-- Building GLFW for X11 (static)
CMake Error at /usr/share/cmake-3.5/Modules/FindX11.cmake:439 (message):
Could not find X11
Call Stack (most recent call first):
3rdparty/src/glfw/CMakeLists.txt:22 (find_package)
3rdparty/src/glfw/CMakeLists.txt:107 (glfw_build_for_winsys)
Also, at first, when I just install all the required component on host machine via sdkmanager, I could not locate DriveSDK, and after I also tried to install the required target component( even though failed since no target hardware connected), I could locate the DriveSDK, but still have this error output.
Thanks for response. I’ve upgrade the OS to 5.1.6.0, and I’m again have trouble cross compile the sample code, with following error:
cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks/samples/cmake/Toolchain-V5L.cmake -DVIBRANTE_PDK:STRING=/home/test/nvidia/nvidia_sdk/DRIVE_OS_5.1.6.0_SDK_Linux_OS_E3550/DriveOS/drive-t186ref-linux -DVIBRANTE_PDK_FILE=/home/test/nvidia/nvidia_sdk/DRIVE_OS_5.1.6.0_SDK_Linux_OS_E3550/DriveOS/drive-t186ref-linux/lib-target/version-oss-sdk.txt ..
-- VIBRANTE_PDK = /home/test/nvidia/nvidia_sdk/DRIVE_OS_5.1.6.0_SDK_Linux_OS_E3550/DriveOS/drive-t186ref-linux
-- VIBRANTE_PDK_DEVICE = t186ref
-- VIBRANTE_PDK_BRANCH = 5.1.6.0
-- Vibrante version 5.1.6.0
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
CMake Error at CMakeLists.txt:16 (project):
The CMAKE_C_COMPILER:
/home/test/nvidia/nvidia_sdk/DRIVE_OS_5.1.6.0_SDK_Linux_OS_E3550/DriveOS/drive-t186ref-linux/../toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc
is not a full path to an existing compiler tool.
Tell CMake where to find the compiler by setting either the environment
variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
the compiler, or to the compiler name if it is in the PATH.
The CMAKE_CXX_COMPILER:
/home/test/nvidia/nvidia_sdk/DRIVE_OS_5.1.6.0_SDK_Linux_OS_E3550/DriveOS/drive-t186ref-linux/../toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-g++
variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
to the compiler, or to the compiler name if it is in the PATH.
-- Configuring incomplete, errors occurred!
Seems the path to compiler is currupted, but I’m wondering what would be the rightful path for the compiler?
Dear j5207,
As I said, if you flash just Drive OS via sdkmanager, you don’t get Driveworks with it. It seems you are trying to cross compile the old DW.
Yes, I do understand. It just seems to me that in sdkmanager, there’s only one option for flash, only with 5.1.6.0 DriveOS. Therefore, I’m wondering how could I install the compatible Driveworks?
