Hey,
I’ve tried running the installer using this command:
sudo sh cuda_10.0.130_410.48_linux.run -silent -driver
but it is not responding for some long hours,
looking at the logs I see that it is stuck on 97% for a long time
is there a way to make the logs be more detailed?
Installing the NVIDIA display driver...
Verifying archive integrity... OK
Uncompressing NVIDIA Accelerated Graphics Driver for Linux-x86_64 410.48................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
Welcome to the NVIDIA Software Installer for Unix/Linux
Detected 8 CPUs online; setting concurrency level to 8.
Installing NVIDIA driver version 410.48.
There appears to already be a driver installed on your system (version:
410.48). As part of installing this driver (version: 410.48), the existing
driver will be uninstalled. Are you sure you want to continue? (Answer:
Continue installation)
Running distribution scripts
Executing /usr/lib/nvidia/pre-install: [ ] 0%
Executing /usr/lib/nvidia/pre-install: [##############################] 100%
WARNING: One or more modprobe configuration files to disable Nouveau are
already present at:
/etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be
sure you have rebooted your system since these files were written.
If you have rebooted, then Nouveau may be enabled for other
reasons, such as being included in the system initial ramdisk or
in your X configuration file. Please consult the NVIDIA driver
README and your Linux distribution's documentation for details on
how to correctly disable the Nouveau kernel driver.
The distribution-provided pre-install script failed! Are you sure you want
to continue? (Answer: Continue installation)
For some distributions, Nouveau can be disabled by adding a file in the
modprobe configuration directory. Would you like nvidia-installer to
attempt to create this modprobe file for you? (Answer: Yes)
One or more modprobe configuration files to disable Nouveau have been
written. For some distributions, this may be sufficient to disable
Nouveau; other distributions may require modification of the initial
ramdisk. Please reboot your system and attempt NVIDIA driver installation
again. Note if you later wish to reenable Nouveau, you will need to delete
these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
Would you like to register the kernel module sources with DKMS? This will
allow DKMS to automatically build a new module, if you install a different
kernel later. (Answer: Yes)
Installing both new and classic TLS OpenGL libraries.
Installing both new and classic TLS 32bit OpenGL libraries.
Install NVIDIA's 32-bit compatibility libraries? (Answer: Yes)
Will install GLVND GLX client libraries.
Will install GLVND EGL client libraries.
Skipping GLX non-GLVND file: "libGL.so.410.48"
Skipping GLX non-GLVND file: "libGL.so.1"
Skipping GLX non-GLVND file: "libGL.so"
Skipping EGL non-GLVND file: "libEGL.so.410.48"
Skipping EGL non-GLVND file: "libEGL.so"
Skipping EGL non-GLVND file: "libEGL.so.1"
Skipping GLX non-GLVND file: "./32/libGL.so.410.48"
Skipping EGL non-GLVND file: "./32/libEGL.so.410.48"
Uninstalling the previous installation with /usr/bin/nvidia-uninstall.
Skipping GLVND file: "libOpenGL.so.0"
Skipping GLVND file: "libOpenGL.so"
Skipping GLVND file: "libGLESv1_CM.so.1.2.0"
Skipping GLVND file: "libGLESv1_CM.so.1"
Skipping GLVND file: "libGLESv1_CM.so"
Skipping GLVND file: "libGLESv2.so.2.1.0"
Skipping GLVND file: "libGLESv2.so.2"
Skipping GLVND file: "libGLESv2.so"
Skipping GLVND file: "libGLdispatch.so.0"
Skipping GLVND file: "libGLX.so.0"
Skipping GLVND file: "libGLX.so"
Skipping GLVND file: "libGL.so.1.7.0"
Skipping GLVND file: "libGL.so.1"
Skipping GLVND file: "libGL.so"
Skipping GLVND file: "libEGL.so.1.1.0"
Skipping GLVND file: "libEGL.so.1"
Skipping GLVND file: "libEGL.so"
Skipping GLVND file: "./32/libOpenGL.so.0"
Skipping GLVND file: "./32/libGLdispatch.so.0"
Skipping GLVND file: "./32/libGLESv2.so.2.1.0"
Skipping GLVND file: "./32/libGLESv1_CM.so.1.2.0"
Skipping GLVND file: "./32/libGL.so.1.7.0"
Skipping GLVND file: "./32/libGLX.so.0"
Skipping GLVND file: "./32/libEGL.so.1.1.0"
Searching for conflicting files:
Searching: [ ] 0%
Searching: [############### ] 50%
Searching: [##############################] 100%
Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (410.48):
Installing: [ ] 0%
Installing: [ ] 0%
Installing: [# ] 0%
Installing: [# ] 0%
Installing: [# ] 0%
Installing: [# ] 0%
Installing: [# ] 0%
Installing: [# ] 1%
Installing: [# ] 1%
Installing: [# ] 1%
Installing: [# ] 1%
Installing: [# ] 1%
Installing: [# ] 2%
Installing: [# ] 2%
Installing: [# ] 2%
Installing: [# ] 2%
Installing: [# ] 2%
Installing: [# ] 2%
Installing: [# ] 3%
Installing: [# ] 3%
Installing: [## ] 3%
Installing: [## ] 4%
Installing: [## ] 5%
Installing: [## ] 6%
Installing: [### ] 6%
Installing: [### ] 7%
Installing: [### ] 8%
Installing: [### ] 9%
Installing: [#### ] 10%
Installing: [#### ] 11%
Installing: [#### ] 12%
Installing: [#### ] 13%
Installing: [##### ] 13%
Installing: [##### ] 14%
Installing: [##### ] 15%
Installing: [##### ] 16%
Installing: [###### ] 16%
Installing: [###### ] 17%
Installing: [###### ] 18%
Installing: [###### ] 19%
Installing: [###### ] 20%
Installing: [####### ] 20%
Installing: [####### ] 21%
Installing: [####### ] 22%
Installing: [####### ] 23%
Installing: [######## ] 23%
Installing: [######## ] 24%
Installing: [######## ] 25%
Installing: [######## ] 26%
Installing: [######### ] 26%
Installing: [######### ] 27%
Installing: [######### ] 28%
Installing: [######### ] 29%
Installing: [########## ] 30%
Installing: [########## ] 31%
Installing: [########## ] 32%
Installing: [########## ] 33%
Installing: [########### ] 33%
Installing: [########### ] 34%
Installing: [########### ] 35%
Installing: [########### ] 36%
Installing: [############ ] 36%
Installing: [############ ] 37%
Installing: [############ ] 38%
Installing: [############ ] 39%
Installing: [############ ] 40%
Installing: [############# ] 40%
Installing: [############# ] 41%
Installing: [############# ] 42%
Installing: [############# ] 43%
Installing: [############## ] 43%
Installing: [############## ] 44%
Installing: [############## ] 45%
Installing: [############## ] 46%
Installing: [############### ] 46%
Installing: [############### ] 47%
Installing: [############### ] 48%
Installing: [############### ] 49%
Installing: [################ ] 50%
Installing: [################ ] 51%
Installing: [################ ] 52%
Installing: [################ ] 53%
Installing: [################# ] 53%
Installing: [################# ] 54%
Installing: [################# ] 55%
Installing: [################# ] 56%
Installing: [################## ] 56%
Installing: [################## ] 57%
Installing: [################## ] 58%
Installing: [################## ] 59%
Installing: [################## ] 60%
Installing: [################### ] 60%
Installing: [################### ] 61%
Installing: [################### ] 62%
Installing: [################### ] 63%
Installing: [#################### ] 63%
Installing: [#################### ] 64%
Installing: [#################### ] 65%
Installing: [#################### ] 66%
Installing: [##################### ] 66%
Installing: [##################### ] 67%
Installing: [##################### ] 68%
Installing: [##################### ] 69%
Installing: [###################### ] 70%
Installing: [###################### ] 71%
Installing: [###################### ] 72%
Installing: [###################### ] 73%
Installing: [####################### ] 73%
Installing: [####################### ] 74%
Installing: [####################### ] 75%
Installing: [####################### ] 76%
Installing: [######################## ] 76%
Installing: [######################## ] 77%
Installing: [######################## ] 78%
Installing: [######################## ] 79%
Installing: [######################## ] 80%
Installing: [######################### ] 80%
Installing: [######################### ] 81%
Installing: [######################### ] 82%
Installing: [######################### ] 83%
Installing: [########################## ] 83%
Installing: [########################## ] 84%
Installing: [########################## ] 85%
Installing: [########################## ] 86%
Installing: [########################### ] 86%
Installing: [########################### ] 87%
Installing: [########################### ] 88%
Installing: [########################### ] 89%
Installing: [############################ ] 90%
Installing: [############################ ] 91%
Installing: [############################ ] 92%
Installing: [############################ ] 93%
Installing: [############################# ] 93%
Installing: [############################# ] 94%
Installing: [############################# ] 95%
Installing: [############################# ] 96%
Installing: [##############################] 96%
Installing: [##############################] 97%
