Cuda 11.4:
In the following simple kernel, each column (i) is subtracted from column (i+1).
Then ABS2 of the result is written to destination.
The code works fine on matrix with 12800 rows, 40 columns.
I checked data at start of destination and at the end of the destination. All data is correct.
Should I run: cudaDeviceSynchronize () after such kernel ?
I checked the elapsed time with and without cudaDeviceSynchronize .
With cudaDeviceSynchronize , the time is much longer.
__global__ void mat_col_sub_kernel (ComplexInt32 *pSrc, uint32_t *pDest, int Cols, int Rows)
	uint32_t RowId = threadIdx.x + blockIdx.x * blockDim.x;
	uint32_t ColId = threadIdx.y + blockIdx.y * blockDim.y;
	if (ColId>0 && ColId<Cols && RowId<Rows)
		unsigned int idx;
		unsigned int idOut;
		uint32_t Re,Im;
		idx = RowId*Cols + ColId;
		idOut = RowId*(Cols-1) + ColId-1;
		Re = pSrc[idx].Re - pSrc[idx-1].Re;
		Im = pSrc[idx].Im - pSrc[idx-1].Im;
		pDest[idOut] = Re*Re+Im*Im;
void mat_col_sub (ComplexInt32 *pSrc, uint32_t *pDest, int Cols, int Rows)
	dim3 dimBlock(DIMX, DIMY);
	dim3 dimGrid;
	dimGrid.x = (Rows+ dimBlock.x - 1) / dimBlock.x;
	dimGrid.y = (Cols+ dimBlock.y - 1) / dimBlock.y;
        clock_gettime (CLOCK_REALTIME, &Before);
	mat_col_sub_kernel <<<dimGrid, dimBlock>>> (pSrc, pDest, Cols, Rows);
        clock_gettime (CLOCK_REALTIME, &After);
Thank you,
Zvika
What do you mean by “much longer”. If you measure the time on the host without cudaDeviceSynchronize , you probably just measure the kernel launch overhead, but not the kernel execution time.
Hi striker159, All,
It’s quite strange.
I called:
cudaMemcpy (… , cudaMemcpyDeviceToHost)
and then wrote the data to reference file.
Then, after power off/on, I read file file, ran the kernel without cudaDeviceSynchronize.
After cudaMemcpy I compared the data to the reference file.
They are identical.
Does it make sense ?
Thank you,
Zvika
cudaMemcpy(..., cudaMemcpyDeviceToHost) uses default-stream semantics. The call will automatically wait for any kernels to finish before the copy is executed. You do not need to explicitely call cudaDeviceSynchronize() beforehand.
Hi striker159,
Thank you very much !
Best regards,
Zvika
