I have 20 sets of NVIDIA Jetson TX2 Developer kits to configure.
Currently, I am using the SDK manager to flash Jetpack 4.2.2 to the TX2. I have installed additional libraries and made changes to the configuration of the TX2 according to my requirement.
I would like the same exact configuration for the other 19 TX2, thus would like to know if there is a faster way to do this. I could only think of creating an image of the working TX2 and flashing it to the rest of the TX2 - but not sure if its possible to do so. Tried googling to no avail.
you could enable -G options to back-up APP partition to save all your configurations into an image file.
-G ------- Read partition and save image to file.
you may backup the system.img from target.
for example,
please replace that system.img with your host machine image.
then you should flash it to other boards with the same configuration.
please remember to add -r options, it’ll skip building and reuse existing system.img
thanks
I am thinking I saw the UID 120 somewhere before, but can’t remember. However, keep in mind that the non-rootfs binary partitions need to come from the same JetPack/L4T release as the rootfs was generated for. So for example, a rootfs from R28.2.1 won’t work with the non-rootfs partitions of R32.2.
You can see which L4T release the rootfs goes with via “head -n 1 /etc/nv_tegra_release”.
I am unable to switch tty, the screen keeps on flashing back to tty1
I reverted to the original bootloader/system.img on my host machine and flashed the board via the command above, it was giving me the same error. However, when I flash the original image using the NVIDIA SDKManager GUI, it works fine.
Also to note, the backup image is based on the same Jetpack 4.2.2 as I have on my host machine.
If this does not return all “ok”, then you have some incorrect libraries. If all is “ok”, then likely the flashing back to tty1 is a user space configuration issue.
