CUBLAS reference
Hi forum,
I looking for the CUBLAS and CUFFT reference specification. The first entry when googling is a pdf manual v1.0 from June 2007 for CUBLAS and v1.1 from October 2007 for CUFFT, are those the most updated versions? are included by default in the SDK?
Sorry, I am newby in CUDA.
Kind regards.
Arturo Díaz-Almagro
hi,
i’m also totally new to CUDA and had the same “problem” some hours ago.
just have a look into your doc folder of the CUDA installation (generally C:\CUDA\doc).
there you will find both references as pdf files ;-)
good luck with CUDA developing!
regards,
fab
Thanks!!! I did not check the doc folder yet. Let’s do it!!!
Thank you again.
