cannot compile with cublas code in kernel
i’m try to make a kernel with cublas code in it. i couldn’t pass th first step. I am using toolkit 9.2 and visual studio 2017
here is the code
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <helper_cuda.h>
#include <device_functions.h>
#include <cuda.h>
#include <cublas_v2.h>
__constant__ long		n_d;
__global__ void solve_linear_system_without_partial_pivot(void* buffer)
	__shared__ int n;
	__shared__ double* d_A;
	cublasHandle_t cnpHandle;
	cublasCreate(&cnpHandle);
int main ()
	return 0;
And here is some part of the detailed compile error log informations.
1> Initializing task factory “XamlTaskFactory” from assembly “Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Using “CudaCompile” task from the task factory “XamlTaskFactory”.
1> Task “CudaCompile”
1> Task Parameter:StandardOutputImportance=High
1> Task Parameter:LogStandardErrorAsError=False
1> Task Parameter:CompileOut=x64\Debug\kernel.cu.obj
1> Task Parameter:Include=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include
1> Task Parameter:GenerateRelocatableDeviceCode=False
1> Task Parameter:NvccCompilation=compile
1> Task Parameter:CudaRuntime=Static
1> Task Parameter:NvccPath=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\bin\nvcc.exe
1> Task Parameter:RequiredIncludes=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include
1> Task Parameter:TargetMachinePlatform=64
1> Task Parameter:InterleaveSourceInPTX=False
1> Task Parameter:CodeGeneration=arch=compute_61,code="sm_61,compute_61"
1> Task Parameter:GPUDebugInfo=True
1> Task Parameter:GenerateLineInfo=False
1> Task Parameter:Keep=False
1> Task Parameter:KeepDir=x64\Debug
1> Task Parameter:MaxRegCount=0
1> Task Parameter:PtxAsOptionV=False
1> Task Parameter:
1> Defines=
1> WIN32
1> WIN64
1> _DEBUG
1> _CONSOLE
1> _MBCS
1> Task Parameter:Emulation=False
1> Task Parameter:HostDebugInfo=True
1> Task Parameter:FastMath=False
1> Task Parameter:Optimization=Od
1> Task Parameter:ProgramDataBaseFileName=x64\Debug\vc141.pdb
1> Task Parameter:Runtime=MDd
1> Task Parameter:RuntimeChecks=RTC1
1> Task Parameter:Warning=W3
1> Task Parameter:CommandLineTemplate=“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\bin\nvcc.exe” [CodeGeneration] --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\HostX86\x64” -x cu [GenerateRelocatableDeviceCode] [Include] [RequiredIncludes] [InterleaveSourceInPTX] [GPUDebugInfo] [GenerateLineInfo] [Keep] [KeepDir] [MaxRegCount] [PtxAsOptionV] [TargetMachinePlatform] [NvccCompilation] [CudaRuntime] [AdditionalOptions] [HostDebugInfo] [Emulation] [FastMath] [Defines] -Xcompiler “/EHsc [Warning] /nologo [Optimization] [ProgramDataBaseFileName] /FS /Zi [RuntimeChecks] [Runtime] [TypeInfo]” [CompileOut] “C:\Users\tevfikoguz\source\repos\cuda_sil_3\cuda_sil_3\kernel.cu”
1> cmd.exe /C “C:\Users\tevfikoguz\AppData\Local\Temp\tmp2fc3bea90af3449f8e23d905eb5768aa.cmd”
1> “C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\bin\nvcc.exe” -gencode=arch=compute_61,code="sm_61,compute_61" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\HostX86\x64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -D"WIN32" -D"WIN64" -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Fdx64\Debug\vc141.pdb /FS /Zi /RTC1 /MDd " -o x64\Debug\kernel.cu.obj “C:\Users\tevfikoguz\source\repos\cuda_sil_3\cuda_sil_3\kernel.cu”
1>
1> C:\Users\tevfikoguz\source\repos\cuda_sil_3\cuda_sil_3>“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\bin\nvcc.exe” -gencode=arch=compute_61,code="sm_61,compute_61" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\HostX86\x64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -D"WIN32" -D"WIN64" -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Fdx64\Debug\vc141.pdb /FS /Zi /RTC1 /MDd " -o x64\Debug\kernel.cu.obj “C:\Users\tevfikoguz\source\repos\cuda_sil_3\cuda_sil_3\kernel.cu”
1> C:/Users/tevfikoguz/source/repos/cuda_sil_3/cuda_sil_3/kernel.cu(14): warning : variable “n” was declared but never referenced
1>
1> C:/Users/tevfikoguz/source/repos/cuda_sil_3/cuda_sil_3/kernel.cu(15): warning : variable “d_A” was declared but never referenced
1>
1> ptxas fatal : Unresolved extern function ‘cublasCreate_v2’
1> kernel.cu
1> C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\BuildCustomizations\CUDA 9.2.targets(712,9): error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\bin\nvcc.exe” -gencode=arch=compute_61,code="sm_61,compute_61" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\HostX86\x64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include” -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -D"WIN32" -D"WIN64" -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Fdx64\Debug\vc141.pdb /FS /Zi /RTC1 /MDd " -o x64\Debug\kernel.cu.obj “C:\Users\tevfikoguz\source\repos\cuda_sil_3\cuda_sil_3\kernel.cu”” exited with code 255.
1> Done executing task “CudaCompile” – FAILED.
1> Done building target “CudaBuildCore” in project “cuda_sil_3.vcxproj” – FAILED.
1>
1> Done building project “cuda_sil_3.vcxproj” – FAILED.
1> Done executing task “MSBuild” – FAILED.
1>Done building target “CudaBuild” in project “cuda_sil_3.vcxproj” – FAILED.
1>
1>Done building project “cuda_sil_3.vcxproj” – FAILED.
1>
1>Project Performance Summary:
1> * ms C:\Users\tevfikoguz\source\repos\cuda_sil_3\cuda_sil_3\cuda_sil_3.vcxproj 1 calls
1> (* = timing was not recorded because of reentrancy)
1>
1>Target Performance Summary:
1> 0 ms _PrepareForReferenceResolution 1 calls
1> 0 ms ResolveReferences 1 calls
1> 0 ms ResolveAssemblyReferences 1 calls
1> 0 ms ExpandSDKReferences 1 calls
1> 0 ms ResolveSDKReferences 1 calls
1> 0 ms BeforeResolveReferences 1 calls
1> 0 ms _PrepareForBuild 1 calls
1> 0 ms Clean 1 calls
1> 0 ms ValidateCudaBuild 1 calls
1> 0 ms PreBuildEvent 1 calls
1> 0 ms PGInstrumentedClean 1 calls
1> 0 ms AfterCppClean 1 calls
1> 0 ms AfterClean 1 calls
1> 0 ms CppClean 1 calls
1> 0 ms BeforeBuildGenerateSources 1 calls
1> 0 ms AddCudaLinkMetadata 1 calls
1> 0 ms PrepareProjectReferences 1 calls
1> 0 ms _SplitProjectReferencesByFileExistence 1 calls
1> 0 ms CleanPublishFolder 1 calls
1> 0 ms BeforeClean 1 calls
1> 0 ms _SelectedFiles 1 calls
1> 0 ms AfterResolveReferences 1 calls
1> 0 ms BeforeRebuild 1 calls
1> 0 ms PlatformPrepareForBuild 1 calls
1> 1 ms _CheckWindowsSDKInstalled 1 calls
1> 1 ms GetReferenceAssemblyPaths 1 calls
1> 1 ms CleanReferencedProjects 1 calls
1> 1 ms GetResolvedWinMD 1 calls
1> 1 ms SetCABuildNativeEnvironmentVariables 1 calls
1> 1 ms BeforeCppClean 1 calls
1> 2 ms GetFrameworkPaths 1 calls
1> 2 ms ValidateCudaCodeGeneration 1 calls
1> 3 ms PrepareForCudaBuild 2 calls
1> 3 ms SetBuildDefaultEnvironmentVariables 2 calls
1> 4 ms PrepareForBuild 1 calls
1> 4 ms InitializeBuildStatus 1 calls
1> 4 ms BuildGenerateSourcesTraverse 1 calls
1> 6 ms InitializeCudaProjectProperties 1 calls
1> 7 ms InitializeCudaHostProperties 1 calls
1> 7 ms ComputeCudaCompileOutput 1 calls
1> 11 ms _HandlePackageFileConflicts 1 calls
1> 12 ms AssignProjectConfiguration 1 calls
1> 13 ms SetTelemetryEnvironmentVariables 1 calls
1> 15 ms _GetProjectReferenceTargetFrameworkProperties 1 calls
1> 17 ms CoreCppClean 1 calls
1> 17 ms ResolveProjectReferences 1 calls
1> 23 ms _PrepareForRebuild 1 calls
1> 26 ms _PrepareForClean 1 calls
1> 29 ms AddCudaCompilePropsDeps 1 calls
1> 32 ms CoreClean 1 calls
1> 41 ms AddCudaCompileMetadata 1 calls
1> 81 ms _CheckForInvalidConfigurationAndPlatform 1 calls
1> 865 ms AddCudaCompileDeps 1 calls
1> 1355 ms CudaBuildCore 1 calls
1> 1501 ms CudaBuild 1 calls
1> 1936 ms CudaClean 1 calls
1>
1>Task Performance Summary:
1> 0 ms ResolvePaths 1 calls
1> 0 ms CountItems 1 calls
1> 1 ms RemoveDuplicates 1 calls
1> 2 ms CudaSetEnvironmentVariable 2 calls
1> 2 ms SanitizePaths 3 calls
1> 2 ms Touch 1 calls
1> 3 ms MakeDir 5 calls
1> 6 ms WriteLinesToFile 5 calls
1> 8 ms XmlPeek 1 calls
1> 10 ms AssignProjectConfiguration 1 calls
1> 10 ms ReadLinesFromFile 3 calls
1> 11 ms ResolvePackageFileConflicts 1 calls
1> 11 ms SetEnv 12 calls
1> 13 ms FindUnderPath 2 calls
1> 17 ms CppClean 1 calls
1> 19 ms SplitToItemMetadata 2 calls
1> 20 ms ReadMetadataLinesFromItems 1 calls
1> 27 ms Delete 5 calls
1> 30 ms Message 3 calls
1> 857 ms GenerateDeps 1 calls
1> 1507 ms MSBuild 2 calls
1> 2931 ms CudaCompile 2 calls
1>
1>Build FAILED.
1>
1>C:/Users/tevfikoguz/source/repos/cuda_sil_3/cuda_sil_3/kernel.cu(14): warning : variable “n” was declared but never referenced
1>C:/Users/tevfikoguz/source/repos/cuda_sil_3/cuda_sil_3/kernel.cu(15): warning : variable “d_A” was declared but never referenced
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\BuildCustomizations\CUDA 9.2.targets(712,9): error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\bin\nvcc.exe” -gencode=arch=compute_61,code="sm_61,compute_61" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\HostX86\x64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -D"WIN32" -D"WIN64" -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Fdx64\Debug\vc141.pdb /FS /Zi /RTC1 /MDd " -o x64\Debug\kernel.cu.obj “C:\Users\tevfikoguz\source\repos\cuda_sil_3\cuda_sil_3\kernel.cu”” exited with code 255.
1> 2 Warning(s)
1> 1 Error(s)
1>
1>Time Elapsed 00:00:04.70
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Your project is setup incorrectly.
  1. You need to be compiling for at least a cc3.5 or higher device.
  2. You need to use relocatable device code (-rdc=true)
  3. And you need to link against cublas_device (and possibly also cublas)
You are satisfying step 1 but don’t appear to be satisfying step 2 or 3.
I’m not going to try to give you detailed instructions to change your project settings to address steps 2 and 3.
Instead, study a CUDA sample project that has this setup, such as simpleDevLibCUBLAS
Also note that this cublas-from-kernel capability was deprecated and is now removed from newer versions of CUDA. So you won’t be able to build this code against CUDA 10.0 or any higher version of CUDA.
[url]Release Notes :: CUDA Toolkit Documentation
@robert_crovella, thank you for your answer.
i have GTX 1050 ti so i passed step 1,
i did changed relocatable device code to (-rcd=true) sp step 2 passed,
and i did added cublas.lib and cublas_device.lib step 3 passed
now i am stuck with bunck of “error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’” errors everywhere. (i left my code and like you said i tried to complied “simpleDevLibCUBLAS”)
here is the compliation commandlines of “simpleDevLibCUBLAS”
Target CudaBuild:
1> Task “MSBuild”
1> Overriding Global Properties for project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.2\7_CUDALibraries\simpleDevLibCUBLAS\simpleDevLibCUBLAS_vs2017.vcxproj” with:
1> Platform=x64
1> Configuration=Release
1> __CompileIn=C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.2\7_CUDALibraries\simpleDevLibCUBLAS\kernels.cu
1> __CompileRelativeDir=
1> __CompileFilename=kernels
1> __CompileOut=x64/Release/kernels.cu.obj
1> __ProjectDeps=
1> __Deps=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2/include\cuda_runtime.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_config.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_config.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\vcruntime.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\sal.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\concurrencysal.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\vadefs.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\limits.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\stddef.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\library_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\channel_descriptor.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\cuda_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\cuda_device_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\cuda_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\common_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/common_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\host_defines.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\string.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_memory.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_memcpy_s.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\errno.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\vcruntime_string.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_wstring.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\time.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_wtime.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\math_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\host_defines.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\math.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_math.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\stdlib.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_malloc.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_search.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_wstdlib.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\cmath;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\yvals.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\yvals_core.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xkeycheck.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\crtdefs.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\crtdbg.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\vcruntime_new_debug.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\vcruntime_new.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\use_ansi.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\cstdlib;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\math.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xtgmath.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xtr1common;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\math_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\cuda_surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\channel_descriptor.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\cuda_texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\channel_descriptor.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/device_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\device_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\device_double_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\device_double_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_20_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_32_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_35_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_32_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_60_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_20_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_30_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_32_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_35_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_32_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\sm_61_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\sm_70_rt.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\cuda_surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_fetch_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\cuda_texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_indirect_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_indirect_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\device_launch_parameters.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\stdio.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_wstdio.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_stdio_config.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2/include\cuda_runtime.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2/include\cublas_v2.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\cublas_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\cuComplex.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\math.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\vector_types.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2/include\cuda_fp16.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\cuda_fp16.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\library_types.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\stdint.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\fstream;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\istream;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\ostream;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\ios;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xlocnum;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\climits;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\cstdio;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\streambuf;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xiosbase;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xlocale;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\cstring;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\stdexcept;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\exception;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\type_traits;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xstddef;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\cstddef;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\initializer_list;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\malloc.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\vcruntime_exception.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\eh.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_terminate.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xstring;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xmemory0;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\cstdint;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\limits;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\ymath.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\cfloat;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\float.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\cwchar;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\wchar.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_wconio.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_wctype.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_wdirect.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_wio.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_share.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\corecrt_wprocess.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\sys/stat.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\sys/types.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\new;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xutility;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\utility;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\iosfwd;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xatomic0.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\intrin0.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\typeinfo;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\vcruntime_typeinfo.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xlocinfo;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xlocinfo.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\ctype.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\locale.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\memory;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xmemory;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xfacet;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\system_error;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\cerrno;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xcall_once.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xerrc.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.17763.0\ucrt\share.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\string;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\xstring_insert.h
1> __AdditionalDependencies=
1> __SelectedFilesDep=
1> __ExcludedFromBuild=
1> __ExecutionDescription=Compiling CUDA source file kernels.cu…
1> __ExclusionDescription=Skipping CUDA source file kernels.cu %28excluded from build%29.
1> __Api=Runtime
1> __AdditionalCompilerOptions=
1> __AdditionalDeps=
1> __Include=./;…/…/common/inc;./;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2/include;…/…/common/inc;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include
1> __GenerateRelocatableDeviceCode=true
1> __NvccCompilation=compile
1> __CudaRuntime=Static
1> __NvccPath=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\bin\nvcc.exe
1> __RequiredIncludes=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include
1> __TargetMachinePlatform=64
1> __InterleaveSourceInPTX=false
1> __CodeGeneration=arch=compute_35,code="sm_35,compute_35" arch=compute_37,code="sm_37,compute_37" arch=compute_50,code="sm_50,compute_50" arch=compute_52,code="sm_52,compute_52" arch=compute_60,code="sm_60,compute_60" arch=compute_61,code="sm_61,compute_61" arch=compute_70,code="sm_70,compute_70"
1> __GPUDebugInfo=false
1> __GenerateLineInfo=false
1> __Keep=false
1> __KeepDir=x64\Release
1> __MaxRegCount=0
1> __PtxAsOptionV=false
1> __Defines=WIN32 WIN32 _MBCS _MBCS
1> __Emulation=false
1> __HostDebugInfo=false
1> __FastMath=false
1> __Optimization=O2
1> __ProgramDataBaseFileName=x64/Release/vc141.pdb
1> __Runtime=MT
1> __RuntimeChecks=Default
1> __TypeInfo=
1> __Warning=W3
1> __AdditionalOptions=-Xcompiler “/wd 4819”
1> __CommandLineTemplate=“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\bin\nvcc.exe” [CodeGeneration] --use-local-env -ccbin “C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\HostX86\x64” -x cu [GenerateRelocatableDeviceCode] [Include] [RequiredIncludes] [InterleaveSourceInPTX] [GPUDebugInfo] [GenerateLineInfo] [Keep] [KeepDir] [MaxRegCount] [PtxAsOptionV] [TargetMachinePlatform] [NvccCompilation] [CudaRuntime] [AdditionalOptions] [HostDebugInfo] [Emulation] [FastMath] [Defines] -Xcompiler “/EHsc [Warning] /nologo [Optimization] [ProgramDataBaseFileName] /FS /Zi [RuntimeChecks] [Runtime] [TypeInfo]” [CompileOut] “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.2\7_CUDALibraries\simpleDevLibCUBLAS\kernels.cu”
1> Building with tools version “15.0”.
here are the compliation results of “simpleDevLibCUBLAS” in my computer.
1> cublas_device.lib(sgemmEx.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(hgemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(lapack_trttp_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(lapack_trttp_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(lapack_tpttr_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(lapack_tpttr_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(dgmm_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(dgmm_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(geam_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(geam_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(geqrf_batch.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_getrs.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_getri_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_getri_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_getrf_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_getrf_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_trsm_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_trsm_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_matinv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_matinv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(trmm_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(trmm_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(trsm_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(trsm_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(zhemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(zsymm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(chemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(csymm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(dsymm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(ssymm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(zher2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(zsyr2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(cher2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(csyr2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(dsyr2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(ssyr2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(csyherk3mEx.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(csyherkEx.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(zherk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(zsyrk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(cherk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(csyrk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(dsyrk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(ssyrk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_gemm_hp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_gemm_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(batch_gemm_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(cgemm3m.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(zgemm3m.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(zgemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(dgemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(cgemmEx.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(cgemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(sgemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(sphpr2_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(sphpr2_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(syher2_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(syher2_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(sphpr_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(sphpr_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(syher_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(syher_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(ger_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(ger_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(sphpmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(sphpmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(sbhbmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(sbhbmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(syhemv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(syhemv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(tbsv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(tbsv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(tpsv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(tpsv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(trsv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(trsv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(tpmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(tpmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(tbmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(tbmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(trmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(trmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(gbmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(gbmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(gemv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(gemv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(rotmg.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(rotm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(rotg.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(rot.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(asum.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(iamin.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(iamax.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(swap.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(copy.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(axpy.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(scal.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(dot.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(nrm2.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(name_converters.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(logging.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(xerbla.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(cublas.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> cublas_device.lib(gpvar.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> Creating library …/…/bin/win64/Release/simpleDevLibCUBLAS.lib and object …/…/bin/win64/Release/simpleDevLibCUBLAS.exp
1> cublas_device.lib(gpvar.obj) : error LNK2001: unresolved external symbol __iob_func
1> cublas_device.lib(gpvar.obj) : error LNK2001: unresolved external symbol _snprintf
1> …/…/bin/win64/Release//simpleDevLibCUBLAS.exe : fatal error LNK1120: 2 unresolved externals
1> The command exited with code 1120.
1> Done executing task “Link” – FAILED.
1>Done building target “Link” in project “simpleDevLibCUBLAS_vs2017.vcxproj” – FAILED.
1>
1>Done building project “simpleDevLibCUBLAS_vs2017.vcxproj” – FAILED.
1>
1>Build FAILED.
1>
1>cublas_device.lib(sgemmEx.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(hgemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(lapack_trttp_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(lapack_trttp_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(lapack_tpttr_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(lapack_tpttr_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(dgmm_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(dgmm_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(geam_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(geam_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(geqrf_batch.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_getrs.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_getri_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_getri_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_getrf_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_getrf_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_trsm_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_trsm_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_matinv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_matinv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(trmm_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(trmm_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(trsm_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(trsm_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(zhemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(zsymm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(chemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(csymm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(dsymm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(ssymm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(zher2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(zsyr2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(cher2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(csyr2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(dsyr2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(ssyr2k.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(csyherk3mEx.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(csyherkEx.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(zherk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(zsyrk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(cherk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(csyrk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(dsyrk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(ssyrk.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_gemm_hp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_gemm_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(batch_gemm_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(cgemm3m.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(zgemm3m.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(zgemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(dgemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(cgemmEx.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(cgemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(sgemm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(sphpr2_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(sphpr2_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(syher2_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(syher2_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(sphpr_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(sphpr_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(syher_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(syher_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(ger_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(ger_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(sphpmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(sphpmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(sbhbmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(sbhbmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(syhemv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(syhemv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(tbsv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(tbsv_sp.ob
There was a problem with the CUBLAS device lib build in CUDA 9.2
It will not be fixed.
Revert to CUDA 9.1 (or switch to VS2010)
[url]https://devtalk.nvidia.com/default/topic/1035640/cuda-setup-and-installation/errors-building-cuda-9-2-using-visual-studio-2013/[/url]
thanks again for your quick answer. i will try to install CUDA 9.1 but switching to VS2010 doesnt change anything i guess.
here is the compliation results of "simpleDevLibCUBLAS" on VS2010
1>------ Build started: Project: simpleDevLibCUBLAS, Configuration: Debug x64 ------
1>simpleDevLibCUBLAS.obj : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(sgemmEx.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(hgemm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(lapack_trttp_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(lapack_trttp_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(lapack_tpttr_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(lapack_tpttr_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(dgmm_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(dgmm_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(geam_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(geam_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(geqrf_batch.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_getrs.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_getri_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_getri_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_getrf_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_getrf_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_trsm_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_trsm_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_matinv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_matinv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(trmm_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(trmm_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(trsm_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(trsm_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(zhemm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(zsymm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(chemm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(csymm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(dsymm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(ssymm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(zher2k.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(zsyr2k.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(cher2k.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(csyr2k.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(dsyr2k.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(ssyr2k.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(csyherk3mEx.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(csyherkEx.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(zherk.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(zsyrk.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(cherk.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(csyrk.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(dsyrk.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(ssyrk.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_gemm_hp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_gemm_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(batch_gemm_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(cgemm3m.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(zgemm3m.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(zgemm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(dgemm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(cgemmEx.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(cgemm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(sgemm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(sphpr2_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(sphpr2_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(syher2_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(syher2_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(sphpr_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(sphpr_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(syher_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(syher_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(ger_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(ger_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(sphpmv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(sphpmv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(sbhbmv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(sbhbmv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(syhemv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(syhemv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(tbsv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(tbsv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(tbsv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(tpsv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(tpsv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(tpsv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(tpsv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(trsv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(trsv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(trsv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(trsv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(tpmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(tpmv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(tpmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(tpmv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(tbmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(tbmv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(tbmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(tbmv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(trmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(trmv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(trmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(trmv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(gbmv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(gbmv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(gbmv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(gbmv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(gemv_dp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(gemv_dp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(gemv_sp.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(gemv_sp.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(rotmg.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(rotmg.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(rotm.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(rotm.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(rotg.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(rotg.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(rot.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(rot.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(asum.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(asum.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(iamin.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(iamin.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(iamax.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(iamax.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(swap.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(swap.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(copy.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(copy.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(axpy.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(axpy.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(scal.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(scal.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(dot.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(dot.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(nrm2.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(nrm2.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(name_converters.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(name_converters.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(logging.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(logging.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(xerbla.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(xerbla.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(cublas.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(cublas.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>cublas_device.lib(gpvar.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>cublas_device.lib(gpvar.obj) : error LNK2038: mismatch detected for ‘_ITERATOR_DEBUG_LEVEL’: value ‘0’ doesn’t match value ‘2’ in kernels.cu.obj
1>LIBCMTD.lib(frame.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>LIBCMTD.lib(typinfo.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>LIBCMTD.lib(stdexcpt.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1>LIBCMTD.lib(typname.obj) : error LNK2038: mismatch detected for ‘_MSC_VER’: value ‘1600’ doesn’t match value ‘1900’ in kernels.cu.obj
1> Creating library …/…/bin/win64/Debug/simpleDevLibCUBLAS.lib and object …/…/bin/win64/Debug/simpleDevLibCUBLAS.exp
1>kernels.cu.obj : error LNK2019: unresolved external symbol fminf referenced in function "float __cdecl fmin(float,float)" (?fmin@@YAMMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol fmaxf referenced in function "float __cdecl fmax(float,float)" (?fmax@@YAMMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol exp2f referenced in function "float __cdecl exp2(float)" (?exp2@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol expm1f referenced in function "float __cdecl expm1(float)" (?expm1@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol log2f referenced in function "float __cdecl log2(float)" (?log2@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol log1pf referenced in function "float __cdecl log1p(float)" (?log1p@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol acoshf referenced in function "float __cdecl acosh(float)" (?acosh@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol asinhf referenced in function "float __cdecl asinh(float)" (?asinh@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol atanhf referenced in function "float __cdecl atanh(float)" (?atanh@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol logbf referenced in function "float __cdecl logb(float)" (?logb@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol ilogbf referenced in function "int __cdecl ilogb(float)" (?ilogb@@YAHM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol scalblnf referenced in function "float __cdecl scalbln(float,long)" (?scalbln@@YAMMJ@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol roundf referenced in function "float __cdecl round(float)" (?round@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol lroundf referenced in function "long __cdecl lround(float)" (?lround@@YAJM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol llroundf referenced in function "__int64 __cdecl llround(float)" (?llround@@YA_JM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol rintf referenced in function "float __cdecl rint(float)" (?rint@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol lrintf referenced in function "long __cdecl lrint(float)" (?lrint@@YAJM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol llrintf referenced in function "__int64 __cdecl llrint(float)" (?llrint@@YA_JM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol nearbyintf referenced in function "float __cdecl nearbyint(float)" (?nearbyint@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol truncf referenced in function "float __cdecl trunc(float)" (?trunc@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol fdimf referenced in function "float __cdecl fdim(float,float)" (?fdim@@YAMMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol cbrtf referenced in function "float __cdecl cbrt(float)" (?cbrt@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol remquof referenced in function "float __cdecl remquo(float,float,int *)" (?remquo@@YAMMMPEAH@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol erff referenced in function "float __cdecl erf(float)" (?erf@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol erfcf referenced in function "float __cdecl erfc(float)" (?erfc@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol lgammaf referenced in function "float __cdecl lgamma(float)" (?lgamma@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol tgammaf referenced in function "float __cdecl tgamma(float)" (?tgamma@@YAMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol copysignf referenced in function "float __cdecl copysign(float,float)" (?copysign@@YAMMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol nextafterf referenced in function "float __cdecl nextafter(float,float)" (?nextafter@@YAMMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol fmaf referenced in function "float __cdecl fma(float,float,float)" (?fma@@YAMMMM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol _dsign referenced in function "bool __cdecl signbit(double)" (?signbit@@YA_NN@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol _ldsign referenced in function "bool __cdecl signbit(long double)" (?signbit@@YA_NO@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol _fdsign referenced in function "bool __cdecl signbit(float)" (?signbit@@YA_NM@Z)
1>kernels.cu.obj : error LNK2019: unresolved external symbol __acrt_iob_func referenced in function device_cublas_sgemm
1>kernels.cu.obj : error LNK2019: unresolved external symbol __stdio_common_vfprintf referenced in function _vfprintf_l
1>…/…/bin/win64/Debug//simpleDevLibCUBLAS.exe : fatal error LNK1120: 35 unresolved externals
