I would like to encode data rendered with CUDA as quickly as possible as h264. It seems that a proper way to do this is to create a gstreamer-pipeline with a nveglstreamsrc-element connected to an omx264enc-element. I implemented it, but it doesn’t work as expected. Specifically the cuEGLStreamProducerPresentFrame-method always returns immediately and no data is written. Presumably I’m missing something, but as I’m not able to find any documentation about proper usage of the egl-methods, I’m asking you if could tell me what I have to do.
This is the complete source-code of my test-application:
#include <gst/gst.h>
#include <iostream>
#include <stdexcept>
#include <chrono>
#include <cuda.h>
#include <cudaEGL.h>
static void checkCuda(cudaError_t code) {
if (code != cudaSuccess) {
printf("cuda-error: %s", cudaGetErrorString(code));
std::cout << std::endl;
exit(1);
static void checkCu(CUresult code) {
if (code != CUDA_SUCCESS) {
const char *str = NULL;
cuGetErrorString(code, &str);
printf("cuda error-description: %s", str);
exit(1);
static EGLStreamKHR eglStream;
static EGLDisplay eglDisplay;
#define EXTENSION_LIST(T) \
T( PFNEGLCREATESTREAMKHRPROC, eglCreateStreamKHR ) \
T( PFNEGLDESTROYSTREAMKHRPROC, eglDestroyStreamKHR ) \
T( PFNEGLQUERYSTREAMKHRPROC, eglQueryStreamKHR ) \
T( PFNEGLQUERYSTREAMU64KHRPROC, eglQueryStreamu64KHR ) \
T( PFNEGLQUERYSTREAMTIMEKHRPROC, eglQueryStreamTimeKHR ) \
T( PFNEGLSTREAMATTRIBKHRPROC, eglStreamAttribKHR ) \
T( PFNEGLSTREAMCONSUMERACQUIREKHRPROC, eglStreamConsumerAcquireKHR ) \
T( PFNEGLSTREAMCONSUMERRELEASEKHRPROC, eglStreamConsumerReleaseKHR ) \
T( PFNEGLSTREAMCONSUMERGLTEXTUREEXTERNALKHRPROC, \
eglStreamConsumerGLTextureExternalKHR ) \
T( PFNEGLGETSTREAMFILEDESCRIPTORKHRPROC, eglGetStreamFileDescriptorKHR) \
T( PFNEGLCREATESTREAMFROMFILEDESCRIPTORKHRPROC, eglCreateStreamFromFileDescriptorKHR)
// See bug 200161837 on my EGL pointer functions should renamed starting with my_
// not renaming egl pointer function to start with my_ causes 64 bit app to crash
#define eglCreateStreamKHR my_eglCreateStreamKHR
#define eglDestroyStreamKHR my_eglDestroyStreamKHR
#define eglQueryStreamKHR my_eglQueryStreamKHR
#define eglQueryStreamu64KHR my_eglQueryStreamu64KHR
#define eglQueryStreamTimeKHR my_eglQueryStreamTimeKHR
#define eglStreamAttribKHR my_eglStreamAttribKHR
#define eglStreamConsumerAcquireKHR my_eglStreamConsumerAcquireKHR
#define eglStreamConsumerReleaseKHR my_eglStreamConsumerReleaseKHR
#define eglStreamConsumerGLTextureExternalKHR my_eglStreamConsumerGLTextureExternalKHR
#define eglGetStreamFileDescriptorKHR my_eglGetStreamFileDescriptorKHR
#define eglCreateStreamFromFileDescriptorKHR my_eglCreateStreamFromFileDescriptorKHR
#define EXTLST_DECL(tx, x) tx my_ ## x = NULL;
#define EXTLST_EXTERN(tx, x) extern tx my_ ## x;
#define EXTLST_ENTRY(tx, x) { (extlst_fnptr_t *)&my_ ## x, #x },
EXTENSION_LIST(EXTLST_DECL)
typedef void (*extlst_fnptr_t)(void);
static struct {
extlst_fnptr_t *fnptr;
char const *name;
} extensionList[] = { EXTENSION_LIST(EXTLST_ENTRY) };
static int eglSetupExtensions(void) {
for (int i = 0; i < (sizeof(extensionList) / sizeof(*extensionList)); i++) {
*extensionList[i].fnptr = eglGetProcAddress(extensionList[i].name);
if (*extensionList[i].fnptr == NULL) {
printf("Couldn't get address of %s()\n", extensionList[i].name);
return 0;
return 1;
static int EGLStreamInit() {
static const EGLint streamAttrMailboxMode[] = { EGL_SUPPORT_REUSE_NV, EGL_FALSE, EGL_NONE };
EGLBoolean eglStatus;
eglDisplay = eglGetDisplay(EGL_DEFAULT_DISPLAY);
if (eglDisplay == EGL_NO_DISPLAY) {
printf("eglDisplayHandle failed \n");
return 0;
} else {
printf("eglDisplay Handle created (0x%p)\n", eglDisplay);
eglStatus = eglInitialize(eglDisplay, 0, 0);
if (!eglStatus) {
printf("EGL failed to initialize.\n");
return 0;
eglStream = eglCreateStreamKHR(eglDisplay, streamAttrMailboxMode);
if (eglStream == EGL_NO_STREAM_KHR) {
printf("EGLStreamInit: Couldn't create eglStream.\n");
return 0;
// Set stream attribute
if (!eglStreamAttribKHR(eglDisplay, eglStream, EGL_CONSUMER_LATENCY_USEC_KHR, 16000)) {
printf("Consumer: eglStreamAttribKHR EGL_CONSUMER_LATENCY_USEC_KHR failed\n");
return 0;
if (!eglStreamAttribKHR(eglDisplay, eglStream, EGL_CONSUMER_ACQUIRE_TIMEOUT_USEC_KHR, 16000)) {
printf("Consumer: eglStreamAttribKHR EGL_CONSUMER_ACQUIRE_TIMEOUT_USEC_KHR failed\n");
return 0;
printf("EGLStream initialized\n");
return 1;
constexpr int WIDTH = 1280;
constexpr int HEIGHT = 720;
static CUeglStreamConnection conn = NULL;
static gboolean myIdle(gpointer user_data) {
static uint8_t *data = NULL;
if (!data) {
checkCuda(cudaMallocHost(&data, WIDTH*HEIGHT*3/2));
checkCuda(cudaMemset(data, 128, WIDTH*HEIGHT*3/2));
CUeglFrame eglFrame{};
eglFrame.frame.pPitch[0] = const_cast<uint8_t*>(data);
eglFrame.frame.pPitch[1] = const_cast<uint8_t*>(data) + WIDTH*HEIGHT;
eglFrame.frame.pPitch[2] = const_cast<uint8_t*>(data) + WIDTH*HEIGHT*5/4;
eglFrame.width = WIDTH;
eglFrame.height = HEIGHT;
eglFrame.depth = 1;
eglFrame.pitch = WIDTH;
eglFrame.frameType = CU_EGL_FRAME_TYPE_PITCH;
eglFrame.planeCount = 3;
eglFrame.numChannels = 1;
eglFrame.eglColorFormat = CU_EGL_COLOR_FORMAT_YUV420_PLANAR;
eglFrame.cuFormat = CU_AD_FORMAT_UNSIGNED_INT8;
checkCu(cuEGLStreamProducerPresentFrame(&conn, eglFrame, NULL));
static int counter = 0;
++counter;
using namespace std::chrono;
using theclk = high_resolution_clock;
static theclk::time_point lastTime{};
const auto curTime = theclk::now();
const auto timeDiff = curTime-lastTime;
if (timeDiff >= seconds(1)) {
lastTime = curTime;
printf("%.1f fps", counter/duration_cast<duration<double>>(timeDiff).count());
counter = 0;
return G_SOURCE_CONTINUE;
int main() {
gst_init(NULL, NULL);
if (!eglSetupExtensions()) throw std::runtime_error("eglSetupExtensions");
if (!EGLStreamInit()) throw std::runtime_error("EGLStreamInit");
checkCu(cuInit(0));
CUdevice device;
checkCu(cuDeviceGet(&device, 0));
CUcontext ctx = NULL;
cuCtxCreate(&ctx, 0, device);
checkCu(cuEGLStreamConsumerConnect(&conn, eglStream)); // without this the producer-connect call fails
checkCu(cuEGLStreamProducerConnect(&conn, eglStream, WIDTH, HEIGHT));
GstElement *pipeline = gst_pipeline_new("video_pipeline");
if (!pipeline) throw std::runtime_error("no pipeline");
GstElement *eglSrc = gst_element_factory_make("nveglstreamsrc", NULL);
if (!eglSrc) throw std::runtime_error("no eglSrc");
if (!gst_bin_add(GST_BIN(pipeline), eglSrc)) throw std::runtime_error("could not add eglSrc");
g_object_set(G_OBJECT(eglSrc), "display", eglDisplay, NULL);
g_object_set(G_OBJECT(eglSrc), "eglstream", eglStream, NULL);
GstElement *queue = gst_element_factory_make("queue", NULL);
if (!queue) throw std::runtime_error("no queue");
if (!gst_bin_add(GST_BIN(pipeline), queue)) throw std::runtime_error("could not add queue");
GstElement *h264Enc = gst_element_factory_make("omxh264enc", NULL);
if (!h264Enc) throw std::runtime_error("no omxh264enc");
if (!gst_bin_add(GST_BIN(pipeline), h264Enc)) throw std::runtime_error("could not add omxh264enc");
g_object_set(G_OBJECT(h264Enc), "bitrate", 30000000, NULL);
GstElement *videoMuxer = gst_element_factory_make("qtmux", NULL);
if (!videoMuxer) throw std::runtime_error("no qtmux");
if (!gst_bin_add(GST_BIN(pipeline), videoMuxer)) throw std::runtime_error("could not add qtmux");
GstElement *fileSink = gst_element_factory_make("filesink", NULL);
if (!fileSink) throw std::runtime_error("no filesink");
if (!gst_bin_add(GST_BIN(pipeline), fileSink)) throw std::runtime_error("could not add filesink");
g_object_set(G_OBJECT(fileSink), "location", "test.mp4", NULL);
GstCaps *caps = gst_caps_new_simple("video/x-raw",
"format", G_TYPE_STRING, "I420", // I420/NV12
"width", G_TYPE_INT, WIDTH,
"height", G_TYPE_INT, HEIGHT,
"framerate", GST_TYPE_FRACTION, 30, 1,
NULL);
if (!caps) throw std::runtime_error("no caps");
GstCapsFeatures *features = gst_caps_features_new("memory:NVMM", NULL);
if (!features) throw std::runtime_error("no features");
gst_caps_set_features(caps, 0, features);
if (!gst_element_link_filtered(eglSrc, queue, caps)) throw std::runtime_error("could not link eglSrc to queue");
gst_caps_unref(caps);
if (!gst_element_link(queue, h264Enc)) throw std::runtime_error("could not link queue to h264Enc");
if (!gst_element_link_pads(h264Enc, "src", videoMuxer, "video_%u")) throw std::runtime_error("could not link h264Enc to videoMuxer");
if (!gst_element_link(videoMuxer, fileSink)) throw std::runtime_error("could not link videoMuxer to fileSink");
gst_element_set_state(pipeline, GST_STATE_PLAYING);
GMainLoop *gMainLoop = g_main_loop_new(NULL, FALSE);
g_idle_add(myIdle, NULL);
g_main_loop_run(gMainLoop);
return 0;
