port: 1
state: PORT_ACTIVE (4)
max_mtu: 4096 (5)
active_mtu: 1024 (3)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
link_layer: Ethernet
max_msg_sz: 0x40000000
port_cap_flags: 0x0c010000
max_vl_num: 2 (2)
bad_pkey_cntr: 0x0
qkey_viol_cntr: 0x0
sm_sl: 0
pkey_tbl_len: 1
gid_tbl_len: 128
subnet_timeout: 0
init_type_reply: 0
active_width: 1X (1)
active_speed: 10.0 Gbps (4)
phys_state: LINK_UP (5)
GID[ 0]: fe80:0000:0000:0000:e61d:2dff:fe2b:dba0
GID[ 1]: 0000:0000:0000:0000:0000:ffff:0a01:c817
port: 2
max_mtu: 4096 (5)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
max_vl_num: 2 (2)
bad_pkey_cntr: 0x0
qkey_viol_cntr: 0x0
sm_sl: 0
pkey_tbl_len: 1
gid_tbl_len: 128
subnet_timeout: 0
init_type_reply: 0
GID[ 0]: fe80:0000:0000:0000:e61d:2dff:fe2b:dba1
GID[ 1]: 0000:0000:0000:0000:0000:ffff:0a01:c90d
Device does report flow steering support. EXP_MANAGED_FLOW_STEERING flag is shown in the output. For additional details,please refer to Mellanox OFED User Manual - ‘Flow Steering Support’.
ibv_exp_* is a way to go if support for the latest features, like flow steering, is necessary.
