I have a Quatro p1000, I’m having a very difficult time getting CUDA 11.1 installed.
I have a Windows 10 x64 machine with VS 2019 Community installed, all the updates are up-to-date for both Windows and VS2019 CE.
In the Nvidia CUDA setup log, I see:
223.355 | ERROR: [NVI2.NVMsiPhase] 827@CNVMsiPhase::InvokePhase : Caught exception Exception {0x80070643 - Fatal error during installation.; File: NVMsiPhase.cpp; Line: 75}.
223.381 | INFO: [NVI2.NVInstaller] 2930@CNVInstaller::InternalPerformInstallPackagePhases : Exiting Checkpoint: Processing package phase “NsightMSINoTraffic” ( 46235 ms ).
223.381 | INFO: [NVI2.NVInstaller] 1969@CNVInstaller::InternalPerformInstall : Exiting Checkpoint: Processing Package Phases in “nsight_vse_11.1” ( 46235 ms ).
223.393 | ERROR: [NVI2.NVInstaller] 1990@CNVInstaller::InternalPerformInstall : Package “nsight_vse_11.1” failed with error: Exception {0x80070643 - Fatal error during installation.; File: PerformInstall.cpp; Line: 3955; Phase failure}.
223.393 | DEBUG: [DisplayDriver.DisplayDriverExtSite] 1605@CDisplayDriverExtSite::AfterInstallPackage : Package that finished is not Display.Driver , returning early.
223.394 | ERROR: [NVI2.NVInstaller] 2049@CNVInstaller::InternalPerformInstall : Failing at package “nsight_vse_11.1” failed with error: Exception {0x80070643 - Fatal error during installation.} - aborting install.
223.394 | INFO: [NVI2.NVInstaller] 1845@CNVInstaller::InternalPerformInstall : Exiting Checkpoint: Processing Package “nsight_vse_11.1” ( 46250 ms ).
223.394 | INFO: [NVI2.NVInstaller] 1825@CNVInstaller::InternalPerformInstall : Exiting Checkpoint: Processing Packages ( 138421 ms ).
223.394 | INFO: [system] 472@Nvidia::Logging::Logger::Logger : 2020-Dec-10 17:52:15 : Logging init OK. Using configuration from HKLM for DefaultProcess, for the setup.exe.
223.394 | INFO: [DocExt.DocExtSite] 261@CDocExtSite::DecideLaunchDocFinishItem : Skipping finish option decision as package not successfully installed.
223.395 | INFO: [system] 472@Nvidia::Logging::Logger::Logger : 2020-Dec-10 17:52:15 : Logging init OK. Using configuration from HKLM for DefaultProcess, for the setup.exe.
223.396 | INFO: [CUDAToolkit.CUDAToolkitExtSite] 700@CCUDAToolkitExtSite::DecideLaunchDocFinishItem : Skipping finish option decision as package not successfully installed.
223.399 | ERROR: [NVI2.InstallThread] 54@CInstallThread::ThreadProc : Install failed - Exception {0x80070643 - Fatal error during installation.; File: PerformInstall.cpp; Line: 3955; Phase failure} - going to fail state.
If I do a custom install and skip all the Visual Studio options, it installs, but deviceQuery.exe fails, but then, vnidia-smi.exe tells me:
NVIDIA-SMI 431.98 Driver Version: 431.98 CUDA Version: 10.1
But, why is it 10.1 if I installed 11.1? Can VS2019 Community Edition even be used? It is not clear from Installation Guide Windows :: CUDA Toolkit Documentation if “VS2019 Community” will work.
