Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Dear @kansai,
Have you used the same host to flash target? If so, it is expected to install the necessary packages for cross compilation during setup using sdkmanager. Please find the drive-t186ref-linux folder at <PATH_TO_DRIVEOS>/drive-t186ref-linux. The default installation will be at ~/nvidia/
Actually the SDK Manager only installed CUDA CUDA\X AI Cmake and developer tools. I had to manually install drive works crosscompilation libraries by my self
I found the folder at /home/user/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER\DRIVEOS/
I suppose now I have to set the variable by export?
Dear @kansai,
Does that mean flashing via sdkmanager resulted in errors?
Please use path to drive-t186ref-linux as /home/user/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER\DRIVEOS/drive-t186ref-linuxin DW cross compilation instructions
I tried to crosscompile the samples (that I copied to my own directory in my user directory) dw_samples/src by doing the cmake listed in the docs but I got an error
Could not find a package configuration file provided by
driveworks_visualization with any of the following names
driveworks_visualizationConfig/cmake
driveworks_visualization-config.cmake
Add the installation prefix of driveworks_visualization to CMAKE_PREFIX_PATH or ser driveworks_visualization_DIR to a directory containing one of the above files
Dear @kansai,
Could you just create a new build folder(use original DW samples installed path instead of creating a copy) and let us know if it works without any issue? If you want to modify/add sample you can create a sample under /usr/local/driveworks-3.5/samples/ and update the make files accordingly.
Thanks. I edited one source file from an example, and with that I could build it.
I would have like to create a sample under /usr/local/driveworks-3.5/samples as you said, but what make files should I update?
and in the future, I would like to create programs under my own user folder, so I wonder what should I modify (I suspect some CMake file) in order to build it correctly?
Dear @kansai,
You need to create a sample similar to other samples at /usr/local/driveworks-3.5/samples/src and update the below SAMPLES variable at /usr/local/driveworks-4.0/samples/CMakeLists.txt accordingly
If you adding your samples under one of the folder(like under samples/src/dnn), You need to make sure to add the add_subdirectory()in corresponding CMakeLists.txt (like samples/src/dnn/CMakeLists.txt)
