Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
CMake Error: CMake was unable to find a build program corresponding to “Unix Makefiles”. CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
– Configuring incomplete, errors occurred!
Hi, @mohammed.el-yaagoubi
Is /home/melyaagoubi/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/ the right directory? Were the target components installed successfully via SDK Manager ?
Have you cross-compiled successfully before?
DriveWorks 4.0 was released. Would you like to move to DRIVE OS 5.2.6 and DriveWorks 4.0?
Yes AGX DRIVE is the right target and all the components were successfully installed via SDK Manager.
I have already done a cross-compilation before.
No I would like to keep DRIVE OS 5.2.0 and DriveWorks 3.5
Please remove the line ending slash of your DVIBRANTE_PDK path in your command and try again.
change from:
to:
