Hey,
For a standard GEMM routine C = alpha(AB) + betaC, with dimensions A=MxK, B=KxN and C=MxN, what are the constraints of M, N and K for 8bit integer operations. I remember reading somewhere that M, N and K need to be a multiple of 4, but I can’t find that reference anywhere.
Furthermore I tested with no transpose (M= 4, N= 1, K = 4) works.
Could someone please give me constraint information on M, N and K for 8 bit integers, and if there is a way to avoid it with a different Cutlas routine?
Cheers,
Nick
pp reference code:
#include <cublas_v2.h>
#include <cuda_runtime.h>
#include <iostream>
#include <stdio.h>
#include <array>
#include <vector>
#include <random>
#include <math.h>
#include <cutlass/gemm/device/gemm.h>
cudaError_t cutlass_igemm_nn(
int M,
int N,
int K,
float alpha,
int8_t const *A,
int lda,
int8_t const *B,
int ldb,
float beta,
int32_t *C,
int ldc) {
// Define type definition for single-precision CUTLASS GEMM with column-major
// input matrices and 128x128x8 threadblock tile size (chosen by default).
// To keep the interface manageable, several helpers are defined for plausible compositions
// including the following example for single-precision GEMM. Typical values are used as
// default template arguments. See `cutlass/gemm/device/default_gemm_configuration.h` for more details.
// To view the full gemm device API interface, see `cutlass/gemm/device/gemm.h`
using ColumnMajor = cutlass::layout::ColumnMajor;
//using RowMajor = cutlass::layout::RowMajor;
using CutlassGemm = cutlass::gemm::device::Gemm<int8_t, // Data-type of A matrix
ColumnMajor, // Layout of A matrix
int8_t, // Data-type of B matrix
ColumnMajor, // Layout of B matrix
int32_t, // Data-type of C matrix
ColumnMajor>; // Layout of C matrix
// Define a CUTLASS GEMM type
CutlassGemm gemm_operator;
// Construct the CUTLASS GEMM arguments object.
// One of CUTLASS's design patterns is to define gemm argument objects that are constructible
// in host code and passed to kernels by value. These may include pointers, strides, scalars,
// and other arguments needed by Gemm and its components.
// The benefits of this pattern are (1.) a structured, composable strategy for passing host-constructible
// arguments to kernels and (2.) minimized initialization overhead on kernel entry.
CutlassGemm::Arguments args({M , N, K}, // Gemm Problem dimensions
{A, lda}, // Tensor-ref for source matrix A
{B, ldb}, // Tensor-ref for source matrix B
{C, ldc}, // Tensor-ref for source matrix C
{C, ldc}, // Tensor-ref for destination matrix D (may be different memory than source C matrix)
{alpha, beta}); // Scalars used in the Epilogue
// Launch the CUTLASS GEMM kernel.
cutlass::Status status = gemm_operator(args);
// Return a cudaError_t if the CUTLASS GEMM operator returned an error code.
if (status != cutlass::Status::kSuccess) {
return cudaErrorUnknown;
// Return success, if no errors were encountered.
return cudaSuccess;
__global__ void quantize(const float * input, int8_t * output, size_t items, float quantMult) {
size_t x = blockIdx.x * blockDim.x + threadIdx.x;
if (x < items) {
output[x] = (int8_t)llrintf((input[x]*quantMult));
//printf("%d Input: %f, output %d\n", x, input[x], (int8_t)llrintf((input[x]*quantMult)));
template<class intType>
__global__ void dequantize(intType * input, float * output, size_t items, float dequantMult) {
if (x < items)
output[x] = ((float)input[x])*dequantMult;
__global__ void findMaxMin(const float * input_gpu, int idxMax, int idxMin, float * output) {
float absMax = abs(input_gpu[idxMax]);
float absMin = abs(input_gpu[idxMin]);
if (absMax > absMin) {
output[0] = absMax;
} else {
output[0] = absMin;
//@TODO rewrite with a nice singlePass GPU version that uses shared memory
float maxAbs(cublasHandle_t& handle, const float * input_gpu, size_t items, float * scratchMem) {
//Get Max Absolute:
int resMaxIdx;
(cublasIsamax(handle, items, input_gpu, 1, &resMaxIdx));
int resMinIdx;
(cublasIsamin(handle, items, input_gpu, 1, &resMinIdx));
float * output_gpu;
if (scratchMem) {
output_gpu = scratchMem;
} else {
(cudaMalloc(&output_gpu, 1*sizeof(float)));
findMaxMin<<<1,1>>>(input_gpu, resMaxIdx - 1, resMinIdx - 1, output_gpu); //FUCK YOU FORTRAN INDEXING
cudaDeviceSynchronize(); //Not necessary due to subsequent call to CudaMemcpy
float output;
(cudaMemcpy(&output, &output_gpu[0], 1*sizeof(float), cudaMemcpyDeviceToHost));
if (!scratchMem) {
(cudaFree(output_gpu));
return output;
void printGPUMatrix(const float * mat, size_t rows, size_t cols) { //Since they are col major printing is a bit weird
std::vector<float> cpuMat(rows*cols, 2.0f);
(cudaMemcpy(&cpuMat[0], mat, rows*cols*sizeof(float), cudaMemcpyDeviceToHost));
for (int i = 0; i<rows; i++) {
for (int j = 0; j< cols; j++) {
printf("%f ", cpuMat[rows*j +i]);
printf("\n");
void printGPUMatrix(float * mat, size_t rows, size_t cols) { //Since they are col major printing is a bit weird
printf("\n");
void printGPUMatrix(int8_t * mat, size_t rows, size_t cols) { //Since they are col major printing is a bit weird
std::vector<int8_t> cpuMat(rows*cols, 2.0);
(cudaMemcpy(&cpuMat[0], mat, rows*cols*sizeof(int8_t), cudaMemcpyDeviceToHost));
printf("%d ", (int)cpuMat[rows*j +i]);
printf("\n");
cublasStatus_t cublas8bitGemmmEx(cublasHandle_t handle,
cublasOperation_t transa,
cublasOperation_t transb,
int m, int n, int k,
const float* alpha,
const float* A, int lda,
const float* B, int ldb,
const float* beta,
float* C, int ldc) {
auto algorithm = CUBLAS_GEMM_DEFAULT_TENSOR_OP;
auto res = cublasGemmEx(handle, transa, transb,
m, n, k, alpha,
A, CUDA_R_32F, lda,
B, CUDA_R_32F, ldb, beta,
C, CUDA_R_32F, ldc,
CUDA_R_32F, algorithm);
printf("True matrix\n");
printGPUMatrix(C, m, n);
printf("Fake matrix\n\n");
//return res;
if (true || (m%4 == 0 && n % 4 == 0 && k % 4 ==0)) {
int rowsA = m;
int colsA = k;
int rowsB = k;
int colsB = n;
int rowsC = m;
int colsC = n;
// Make sure that we have enough threads so that kernel launches don't fail
if (colsA > 512) {
std::swap(rowsA, colsA);
if (colsA > 512) {
fprintf(stderr, "Incompatible sizes: rows %d, cols %d\n", rowsA, colsA);
if (colsB > 512) {
std::swap(rowsB, colsB);
if (colsB > 512) {
fprintf(stderr, "Incompatible sizes: rows %d, cols %d\n", rowsB, colsB);
if (colsC > 512) {
std::swap(rowsC, colsC);
if (colsC > 512) {
fprintf(stderr, "Incompatible sizes: rows %d, cols %d\n", rowsC, colsC);
int32_t alpha_int = static_cast<int32_t>(*alpha);
int32_t beta_int = static_cast<int32_t>(*beta);
int8_t* in8bitIntA;
int8_t* in8bitIntB;
int32_t * out32bitInt;
(cudaMalloc(&out32bitInt, m*n*sizeof(int32_t)));
(cudaMalloc(&in8bitIntA, m*k*sizeof(int8_t)));
(cudaMalloc(&in8bitIntB, k*n*sizeof(int8_t)));
float aMaxAbs = maxAbs(handle, A, m*k, nullptr);
float bMaxAbs = maxAbs(handle, B, k*n, nullptr);
(cudaDeviceSynchronize());
fprintf(stderr, "MaxAbs A: %f, MaxAbs B: %f\n", aMaxAbs, bMaxAbs);
quantize<<<rowsA, colsA>>>(A, in8bitIntA, m*k, 127.0f/aMaxAbs);
(cudaGetLastError());
(cudaDeviceSynchronize()); //Shouldn't be necessary
quantize<<<rowsB, colsB>>>(B, in8bitIntB, k*n, 127.0f/bMaxAbs);
/* TEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEST
printf("A:\n");
printGPUMatrix(A, rowsA, colsA);
printf("A_quant:\n");
printGPUMatrix(in8bitIntA, rowsA, colsA);
printf("A_unquant:\n");
float *A_restored;
cudaMalloc(&A_restored, m*k*sizeof(float));
dequantize<<<rowsA, colsA>>>(in8bitIntA, A_restored, m*k, (aMaxAbs/127.0f));
printGPUMatrix(A_restored, rowsA, colsA);
cudaFree(A_restored);
printf("FAKE\n\n\n\n");
EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEND*/
m, n, k, &alpha_int,
in8bitIntA, CUDA_R_8I, lda,
in8bitIntB, CUDA_R_8I, ldb, &beta_int,
out32bitInt, CUDA_R_32I, ldc,
CUDA_R_32I, algorithm);
dequantize<<<rowsC, colsC>>>(out32bitInt, C, m*n, (aMaxAbs/127.0f)*(bMaxAbs/127.0f) );
//Free temporary used memory
(cudaFree(out32bitInt));
(cudaFree(in8bitIntA));
(cudaFree(in8bitIntB));
return res;
cudaError_t cutlas8bitGemmmEx(cublasHandle_t handle,
const float* alpha,
const float* beta,
cudaError_t res;
int rowsA = m;
int colsA = k;
int rowsB = k;
int colsB = n;
int rowsC = m;
int colsC = n;
if (colsA > 512) {
if (colsA > 512) {
if (colsB > 512) {
if (colsB > 512) {
if (colsC > 512) {
if (colsC > 512) {
int8_t* in8bitIntA;
int8_t* in8bitIntB;
//CUTLASS GEMM
res = cutlass_igemm_nn(
m, n, k, *alpha,
in8bitIntA,
lda,
in8bitIntB,
ldb,
*beta,
out32bitInt,
ldc);
return res;
#define M 4
#define N 1
#define K 4
int main() {
int m = M;
int n = N;
int k = K;
std::mt19937 gen;
// Go somewhat out of range too.
std::uniform_real_distribution<float> dist(-2, 2);
std::vector<float> A_cpu(m*k, 0);
std::vector<float> B_cpu(k*n, 0);
for (auto&& num : A_cpu) {
num = dist(gen);
for (auto&& num : B_cpu) {
num = dist(gen);
//GPU alloc
float * A;
float * B;
float * C;
(cudaMalloc(&A, m*k*sizeof(float)));
(cudaMalloc(&B, k*n*sizeof(float)));
(cudaMalloc(&C, m*n*sizeof(float)));
(cudaMemcpy(A, &A_cpu[0], m*k*sizeof(float), cudaMemcpyHostToDevice));
(cudaMemcpy(B, &B_cpu[0], k*n*sizeof(float), cudaMemcpyHostToDevice));
//Cublas handle
cublasHandle_t handle;
(cublasCreate(&handle));
//lda, ldb, ldc, transposes etc
//auto transa = CUBLAS_OP_T;
//auto transb = CUBLAS_OP_T;
auto transa = CUBLAS_OP_N;
auto transb = CUBLAS_OP_N;
int lda = m;//k; maybe true fro tranposes
int ldb = k;//n;
int ldc = m;//n;
const float alpha = 1;
const float beta = 0;
fprintf(stderr, "\n\nCuBlas\n");
auto res2 = cublas8bitGemmmEx(handle,
transa,
transb,
m, n, k,
&alpha,
A, lda,
B, ldb,
&beta,
C, ldc);
if (res2 != CUBLAS_STATUS_SUCCESS) {
fprintf(stderr, "ERROR Cublass did not run!");
} else {
fprintf(stderr, "\n\nCutlass\n");
auto res = cutlas8bitGemmmEx(handle,
m, n, k,
&alpha,
A, lda,
B, ldb,
&beta,
C, ldc);
if (res != cudaSuccess) {
fprintf(stderr, "ERROR Cutlass");
