# -DVIBRANTE_PDK:STRING=<path to vibrante-t186ref-linux>
-DVIBRANTE_PDK:STRING=/home/server/NVIDIA/Drive/5050aL_SDK/DriveSDK/drive-t186ref-linux
# -DOPENCV_TEST_DATA_PATH=../opencv_extra/testdata
-DOPENCV_TEST_DATA_PATH=/home/server/opencv/opencv_extra/testdata
Then it reported an error:
CMake Error: The source directory "/home/server/opencv/opencv/build/VERBOSE=1" does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
I deleted this command and tried again:
VERBOSE=1
It reported another error:
CMake Error: The source directory "/home/server/opencv/opencv/build" does not appear to contain CMakeLists.txt.
Is this error related to that I didn’t use PDK for cross compiling? If so, can you tell me where to download PDK? If it doesn’t matter, what else caused this error?Thanks.
I did as your words and ran the latest version(DriveInstall 5.0.5.0b), but i can not download any packages basing on it. It will try 10 times to download each package then show as below:
Error:Component is missing
Though I use other host PCs and change my internet connection, unfortunately it did not work. And we have been already under this situation for some days.
Could you give me a Link which i can download all packages i need directly.
Dear 949707878,
Please check if it has issue with internet proxy. You should be able to download without any issue if you connected to internet directly. Before that, Can you double check the cross compilation instructions? The error CMake Error: The source directory “/home/server/opencv/opencv/build” does not appear to contain CMakeLists.txt makes me suspicious that you forgot to add … in the end of cmake command. Also, check if you are the cmake command from build folder
thank you for your suggestion and I very appreciate that!
However, when I ran cmake command, another error reported:
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
CUDA_nppi_LIBRARY (ADVANCED)
linked by target "opencv_cudev" in directory /home/server/opencv/opencv/modules/cudev
linked by target "opencv_core" in directory /home/server/opencv/opencv/modules/core
linked by target "opencv_test_core" in directory /home/server/opencv/opencv/modules/core
linked by target "opencv_perf_core" in directory /home/server/opencv/opencv/modules/core
-- Configuring incomplete, errors occurred!
I found the codes in local FindCUDA.cmake is the same with your patch and make sure the cmake command is from build folder. How can I solve this problem?
i believe i have already change the original codes in my FindCUDA.cmake however it does not work.
and then i take your advice and install this patch following what you wrote. Every time after i applied the command: patch -p1 < FindCUDA.cmake( i download from your website), i see **** only garbage was found in this patch. naja, i do not how to solve it…
