– VIBRANTE_PDK = ~/nvidia/di418/i/VibranteSDK/vibrante-t186ref-linux
CMake Error at cmake/Toolchain-V4L.cmake:94 (message):
Can’t open
~/nvidia/di418/i/VibranteSDK/vibrante-t186ref-linux/lib-target/version-nv-(pdk/sdk).txt
for PDK branch detection
Call Stack (most recent call first):
/usr/share/cmake-3.5/Modules/CMakeDetermineSystem.cmake:98 (include)
CMakeLists.txt:17 (project)
– Configuring incomplete, errors occurred!
See also “/home/adrian/nvidia/di418/build/CMakeFiles/CMakeOutput.log”.
See also “/home/adrian/nvidia/di418/build/CMakeFiles/CMakeError.log”.
Hi amb2,
Can you please re-check the prerequisites and environment variables given in driveWorks SDK reference document. Also, please check if the ~/nvidia/di418/i/VibranteSDK/vibrante-t186ref-linux/lib-target/version-nv-(pdk/sdk).txt files exists.
I cannot see where the error log is in the following output:
adrian@adrian-Dell-System-XPS-L702X:/usr/local/driveworks/build$ sudo /usr/bin/cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks/samples/cmake/Toolchain-V4L.cmake -DVIBRANTE_PDK_FILE:STRING=~/nvidia/di418/i/VibranteSDK/vibrante-t186ref-linux/lib-target/version-nv-sdk.txt -DVIBRANTE_PDK:STRING=~/nvidia/di418/i/VibranteSDK/vibrante-t186ref-linux \ -DCMAKE_INSTALL_PREFIX=/usr/local/driveworks/bin/ /usr/local/driveworks/samples
– VIBRANTE_PDK_FILE = ~/nvidia/di418/i/VibranteSDK/vibrante-t186ref-linux/lib-target/version-nv-sdk.txt
CMake Error at cmake/Toolchain-V4L.cmake:88 (file):
file failed to open for reading (No such file or directory):
adrian@adrian-Dell-System-XPS-L702X:/usr/local/driveworks-0.3/samples/build$ sudo cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks-0.3/samples/cmake/Toolchain-V4L.cmake -DVIBRANTE_PDK:STRING=~/nvidia/di418/i/VibranteSDK/vibrante-t186ref-linux /usr/local/driveworks-0.3/samples/
