I am new to CUDA and to start with I am trying to execute a simple CUBLAS program given in the SDK. The code simpleCUBLAS.c is given below for your reference.
When I am compiling the code as: nvcc -deviceemu -lcublas simpleCUBLAS.c -o output I am getting the following message;
simpleCUBLAS test running…
!!! CUBLAS initialization error
Is this happening because I don’t have any GPU? If yes why is the Emulation not successful here even though I can run many other CUDA program in emulation mode?
I shall be thankful to your replies,
Thanks,
Geetansh
//simpleCUBLAS.c
/* Includes, system */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
/* Includes, cuda */
#include "cublas.h"
/* Matrix size */
#define N (275)
/* Host implementation of a simple version of sgemm */
static void simple_sgemm(int n, float alpha, const float *A, const float *B,
float beta, float *C)
int i;
int j;
int k;
for (i = 0; i < n; ++i) {
for (j = 0; j < n; ++j) {
float prod = 0;
for (k = 0; k < n; ++k) {
prod += A[k * n + i] * B[j * n + k];
C[j * n + i] = alpha * prod + beta * C[j * n + i];
/* Main */
int main()
cublasStatus status;
float* h_A;
float* h_B;
float* h_C;
float* h_C_ref;
float* d_A = 0;
float* d_B = 0;
float* d_C = 0;
float alpha = 1.0f;
float beta = 0.0f;
int n2 = N * N;
int i;
float error_norm;
float ref_norm;
float diff;
/* Initialize CUBLAS */
printf("simpleCUBLAS test running..\n");
status = cublasInit();
if (status != CUBLAS_STATUS_SUCCESS) {
fprintf (stderr, "!!!! CUBLAS initialization error\n");
return EXIT_FAILURE;
/* Allocate host memory for the matrices */
h_A = (float*)malloc(n2 * sizeof(h_A[0]));
if (h_A == 0) {
fprintf (stderr, "!!!! host memory allocation error (A)\n");
h_B = (float*)malloc(n2 * sizeof(h_B[0]));
if (h_B == 0) {
fprintf (stderr, "!!!! host memory allocation error (B)\n");
h_C = (float*)malloc(n2 * sizeof(h_C[0]));
if (h_C == 0) {
fprintf (stderr, "!!!! host memory allocation error (C)\n");
/* Fill the matrices with test data */
for (i = 0; i < n2; i++) {
h_A[i] = rand() / (float)RAND_MAX;
h_B[i] = rand() / (float)RAND_MAX;
h_C[i] = rand() / (float)RAND_MAX;
/* Allocate device memory for the matrices */
status = cublasAlloc(n2, sizeof(d_A[0]), (void**)&d_A);
fprintf (stderr, "!!!! device memory allocation error (A)\n");
status = cublasAlloc(n2, sizeof(d_B[0]), (void**)&d_B);
fprintf (stderr, "!!!! device memory allocation error (B)\n");
status = cublasAlloc(n2, sizeof(d_C[0]), (void**)&d_C);
fprintf (stderr, "!!!! device memory allocation error (C)\n");
/* Initialize the device matrices with the host matrices */
status = cublasSetVector(n2, sizeof(h_A[0]), h_A, 1, d_A, 1);
fprintf (stderr, "!!!! device access error (write A)\n");
status = cublasSetVector(n2, sizeof(h_B[0]), h_B, 1, d_B, 1);
fprintf (stderr, "!!!! device access error (write B)\n");
status = cublasSetVector(n2, sizeof(h_C[0]), h_C, 1, d_C, 1);
fprintf (stderr, "!!!! device access error (write C)\n");
/* Performs operation using plain C code */
simple_sgemm(N, alpha, h_A, h_B, beta, h_C);
h_C_ref = h_C;
/* Clear last error */
cublasGetError();
/* Performs operation using cublas */
cublasSgemm('n', 'n', N, N, N, alpha, d_A, N, d_B, N, beta, d_C, N);
status = cublasGetError();
fprintf (stderr, "!!!! kernel execution error.\n");
/* Allocate host memory for reading back the result from device memory */
if (h_C == 0) {
/* Read the result back */
status = cublasGetVector(n2, sizeof(h_C[0]), d_C, 1, h_C, 1);
fprintf (stderr, "!!!! device access error (read C)\n");
/* Check result against reference */
error_norm = 0;
ref_norm = 0;
for (i = 0; i < n2; ++i) {
diff = h_C_ref[i] - h_C[i];
error_norm += diff * diff;
ref_norm += h_C_ref[i] * h_C_ref[i];
error_norm = (float)sqrt((double)error_norm);
ref_norm = (float)sqrt((double)ref_norm);
if (fabs(ref_norm) < 1e-7) {
fprintf (stderr, "!!!! reference norm is 0\n");
printf( "Test %s\n", (error_norm / ref_norm < 1e-6f) ? "PASSED" : "FAILED");
/* Memory clean up */
free(h_A);
free(h_B);
free(h_C);
free(h_C_ref);
status = cublasFree(d_A);
fprintf (stderr, "!!!! memory free error (A)\n");
status = cublasFree(d_B);
fprintf (stderr, "!!!! memory free error (B)\n");
status = cublasFree(d_C);
fprintf (stderr, "!!!! memory free error (C)\n");
/* Shutdown */
status = cublasShutdown();
fprintf (stderr, "!!!! shutdown error (A)\n");
