Error with Cross-Compiling for the NVIDIA DRIVE Platform
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.4.1.7402
other
Host Machine Version
native Ubuntu 18.04
other
I’m trying to cross-compile the DriveWorks sample for the NVIDIA DRIVE Platform with reference to:
I thought it was necessary to specify the cudnn path with the DCMAKE_PREFIX_PATH option, so I added this to the cmake options and ran it.
As a result, the following error occurred.
Can you help me resolve this error?
jpc00208119@JPC00208119:~/test/samples/build$ sudo cmake -DCMAKE_BUILD=Release -DCMAKE_TOOLCHAIN_FILE=../cmake/Toolchain-V5L.cmake -DVIBRANTE_PDK:STRING=/home/jpc00208119/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux -DTRT_VERSION:STRING=6.3.1.3 -DCMAKE_PREFIX_PATH="/home/jpc00208119/test/samples/3rdparty/linux-x86/cudnn-7.6.6.184" ..
-- VIBRANTE_PDK = /home/jpc00208119/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux
-- Vibrante version 5.2.0.0
-- Found /home/jpc00208119/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/lib-target/libEGL.so:
--  - Includes: [/home/jpc00208119/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/include]
--  - Libraries: [/home/jpc00208119/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/lib-target/libEGL.so]
-- Found: /home/jpc00208119/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/lib-target/libdrm.so
-- Header at: /home/jpc00208119/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/include
-- DW_EXPERIMENTAL_FORCE_EGL set and EGL Support Enabled
-- Cross Compiling for Vibrante
-- Building with TRT version 6.3.1.3 and cudnn version 7.6.6.184, pdk version 5.2.0.0
-- Building GLFW for X11 (static)
CMake Error at cmake/Samples3rdparty.cmake:14 (find_package):
  Could not find a package configuration file provided by "vibrante" with any
  of the following names:
    vibranteConfig.cmake
    vibrante-config.cmake
  Add the installation prefix of "vibrante" to CMAKE_PREFIX_PATH or set
  "vibrante_DIR" to a directory containing one of the above files.  If
  "vibrante" provides a separate development package or SDK, be sure it has
  been installed.
Call Stack (most recent call first):
  CMakeLists.txt:58 (include)
-- Configuring incomplete, errors occurred!
See also "/home/jpc00208119/test/samples/build/CMakeFiles/CMakeOutput.log".
See also "/home/jpc00208119/test/samples/build/CMakeFiles/CMakeError.log".
Note:
I referred to the post below.
My DRIVE AGX has been flushed by the SDK manager.
Dear @Keisuke.Sakamoto,
Please install the cuda cross compilation libs and follow the instructions provided in https://docs.nvidia.com/drive/driveworks-3.5/dwx_samples_building_V5L.html.
$ cd $HOME
$ mkdir build
$ cd build
$ cmake -DCMAKE_BUILD_TYPE=Release  -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks-3.5/samples/cmake/Toolchain-V5L.cmake -DVIBRANTE_PDK:STRING=/path/to/drive-t186ref-linux -DTRT_VERSION:STRING=6.3.1.3 /usr/local/driveworks-3.5/samples/
$ make -j
$ make install
Hello SivaRamaKrishnaNV,
Thank you for your help.
My problem seemed to be due to not having driveworks_cross_linux–drive-linux-.deb installed on my host system.
After installing this I was able to run cmake.
Thank you,
Sakamoto
Ok. You need to select flashing target as well when you install using sdkmanager. It installs the required cross compilation setup on host
