Hello!
I’m trying to run the ‘simple CUBLAS’ program that can be found in the CUDA SDK, and i’m having trouble in trying to run the code. Here are the following steps i’ve taken to start the project.
Create a new Win32 Console Application (Visual C++>Win32>Win32 Console Application)
Type in the same code that can be found in the simpleCUBLAS eg.
I copy the following header files into my project folder:
a. cublas.h
b. cuComplex.h
c. vector_types.h
d. host_defines.h
e. cuda.h
f. resource.h
The source code is as shown.
The header files are also included under the ‘Header Files’ in the Solution Explorer.
Finally, I build the project under ‘Debug’ Mode and run.
Source Code (same as simpleCUBLAS, but just in case):
[codebox]//This program is taken from SDK. multiplies two matrices A and B and stores the result in C.
#include “stdio.h”
#include <stdlib.h>
#include <cublas.lib>
#include “cuda.lib”
#include <string.h>
#include “stdafx.h”
/* Includes, cuda */
#include “cublas.h”
#include “cuda.h”
/* Matrix size */
#define N (275)
/* Host implementation of a simple version of sgemm This program you guys have already done*/
static void simple_sgemm(int n, float alpha, const float *A, const float *B,float beta, float *C)
int i;
int j;
int k;
for (i = 0; i < n; ++i) {
for (j = 0; j < n; ++j) {
float prod = 0;
for (k = 0; k < n; ++k) {
prod += A[k * n + i] * B[j * n + k];
C[j * n + i] = alpha * prod + beta * C[j * n + i];
/* Main, as usual */
int main()
//int main(int argc, char** argv)
cublasStatus status;
float* h_A;
float* h_B;
float* h_C;
float* h_C_ref;
float* d_A = 0;
float* d_B = 0;
float* d_C = 0;
float alpha = 1.0f;
float beta = 0.0f;
int n2 = N * N;
int i;
float error_norm;
float ref_norm;
float diff;
/* Initialize CUBLAS */
printf("simpleCUBLAS test running..\n");
status = cublasInit();
if (status != CUBLAS_STATUS_SUCCESS) {
fprintf (stderr, "!!!! CUBLAS initialization error\n");
return EXIT_FAILURE;
/* Allocate host memory for the matrices */
h_A = (float*)malloc(n2 * sizeof(h_A[0]));
if (h_A == 0) {
fprintf (stderr, "!!!! host memory allocation error (A)\n");
h_B = (float*)malloc(n2 * sizeof(h_B[0]));
if (h_B == 0) {
fprintf (stderr, "!!!! host memory allocation error (B)\n");
h_C = (float*)malloc(n2 * sizeof(h_C[0]));
if (h_C == 0) {
fprintf (stderr, "!!!! host memory allocation error ©\n");
/* Fill the matrices with test data */
for (i = 0; i < n2; i++) {
h_A[i] = rand() / (float)RAND_MAX;
h_B[i] = rand() / (float)RAND_MAX;
h_C[i] = rand() / (float)RAND_MAX;
/* Allocate device memory for the matrices */
status = cublasAlloc(n2, sizeof(d_A[0]), (void**)&d_A);
fprintf (stderr, "!!!! device memory allocation error (A)\n");
status = cublasAlloc(n2, sizeof(d_B[0]), (void**)&d_B);
fprintf (stderr, "!!!! device memory allocation error (B)\n");
status = cublasAlloc(n2, sizeof(d_C[0]), (void**)&d_C);
fprintf (stderr, "!!!! device memory allocation error ©\n");
/* Initialize the device matrices with the host matrices */
status = cublasSetVector(n2, sizeof(h_A[0]), h_A, 1, d_A, 1);
fprintf (stderr, "!!!! device access error (write A)\n");
status = cublasSetVector(n2, sizeof(h_B[0]), h_B, 1, d_B, 1);
fprintf (stderr, "!!!! device access error (write B)\n");
status = cublasSetVector(n2, sizeof(h_C[0]), h_C, 1, d_C, 1);
fprintf (stderr, "!!!! device access error (write C)\n");
/* Performs operation using plain C code */
simple_sgemm(N, alpha, h_A, h_B, beta, h_C);
h_C_ref = h_C;
/* Clear last error */
cublasGetError();
/* Performs operation using cublas */
cublasSgemm('n', 'n', N, N, N, alpha, d_A, N, d_B, N, beta, d_C, N);
status = cublasGetError();
fprintf (stderr, "!!!! kernel execution error.\n");
/* Allocate host memory for reading back the result from device memory */
if (h_C == 0) {
/* Read the result back */
status = cublasGetVector(n2, sizeof(h_C[0]), d_C, 1, h_C, 1);
fprintf (stderr, "!!!! device access error (read C)\n");
/* Check result against reference */
error_norm = 0;
ref_norm = 0;
for (i = 0; i < n2; ++i) {
diff = h_C_ref[i] - h_C[i];
error_norm += diff * diff;
ref_norm += h_C_ref[i] * h_C_ref[i];
error_norm = (float)sqrt((double)error_norm);
ref_norm = (float)sqrt((double)ref_norm);
if (fabs(ref_norm) < 1e-7) {
fprintf (stderr, "!!!! reference norm is 0\n");
printf( "Test %s\n", (error_norm / ref_norm < 1e-6f) ? "PASSED" : "FAILED");
/* Memory clean up */
free(h_A);
free(h_B);
free(h_C);
free(h_C_ref);
status = cublasFree(d_A);
fprintf (stderr, "!!!! memory free error (A)\n");
status = cublasFree(d_B);
fprintf (stderr, "!!!! memory free error (B)\n");
status = cublasFree(d_C);
fprintf (stderr, "!!!! memory free error ©\n");
/* Shutdown */
status = cublasShutdown();
fprintf (stderr, "!!!! shutdown error (A)\n");
/* if (argc > 1) {
if (!strcmp(argv[1], "-noprompt") ||
!strcmp(argv[1], "-qatest") )
return EXIT_SUCCESS;
else
printf("\nPress ENTER to exit...\n");
getchar();
// return EXIT_SUCCESS;
[/codebox]
Have a look at the errors i get. I’m running Windows 7 32bit, and Visual Studio 2008.
So what could possibly be wrong/missing? Please have a look and thanks in advance for your help!
