Hello Forum!
I am trying to do the following simple operations on some tall skinny matrices (# of rows >> # of cols):
blockVectorR = blockVectorX * lambda
blockVectorR = blockVectorX - blockVectorR
activeBlockVectorR = get the active columns of blockVectorR(see activeMask, column i is active if activeMask[i] = 1)
XtactR = blockVectorX’* activeBlockVectorR
[Dimension: blockVectorR, blockVectorX => Mblocksize, activeBlockVectorR => McurrentBlockSize, lambda => blocksizeblocksize, XtactR => blocksizecurrentBlockSize]
I am using both cublasDgemm routine and OpenMP target offloading for this purpose. But the weird thing is, the very last cublasDgemm call [which is doing transpose(X)*Y type operation] is giving me CUBLAS_STATUS_INTERNAL_ERROR. Though the the final output of the following codeblock matches with two other implementation of the same oprations [ one is using Intel MKL library & cpu kernels and the other one is using NVBLAS dgemm routine and same GPU kernels in following codeblock]. I have attached the outputs here.
Can anyone please point me what am I doing wrong? Or am I missing something here? I really appreciate your help.
Fazlay
#include <stdio.h>
#include <stdlib.h>
#ifdef USE_CUBLAS
#include <cuda_runtime.h>
#include "cublas_v2.h"
#endif
#define DGEMM_RESTRICT __restrict__
//Custom kernels for GPU
void getActiveBlockVector_GPU_v2(double *activeBlockVectorR, int *activeMask, double *blockVectorR, int M, int blocksize, int currentBlockSize);
void mat_sub_GPU_v2(double *src1, double *src2, double *dst, const int row, const int col);
//Utility Kernel
void print_matrix(double *array, int row, int col);
int main()
int M = 4985944, blocksize = 8;
int i, j, k;
int currentBlockSize = 7;
const double cudaAlpha = 1.0;
const double cudaBeta = 0.0;
int activeMask[8];
activeMask[0] = 1 ; activeMask[1] = 1 ; activeMask[2] = 1 ; activeMask[3] = 1 ;
activeMask[4] = 1 ; activeMask[5] = 1 ; activeMask[6] = 1 ; activeMask[7] = 0;
double* DGEMM_RESTRICT blockVectorX = (double*) malloc(sizeof(double) * M * blocksize);
double* DGEMM_RESTRICT lambda = (double*) malloc(sizeof(double) * blocksize * blocksize);
double* DGEMM_RESTRICT blockVectorR = (double*) malloc(sizeof(double) * M * blocksize);
double* DGEMM_RESTRICT activeBlockVectorR = (double*) malloc(sizeof(double) * M * blocksize);
double* DGEMM_RESTRICT XtactR = (double*) malloc(sizeof(double) * blocksize * currentBlockSize);
double* DGEMM_RESTRICT cblas_XtactR = (double*) malloc(sizeof(double) * blocksize * currentBlockSize);
double* DGEMM_RESTRICT nvblas_XtactR = (double*) malloc(sizeof(double) * blocksize * currentBlockSize);
srand(0);
//#pragma omp paralle for default(shared) private(j)
for(i = 0 ; i < M ; i++)
for(j = 0 ; j < blocksize ; j++)
blockVectorX[i * blocksize + j] = (double)rand()/(double)RAND_MAX;
for(i = 0 ; i < blocksize ; i++)
lambda[i * blocksize + j] = (double)rand()/(double)RAND_MAX;
//======== offloading to GPU start ==========//
#if defined(USE_CUBLAS)
double *d_blockVectorX, *d_lambda, *d_blockVectorR, *d_activeBlockVectorR, *devPtrXtR, *devPtrXtactR;
int *d_activeMask;
cudaError_t cuberror;
cuberror = cudaMalloc ((void**)&d_blockVectorX, M * blocksize * sizeof(double));
if( cuberror != 0 ){ printf("cudaMalloc Filed d_blockVectorX\n"); return 0; }
cuberror = cudaMalloc ((void**)&d_lambda, blocksize * blocksize * sizeof(double));
if( cuberror != 0 ){ printf("cudaMalloc Filed d_lambda\n"); return 0; }
cuberror = cudaMalloc ((void**)&d_blockVectorR, M * blocksize * sizeof(double));
if( cuberror != 0 ){ printf("cudaMalloc Filed d_blockVectorR\n"); return 0; }
cuberror = cudaMalloc ((void**)&d_activeBlockVectorR, M * currentBlockSize * sizeof(double));
if( cuberror != 0 ){ printf("cudaMalloc Filed d_activeBlockVectorR\n"); return 0; }
cuberror = cudaMalloc ((void**)&devPtrXtR, blocksize * blocksize * sizeof(double));
cuberror = cudaMalloc ((void**)&devPtrXtactR, blocksize * currentBlockSize * sizeof(double));
if( cuberror != 0 ){ printf("cudaMalloc Filed devPtrXtactR\n"); return 0; }
cuberror = cudaMalloc ((void**)&d_activeMask, blocksize * sizeof(int));
if( cuberror != 0 ){ printf("cudaMalloc Filed d_activeMask\n"); return 0; }
cuberror = cudaMemcpy((void *)d_blockVectorX, blockVectorX, M * blocksize * sizeof(double), cudaMemcpyHostToDevice);
if( cuberror != 0 ){ printf("cudaMemcpy X ==> %d\n", cuberror); return 0; }
cuberror = cudaMemcpy((void *)d_activeMask, activeMask, blocksize * sizeof(int), cudaMemcpyHostToDevice);
if( cuberror != 0 ){ printf("cudaMemcpy d_activeMask ==> %d\n", cuberror); return 0; }
cuberror = cudaMemcpy((void *)d_lambda, lambda, blocksize * blocksize * sizeof(double), cudaMemcpyHostToDevice);
if( cuberror != 0 ){ printf("cudaMemcpy lambda ==> %d\n", cuberror); return 0; }
cublasStatus_t cubstat;
cublasHandle_t handle;
cublasStatus_t gemmStat;
cubstat = cublasCreate(&handle);
if( cubstat != CUBLAS_STATUS_SUCCESS ){ printf("HandleCreationFailure\n"); return 0; }
//blockVectorR = blockVectorX * lambda
gemmStat = cublasDgemm(handle, CUBLAS_OP_N, CUBLAS_OP_N, blocksize, M, blocksize,
&cudaAlpha, d_lambda, blocksize, d_blockVectorX, blocksize, &cudaBeta, d_blockVectorR, blocksize);
if(gemmStat != CUBLAS_STATUS_SUCCESS) {printf("** cublasDgemm status-1: %d\n", gemmStat);}
//blockVectorR = blockVectorX - blockVectorR
mat_sub_GPU_v2(d_blockVectorX, d_blockVectorR, d_blockVectorR, M, blocksize);
//activeBlockVectorR = get the active columns of blockVectorR(first 7 columns are active, see activeMask array)
getActiveBlockVector_GPU_v2(d_activeBlockVectorR, d_activeMask, d_blockVectorR, M, blocksize, currentBlockSize);
//XtactR = blockVectorX'* activeBlockVectorR
gemmStat = cublasDgemm(handle, CUBLAS_OP_N, CUBLAS_OP_T, currentBlockSize, blocksize, M,
&cudaAlpha, d_activeBlockVectorR, currentBlockSize, d_blockVectorX, blocksize, &cudaBeta, devPtrXtactR, currentBlockSize);
if(gemmStat != CUBLAS_STATUS_SUCCESS) {printf("** cublasDgemm status-2: %d\n", gemmStat);}
//copying result back to CPU
cuberror = cudaMemcpy(XtactR, devPtrXtactR, blocksize * currentBlockSize * sizeof(double), cudaMemcpyDeviceToHost);
if( cuberror != 0 ){ printf("cudaMemcpy Failed XtactR: %d\n", cuberror);}
printf("\n=========== Printing XtactR matrix (GPU) ==============\n");
print_matrix(XtactR, blocksize, currentBlockSize);
#endif
cudaFree (d_blockVectorX);
cudaFree (d_lambda);
cudaFree (d_blockVectorR);
cudaFree (devPtrXtR);
cublasDestroy(handle);
#endif
return 0;
//GPU custom kernels
int i, j, k = 0;
#pragma omp target is_device_ptr(activeBlockVectorR, blockVectorR, activeMask)
#pragma omp teams distribute parallel for default(shared) private(j, k)
k = 0;
if(activeMask[j] == 1)
activeBlockVectorR[i * currentBlockSize + k] = blockVectorR[i * blocksize + j];
k++;
int i, j;
#pragma omp target is_device_ptr(src1, src2, dst)
#pragma omp teams distribute parallel for private(j) default(shared)
for(i = 0; i < row ; i++)
for(j = 0 ; j < col ; j++)
dst[i * col + j] = src1[i * col + j] - src2[i * col + j];
//Utility kernel
int i, j;
printf("%lf ", array[i * col + j]);
printf("\n");
