Cross compilation error pyconfig.h not found
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.1.8175
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
I try to cross compile an application (not a driveworks sample) to run after on AGX DRIVE but I keep getting this error:
mkdir -p bin.obj
mkdir -p bin
/home/melyaagoubi/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++ -c -o bin.obj/dnn/src/network.o dnn/src/network.cpp -DWRAPPER_PYTHON=1 -I/home/melyaagoubi/python-agx/include/python3.6m -I/home/melyaagoubi/Workspace/DAR/proj1832_thirdparty_libraries/boost/1.66.0/gnu7.5/aarch64/include -I./include/ -I./include/plugins/ -isystem /usr/include/aarch64-linux-gnu/ -isystem /usr/local/cuda-10.2/targets/aarch64-linux/include/ -std=c++11 -fPIC -DWRAPPER_PYTHON=1
In file included from /home/melyaagoubi/Workspace/DAR/proj1832_thirdparty_libraries/boost/1.66.0/gnu7.5/aarch64/include/boost/python/detail/wrap_python.hpp:50:0,
from /home/melyaagoubi/Workspace/DAR/proj1832_thirdparty_libraries/boost/1.66.0/gnu7.5/aarch64/include/boost/python/detail/prefix.hpp:13,
from /home/melyaagoubi/Workspace/DAR/proj1832_thirdparty_libraries/boost/1.66.0/gnu7.5/aarch64/include/boost/python/args.hpp:8,
from /home/melyaagoubi/Workspace/DAR/proj1832_thirdparty_libraries/boost/1.66.0/gnu7.5/aarch64/include/boost/python.hpp:11,
from /home/melyaagoubi/Workspace/DAR/proj1832_thirdparty_libraries/boost/1.66.0/gnu7.5/aarch64/include/boost/python/numpy/dtype.hpp:15,
from /home/melyaagoubi/Workspace/DAR/proj1832_thirdparty_libraries/boost/1.66.0/gnu7.5/aarch64/include/boost/python/numpy.hpp:10,
from dnn/src/…/…/include/NetworkTensorRT.hpp:37,
from dnn/src/network.cpp:4:
/home/melyaagoubi/python-agx/include/python3.6m/pyconfig.h:9:12: fatal error: aarch64-linux-gnu/python3.6m/pyconfig.h: No such file or directory
#include <aarch64-linux-gnu/python3.6m/pyconfig.h>
compilation terminated.
Makefile:138: recipe for target ‘bin.obj/dnn/src/network.o’ failed
make: *** [bin.obj/dnn/src/network.o] Error 1
Dear @mohammed.el-yaagoubi,
Do you see the file in relavant path? May I know what library sample you are trying to build?
I try to do the cross compilation of an open source framework for deep learning called N2D2 (GitHub - CEA-LIST/N2D2: N2D2 is a open source CAD framework for Deep Neural Network simulation and full DNN-based applications building.).
And yes I can see the file in the relevant path
It looks like a include path issue. Please double check if the aarch64-linux-gnu/python3.6m/pyconfig.h is in include path?
When I try to change the folder containing the pyconfig.h file I get this error:
/home/melyaagoubi/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++ -shared -Wl,-soname,N2D2.so.so -o bin/N2D2.so bin.obj/dnn/src/network.o bin.obj/src/kernels_cpu.o bin.obj/src/n2d2_tensorRT.o bin.obj/src/cpp_utils.o bin.obj/src/kernels_gpu.ocu -std=c++0x -L/home/melyaagoubi/Workspace/DAR/proj1832_thirdparty_libraries/boost/1.66.0/gnu7.5/aarch64/lib -lboost_python3 -L/home/melyaagoubi/Workspace/DAR/proj1832_thirdparty_libraries/boost/1.66.0/gnu7.5/aarch64/lib -lboost_numpy3 -L/usr/aarch64-linux-gnu/lib/ -lpython3.6m -L -L/usr/local/cuda-10.2/targets/aarch64-linux//lib/ -fopenmp -lpthread -lcublas -lcudnn -lnvinfer
/home/melyaagoubi/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/…/lib/gcc/aarch64-linux-gnu/7.3.1/…/…/…/…/aarch64-linux-gnu/bin/ld: bin.obj/src/kernels_gpu.ocu: Relocations in generic ELF (EM: 62)
