I need to create new partitions in emmc
I have already referred to Partition Configuration part in development guide.
The attachment is my modified xml.
I want to set partitions in emmc as same as I write in my xml file.
here is some information:
I use “sudo ./flash.sh -S 16400MiB jetson-tx2 mmcblk0p1” to flash.
root@tegra-ubuntu:~# gdisk -l /dev/mmcblk0
Found valid GPT with protective MBR; using GPT.
Disk /dev/mmcblk0: 61071360 sectors, 29.1 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Partition table holds up to 31 entries
First usable sector is 4097, last usable sector is 61071327
Partitions will be aligned on 1-sector boundaries
Total free space is 1 sectors (512 bytes)
Number Start (sector) End (sector) Size Code Name
1 4097 33591296 16.0 GiB 0700 APP
2 33591297 33599488 4.0 MiB 0700 mts-bootpack
3 33599489 33607680 4.0 MiB 0700 mts-bootpack_b
4 33607681 33608704 512.0 KiB 0700 cpu-bootloader
5 33608705 33609728 512.0 KiB 0700 cpu-bootloader_b
6 33609729 33610752 512.0 KiB 0700 bootloader-dtb
7 33610753 33611776 512.0 KiB 0700 bootloader-dtb_b
8 33611777 33617920 3.0 MiB 0700 secure-os
9 33617921 33624064 3.0 MiB 0700 secure-os_b
10 33624065 33628160 2.0 MiB 0700 eks
11 33628161 33629368 604.0 KiB 0700 bpmp-fw
12 33629369 33630576 604.0 KiB 0700 bpmp-fw_b
13 33630577 33631576 500.0 KiB 0700 bpmp-fw-dtb
14 33631577 33632576 500.0 KiB 0700 bpmp-fw-dtb_b
15 33632577 33636672 2.0 MiB 0700 sce-fw
16 33636673 33640768 2.0 MiB 0700 sce-fw_b
17 33640769 33653056 6.0 MiB 0700 sc7
18 33653057 33665344 6.0 MiB 0700 sc7_b
19 33665345 33669440 2.0 MiB 0700 FBNAME
20 33669441 33931584 128.0 MiB 0700 BMP
21 33931585 34193728 128.0 MiB 0700 BMP_b
22 34193729 34259264 32.0 MiB 0700 SOS
23 34259265 34324800 32.0 MiB 0700 SOS_b
24 34324801 34455872 64.0 MiB 0700 kernel
25 34455873 34586944 64.0 MiB 0700 kernel_b
26 34586945 34587968 512.0 KiB 0700 kernel-dtb
27 34587969 34588992 512.0 KiB 0700 kernel-dtb_b
28 34588993 35113280 256.0 MiB 0700 CAC
29 35113281 61071326 12.4 GiB 0700 UDA
30 61071327 61071326 0 bytes 0700 PLUSA
31 61071327 61071326 0 bytes 0700 PLUSB
Why is there no space in PLUSA and PLUSB?
Can you tell me what else I need to do when creating another partition?
Thanks very much
flash_l4t_t186.xml (21.7 KB)
hello l6331533854,
you should note that by default GPT partition has occupy the rest of emmc size.
please have a try to move your PLUSA and PLUSB forward before GPT partition.
thanks
Hi JerryChang,
thanks for replying.
I try your suggestion in .xml file but it did not work as I expected.
Should I modify other file? I am using R28.2.1. I also try modify .cfg file, but still in vain.
nvidia@tegra-ubuntu:~$ sudo gdisk -l /dev/mmcblk0
29 35113281 61071326 12.4 GiB 0700 PLUSA
30 61071327 61071326 0 bytes 0700 PLUSB
31 61071327 61071326 0 bytes 0700 UDA
Can I assign storages for PLUSA, PLUSB, UDA at the same time?
gnu_linux_fastboot_emmc_full.2-cfg.txt (4.48 KB)
hello l6331533854,
please have modification with below conditions:
- GPT should be the last partition,
allocation_attribute with attribute 0x808 should be the second last partition as it is extended to rest of the device. thanks
Hi, JerryChang,
Thanks for your replying and guiding. I have solved my previous problem.
I am curious about another question.
I want to know the function and role of gnu_linux_fastboot_emmc_full.cfg in cfg folder.
It seems that it is not related to partition setting.
hello l6331533854,
please consider gnu_linux_fastboot_emmc_full.cfg as an unified flash config file.
there’s binary file, mkbctpart to load this file and generate a platform specific configuration files.
thanks
I’m following the counsel in this thread to make my own partition, however I would like it to be 1GB large and to compensate I would like the APP partition to be that much smaller, however in the flash_l4t_t186.xml it has the keyword APPSIZE in the place of the size and if I dare put something else in there, the flashing stops when it needs to flash this image, so I’m definitely doing something wrong. However my question: how does one shrink the APP partition?
I have found the answer to my own question meanwhile:
if you use the flash.sh script, there is the option -S
of which the help says:
-S ------------ Rootfs size in bytes. Valid only for internal
rootdev. KiB, MiB, GiB short hands are allowed,
for example, 1GiB means 1024 * 1024 * 1024 bytes.
so if I simply start
sudo ./flash.sh -S 4GiB spacely-base mmcblk0p1
and I check on my board after the flash I can see that the APP partition is now 4.0 GiB large and the UDA partition at the end is now 24.4 GiB since it fills out the rest of the eMMc drive
