Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
[y] NVIDIA DRIVE™ Software 10.0 (Linux)
other DRIVE OS version
other
Target Operating System
[y] Linux
QNX
other
Hardware Platform
[y] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
[y] 1.7.0.8846
other
Host Machine Version
[y] native Ubuntu 18.04
other
So I am trying to do cross compiling of dw samples using the tutorial here:
https://docs.nvidia.com/drive/driveworks-3.5/dwx_samples_building_V5L.html
But I am getting an error as:
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
CMake Error at CMakeLists.txt:16 (project):
The CMAKE_C_COMPILER:
/../toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc
is not a full path to an existing compiler tool.
Tell CMake where to find the compiler by setting either the environment
variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
the compiler, or to the compiler name if it is in the PATH.
The CMAKE_CXX_COMPILER:
/../toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++
variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
to the compiler, or to the compiler name if it is in the PATH.
The command I used was:
ai@ai-PC:~/nvidia/dw_samples/build-agx$ cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks-2.2/samples/cmake/Toolchain-V5L.cmake -DCVIBRANTE_PDK:STRING=/home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux .. -DTRT_VERSION:STRING=6.3.1.3 /usr/local/driveworks-2.2/samples/src
this thread talks about the same problem:
But I tried re-flashing using nvidia SDK manager, but to no avail, any help will be appreciated. Thanks.
I am fairly new to NVIDIA, Drive and making these topic threads, if I should have created this thread somewhere else, feel free to let me know I will delete/close it and re-ask somewhere else.
